fuse disaster
Hi, i was playing around with bootloadersizes and fuses.BOOTSZ0 and BOOTSZ1 Seems I did something wrong, because no more access to the device. Looks as the device has a wrong signature now and is unaccessible
avrdude: stk500v2_command(): command failed avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status: SCK fail avrdude: initialization failed, rc=-1 avrdude: AVR device initialized and ready to accept instructions avrdude: Device signature = 0x88468e avrdude: Expected signature for ATmega328P is 1E 95 0F
Arduino Duemilanove board with ATmega328p AVR MKII AVRDUDE on Linux
Any suggestion what to do now ?
Device signature shouldn't be able to change. For me, more probably is some problem with connection. Try to show more verbose output, the same avrdude command with -vvvv switch added.
I tried to erase -e:
[> avrdude -vvv -c avrisp2 -pm328p -e
avrdude: Version 6.1, (openSUSE Buildservice)
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/home/op/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : avrisp2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200001200
avrdude: stk500v2_getsync(): found AVRISP mkII programmer
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel AVR ISP mkII
         Programmer Model: AVRISP mkII
         Hardware Version: 1
         Firmware Version Master : 1.17
         Vtarget         : 4.9 V
         SCK period      : 8.00 us
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
pretty muchg the same on Arduino IDE "burn bootloader"
/home/op/WORK/0_uC/Arduino_main/0IDE64/arduino-1.6.6/hardware/tools/avr/bin/avrdude -C/home/op/WORK/0_uC/Arduino_main/0IDE64/arduino-1.6.6/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Apr 14 2015 at 19:04:16
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/home/op/WORK/0_uC/Arduino_main/0IDE64/arduino-1.6.6/hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : stk500v2
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Description     : Atmel STK500 Version 2.x firmware
         Hardware Version: 1
         Vtarget         : 4.9 V
avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status: Unknown status 0x00
         this check.
Error while burning bootloader.
I think the connection is wrong, broken wire or something else. Do you have another chip to try? Btw, I suggested 4 x v '-vvvv', it enables to see individual bytes sent and received. And also chip erase function is wearing the chip (if it works), to read e.g. fuse is enough for test.
> avrdude -vvvv -patmega328p -cstk500v2 -Pusb
         Using Port                    : usb
avrdude: Sent: . [01]
avrdude: Recv: . [01] . [00] . [0a] A [41] V [56] R [52] I [49] S [53] P [50] _ [5f] M [4d] K [4b] 2 [32]
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
avrdude: Sent: . [03] . [90]
avrdude: Recv: . [03] . [00] . [01]
avrdude: Sent: . [03] . [91]
avrdude: Sent: . [03] . [92]
avrdude: Recv: . [03] . [00] . [11]
         Hardware Version: 1
avrdude: Sent: . [03] . [94]
avrdude: Recv: . [03] . [00] 1 [31]
         Vtarget         : 4.9 V
avrdude: Sent: . [03] . [98]
avrdude: Recv: . [03] . [00] . [06]
avrdude: Sent: . [10] . [c8] d [64] . [19]   [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00]
avrdude: Recv: . [10] . [c0]
avrdude: Sent: . [03] . [a1]
avrdude: Recv: . [03] . [00] . [04]
         this check.
avrdude: Sent: . [11] . [01] . [01]
avrdude: Recv: . [11] . [00]
I changed for a working (checked) 2nd mcu of same model 328p
~> avrdude -vvvv -patmega328p -cstk500v2 -Pusb
         Using Port                    : usb
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 1
         Vtarget         : 4.9 V
avrdude: Recv: . [03] . [00] . [00]
         this check.
Maybe my AVR MKII firmware version should be upgraded (?) Whta is the actual version ?
Programmer Type : STK500V2 Description : Atmel AVR ISP mkII Programmer Model: AVRISP mkII Hardware Version: 1 Firmware Version Master : 1.17 Vtarget : 4.9 V SCK period : 8.00 us
All the time it looks to me that there is some connection problem or MCU won't start (missing power or clock). I'd never used AVRISPmkII so I have no experience with this programmer but one thing is suspicious:
A1 command is illegal in STK500v2 and the second thing is two different responses. Anyway, I'm recommending to check carefully your setup first.
While I was typing:
I don't think so. It MUST work without any upgrade.
I bought a new Atmega328p this morning. All works as expected, Burn bootloader from Arduino IDE. Upload sketch also successfully.
So i damaged the mcu from yesterday. I tried to change a single fuse (hfuse), maybe i must change all 3 fuses at once (?)
It costs only few Euros, but I 'm still curious if there is a way to repair, erase, or whatever to get the chip work again. Is it possible to destroy a mcu at all ?
Maybe you buggered the serial programming and/or reset bits.
I've been through that mess lately. First I managed to set the oscillator to "8MHz external", but I didn't have an 8 MHz crystal anywhere. The next time I sat the internal clock frequency to 128kHz. Now the microcontroller was too slow for the ISP. Bummer.. ::) The last time I disabled the SPI interface so I wasn't able to bootload it anymore.
The solution is a HVPP, High Voltage Parallel Programmer. It applies 12v on the reset line, bypassing all fuse settings. There is a few guides on the internet showing how to build one (If you don't have an STK500 or AVR Dragon). Really useful if you want to play with the fuse settings and fix your AVRs afterwards!
wally123: ...curious if there is a way to repair, erase, or whatever...
Probably
Riva: Maybe you buggered the serial programming and/or reset bits.
This is a good point, sounds likely
hansibull: The solution is a HVPP, High Voltage Parallel Programmer. It applies 12v on the reset line, bypassing all fuse settings. There is a few guides on the internet showing how to build one (If you don't have an STK500 or AVR Dragon). Really useful if you want to play with the fuse settings and fix your AVRs afterwards!
Yes, and I put together a guide that I think is easy.
I recommend go ahead and read the fuses to see what you did: HV-Rescue-Simple Use a fuse calculator to better understand the fuses:fusecalc
Check out Nick Gammon’s high voltage programmer also
http://www.gammon.com.au/forum/?id=12898
CrossRoads: Check out Nick Gammon's high voltage programmer also
As hansibull has suggested in reply #10.
