Gc9a01 LCD Unable to display images properly
Hi. i am a student working on a project using an Arduino and LCD. The model im using is the gc9a01 1.28 inch . As I'm fairly new i tried searching the web for sample code to try and understand. I came across Waveshare sample code and tried to display a saved image.
However when i used their software "image2lcd v2.9" the image appeared was a bunch of random pixel . I have also tried to use other image converter but the same result.
i think it has something to do with the way they coded it or i'm missing something.
Anyone can help? Thanks
Welcome to the forum.
The waveshare display seems to be able to run at 3.3V and 5V: https://www.waveshare.com/1.28inch-lcd-module.htm
Can your display work at both voltages ? Can you give a link to where you bought it and/or show a photo of the back side ? Which Arduino board do you use ?
This seems to be the best information: https://dronebotworkshop.com/gc9a01/. He uses an Arduino Uno and the waveshare library.
Have you tried the demo code in "LCD_Module_code.zip" ?
Is your problem only the conversion of your own image with "Image2Lcd2.9.zip" ?
Have you tried the included "ABC.bmp" ?
I'm sorry, but I'm not going to run a random executable file on my computer.
It is most likely that you have the wrong "bmp" format. The included "ABC.bmp" has 16 possible colors format of which only two colors are used and it is the BMP V3 format. So perhaps you have to reduce your image to a format with 16 colors.
Hi! thanks for replying. i am using the mega board. To clarify I have no problem running the demo code provided. The problem is when I am trying to display my own images. I am new to this. I tried replacing the C string array with my own but when i display it, it turns into a bunch of random pixel. I am not familiar with bmp format, could you explain more?
This is where i bought it https://shopee.sg/product/562720324/17545510432?smtt=0.412799521-1671382252.3
They provide three BMP files, so I assume that is the format that you need to make. It is sometimes called the "Windows BMP format".
I'm not sure if your display is compatible with your 5V Arduino board.
Hi statisbmed,
Please notice that this display is 3.3V device. For that matter I prefer to wire this display to an ESP8266 or an ESP32. These are fine displays and I have recently written a post on this display on my Arduino blog: An internet-synced clock: circular display with GC9A01 controller powered by an ESP8266 – thesolaruniverse
Althought I have not done it yet these displays must be perfect to show images on. The Arduinos support 16-bit color ( in Windows speak: True Color): 65,536 colors. Convert your images from 24-bit to 16-bit and voila: they must be fully appreciable on this nice display. Available memory in an Arduino Uno is too small to contain a 240*240 pixel 16-bit color image in c-format, so it is wise in that situation to store your images on SD card and use a SS card reader
Good luck - photoncatcher
Hi photoncatcher,
I have tried changing the image to greyscale, and the file size was 210x210x8 was just enough for the Arduino, however the image displayed was still displayed as a bunch of random pixel. I am using the waveshare sample code to run. I replace their c array with my own.
  • i have a feeling its the way the sample code display its images, could you show me a sample code of displaying c array? Thanks alot btw !
Hi statisbmed,
Modify this:
type or past// Nano_130x130_TFT_duck_12x120_progmem_
// Thanks to David Prentice for assistance
   #include <LCDWIKI_GUI.h> //Core graphics library
   #include <LCDWIKI_SPI.h> //Hardware-specific library
   #include <avr/pgmspace.h>
   #define MAGENTA 0xF81F
   #define WHITE   0xFFFF
   #define BLACK   0x0000
   LCDWIKI_SPI mylcd(SSD1283A, 10, 9, 8, A3); // hardware spi,cs,cd,reset
   const uint8_t duck_120_bitmap[1800] PROGMEM = {
// 123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xef, 0xff, 0xfe, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xf7, 0xff, 0xfe, 0xdf, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xf3, 0xff, 0xfe, 0xef, 0xff, 0xff, 0xf7, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xfd, 0xff, 0xfe, 0xef, 0xff, 0xff, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xfd, 0xff, 0xff, 0x6f, 0xff, 0xff, 0xf7, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xfe, 0xff, 0xff, 0x6f, 0xff, 0xff, 0xef, 0xff, 0xff, 0xff, 0xff, 0xfe,
    0xff, 0xff, 0xff, 0xfe, 0x7f, 0xff, 0x6f, 0xff, 0xff, 0xef, 0xff, 0xff, 0xff, 0xff, 0xfe,
    0xff, 0xff, 0xff, 0xff, 0xbf, 0xff, 0xb7, 0xff, 0xff, 0xf7, 0xff, 0xff, 0xff, 0xff, 0xfd,
    0xff, 0xff, 0xff, 0xff, 0xbf, 0xff, 0xaf, 0xff, 0xff, 0xef, 0xff, 0xff, 0xff, 0xff, 0xfd,
    0xff, 0xff, 0xff, 0xff, 0xdf, 0xff, 0xcf, 0xff, 0xff, 0xef, 0xff, 0xff, 0xff, 0xff, 0xf8,
    0xff, 0xff, 0xff, 0xff, 0xcf, 0xff, 0xe7, 0xff, 0xff, 0xef, 0xff, 0xff, 0xff, 0xff, 0xf9,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf3,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xf8, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xf7, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xf7, 0xbf, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xf3, 0xbf, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xfd, 0x9f, 0xff, 0xff, 0xf5, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xfc, 0xdf, 0xff, 0xff, 0xc0, 0x0f, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0x1f, 0xff, 0xff, 0xc3, 0xc1, 0xf8, 0x3f, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xdf, 0xff, 0xff, 0xfc, 0x7c, 0x5d, 0x9f, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xef, 0xff, 0xff, 0xff, 0x1f, 0x15, 0xcf, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x1f, 0xcf, 0xe1, 0xe7, 0x3f, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0x47, 0xe7, 0xff, 0xf3, 0x1f, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc7, 0xf0, 0x37, 0x7f, 0xf9, 0x8f, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x9f, 0xf3, 0x40, 0x0f, 0xfd, 0xa7, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x3f, 0xfb, 0xf3, 0xe7, 0xfc, 0xb3, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xff, 0xf7, 0xe7, 0xf3, 0xfe, 0x33, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0xff, 0xf3, 0xcf, 0xfb, 0xbf, 0x7b, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xf9, 0xff, 0xf7, 0x9f, 0xf9, 0xbf, 0xfd, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0xe7, 0x3f, 0xfd, 0x9f, 0xfc, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0xcf, 0xd7, 0xff, 0x7f, 0xfc, 0xdf, 0xfc, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0x1f, 0x03, 0xff, 0xff, 0xfe, 0xcf, 0xfe, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xff, 0x7c, 0xfc, 0xff, 0xef, 0xfe, 0xef, 0xfe, 0x7f, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xfc, 0x71, 0xfd, 0xfe, 0x03, 0xfe, 0x6f, 0xff, 0x7e, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xf9, 0xe7, 0xfc, 0xfc, 0xf9, 0xfe, 0xef, 0xff, 0x3e, 0x7f, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xfb, 0xcf, 0xfd, 0xf9, 0xfe, 0xfe, 0x67, 0xff, 0xbc, 0x7f, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xf3, 0x9f, 0xf9, 0xf3, 0xfe, 0x7f, 0x6f, 0xff, 0x9c, 0x3f, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xe7, 0x3f, 0xf3, 0xe7, 0xff, 0x7e, 0x6f, 0xff, 0xc3, 0x7f, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xce, 0x7f, 0xf7, 0xcf, 0xff, 0x3f, 0x67, 0xff, 0xeb, 0x3b, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xde, 0xff, 0xe7, 0x9f, 0xff, 0x7f, 0x4f, 0xff, 0xff, 0x73, 0xff,
    0xff, 0xff, 0xff, 0xff, 0x9c, 0xff, 0xef, 0xbf, 0xff, 0xbf, 0x6f, 0xff, 0xfe, 0x47, 0xff,
    0xff, 0xff, 0xff, 0xff, 0xb9, 0xff, 0xcf, 0x3f, 0xff, 0x3f, 0x3f, 0xff, 0xff, 0x53, 0xff,
    0xff, 0xff, 0xff, 0xff, 0x3b, 0xff, 0x9e, 0x7f, 0xff, 0xbf, 0x7f, 0xff, 0xfe, 0x37, 0xff,
    0xff, 0xff, 0xff, 0xff, 0x73, 0xff, 0xbe, 0xff, 0xff, 0x9f, 0x3f, 0xff, 0xff, 0x67, 0xff,
    0xff, 0xff, 0xff, 0xfe, 0x77, 0xff, 0x3c, 0xff, 0xff, 0xbf, 0x7f, 0xff, 0xff, 0xef, 0xff,
    0xff, 0xff, 0xff, 0xff, 0x67, 0xfe, 0x7d, 0xff, 0xff, 0x3f, 0x3f, 0xff, 0xff, 0xcf, 0xff,
    0xff, 0xff, 0xff, 0xfe, 0x6f, 0xfe, 0xf9, 0xff, 0xff, 0xbf, 0x7f, 0xff, 0xff, 0x9f, 0xff,
    0xff, 0xff, 0xff, 0xfe, 0xef, 0xfe, 0xfb, 0xff, 0xff, 0xbf, 0x3f, 0xff, 0xff, 0x8f, 0xff,
    0xff, 0xff, 0xff, 0xfc, 0xcf, 0xfc, 0xfb, 0xff, 0xff, 0x3f, 0x7f, 0xff, 0xff, 0xe3, 0xff,
    0xff, 0xff, 0xff, 0xfe, 0xdf, 0xf9, 0xf3, 0xff, 0xff, 0xbf, 0xff, 0xff, 0xff, 0xf3, 0xff,
    0xff, 0xff, 0xff, 0xfc, 0xdf, 0xbb, 0xf7, 0xff, 0xff, 0x3f, 0xff, 0xff, 0xff, 0xe7, 0xff,
    0xff, 0xff, 0xff, 0xfd, 0x9e, 0x1b, 0xe7, 0xff, 0xff, 0x7f, 0xff, 0xff, 0xff, 0x9f, 0xff,
    0xff, 0xff, 0xff, 0xfc, 0xdc, 0x03, 0xea, 0xff, 0xff, 0x3f, 0xff, 0xff, 0xff, 0x9f, 0xff,
    0xff, 0xff, 0xff, 0xfd, 0x9c, 0x07, 0xe0, 0x7f, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0x3f, 0xff,
    0xff, 0xff, 0xff, 0xfc, 0xbc, 0x07, 0xc0, 0x7f, 0xff, 0x7f, 0xff, 0xff, 0xff, 0x83, 0xff,
    0xff, 0xff, 0xff, 0xfd, 0xba, 0x07, 0xc0, 0x7f, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xb3, 0xff,
    0xff, 0xef, 0xff, 0xfc, 0xb8, 0x07, 0xc0, 0x3f, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xf7, 0xff,
    0xfe, 0x00, 0x5f, 0xfd, 0xb8, 0x0f, 0xc0, 0x7f, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xf3, 0xff,
    0xf8, 0xa9, 0x0f, 0xfc, 0xb8, 0x0f, 0x83, 0xff, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xe7, 0xff,
    0xf2, 0xad, 0x43, 0xfd, 0x98, 0x0f, 0x80, 0xff, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xcf, 0xff,
    0xe5, 0x6a, 0xb0, 0x7c, 0xbc, 0x1f, 0x80, 0xff, 0xf9, 0xff, 0xff, 0xff, 0xff, 0x9f, 0xff,
    0xe6, 0xad, 0xdc, 0x3e, 0xbf, 0xc0, 0x81, 0xff, 0xfd, 0xff, 0xff, 0xff, 0xff, 0x3f, 0xff,
    0xea, 0xd5, 0x57, 0x8c, 0x9e, 0x04, 0x01, 0xff, 0xf9, 0xff, 0xff, 0xff, 0xff, 0x7f, 0xff,
    0xe5, 0x56, 0xa9, 0x42, 0x90, 0x76, 0x27, 0xff, 0xf3, 0xff, 0xff, 0xff, 0xff, 0x3f, 0xff,
    0xf3, 0x41, 0x56, 0xb0, 0x05, 0x95, 0x9f, 0xff, 0xf7, 0xff, 0xff, 0xff, 0xfe, 0x7f, 0xff,
    0xf1, 0x50, 0xb5, 0x5c, 0x7a, 0xda, 0x9f, 0xff, 0xf3, 0xff, 0xff, 0xff, 0xfe, 0xff, 0xff,
    0xf8, 0xae, 0x0d, 0xa5, 0x2b, 0x55, 0x4f, 0xff, 0xe7, 0xff, 0xff, 0xff, 0xfe, 0x7f, 0xff,
    0xfe, 0x35, 0x45, 0x5a, 0x8a, 0xab, 0x4f, 0xff, 0xef, 0xff, 0xff, 0xff, 0xfc, 0xff, 0xff,
    0xff, 0x82, 0xa1, 0x6b, 0x0d, 0x5a, 0xe7, 0xff, 0xcf, 0xff, 0xff, 0xff, 0xf9, 0xff, 0xff,
    0xff, 0xe8, 0xd8, 0xad, 0xc5, 0xab, 0x23, 0xff, 0xdf, 0xff, 0xff, 0xff, 0xfb, 0xff, 0xff,
    0xff, 0xfe, 0x2c, 0x55, 0x62, 0xb5, 0xb1, 0xff, 0x9f, 0xff, 0xff, 0xff, 0xf3, 0xff, 0xff,
    0xff, 0xff, 0x8b, 0x1a, 0xb2, 0xd6, 0xac, 0xff, 0xbf, 0xff, 0xff, 0xff, 0xe7, 0xff, 0xff,
    0xff, 0xff, 0xe2, 0x8a, 0xa9, 0x5a, 0xb4, 0x7f, 0x9f, 0xff, 0xff, 0xff, 0xef, 0xff, 0xff,
    0xff, 0xff, 0xf1, 0x46, 0xa8, 0xaa, 0xd6, 0x1f, 0x3f, 0xff, 0xff, 0xff, 0xcf, 0xff, 0xff,
    0xff, 0xff, 0xfc, 0xe2, 0xd4, 0xaa, 0xab, 0x8e, 0x7f, 0xff, 0xff, 0xff, 0x9f, 0xff, 0xff,
    0xff, 0xff, 0xfe, 0x31, 0x5e, 0x5b, 0x54, 0xc0, 0xfd, 0x40, 0x03, 0xff, 0x3f, 0xff, 0xff,
    0xff, 0xff, 0xff, 0x18, 0xa8, 0x6a, 0xb6, 0xb4, 0x00, 0x0a, 0x40, 0x7c, 0x7f, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xc6, 0x2b, 0x55, 0x55, 0x5b, 0x55, 0xb5, 0xbd, 0x1c, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xc4, 0x2d, 0x56, 0xda, 0xd5, 0x56, 0xd6, 0xa5, 0x41, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xf2, 0x0a, 0xda, 0xab, 0x55, 0x5a, 0xaa, 0xb6, 0xa3, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xf8, 0x86, 0xab, 0x55, 0x6d, 0xaa, 0xb5, 0x5a, 0xb3, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xfc, 0x41, 0x55, 0x6d, 0xaa, 0xb5, 0x00, 0x0a, 0xd9, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xf9, 0x09, 0x6d, 0xaa, 0xaa, 0xc8, 0x2a, 0x83, 0x49, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xe0, 0x20, 0x55, 0x55, 0x5b, 0x02, 0xd5, 0x70, 0x74, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xe5, 0x10, 0x1a, 0xb6, 0xd0, 0x2d, 0x5b, 0x5a, 0x14, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0xc0, 0x83, 0x85, 0xaa, 0x02, 0xd2, 0xaa, 0xaa, 0xac, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0x8a, 0x12, 0xa0, 0x00, 0x55, 0x00, 0x05, 0x6b, 0x54, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0x94, 0x78, 0xda, 0x55, 0xa0, 0x7f, 0xc0, 0x2d, 0x69, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0x00, 0xfe, 0x55, 0xaa, 0x0f, 0xff, 0xdf, 0x05, 0xad, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0x29, 0xff, 0x14, 0x80, 0xff, 0xff, 0x1f, 0xe0, 0xb1, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0x23, 0xff, 0xa0, 0x3f, 0xff, 0xfe, 0x7f, 0xfc, 0x03, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xfe, 0x0f, 0xe8, 0xaf, 0x7f, 0xff, 0xf8, 0xff, 0xff, 0xaf, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0x1d, 0x05, 0x00, 0x7f, 0xff, 0xf3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xfe, 0x30, 0xff, 0xfc, 0xff, 0xff, 0xc7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0x47, 0x2f, 0xfd, 0xff, 0xff, 0x81, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xff, 0x18, 0x01, 0xf9, 0xff, 0xfe, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xfc, 0x71, 0x48, 0x73, 0xff, 0xfc, 0x10, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xfd, 0xc4, 0x22, 0x67, 0xff, 0xf8, 0x40, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xf1, 0x82, 0x94, 0x0f, 0xff, 0xf0, 0x04, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xf3, 0x14, 0xa2, 0x3f, 0xff, 0xe1, 0x10, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0xe7, 0x22, 0x14, 0x12, 0x17, 0xc0, 0x41, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xff, 0x4e, 0x15, 0x48, 0x00, 0x01, 0x82, 0x04, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xf8, 0x00, 0x48, 0xa0, 0x41, 0x50, 0x08, 0x00, 0x47, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xf1, 0x20, 0xa5, 0x00, 0x0a, 0x4a, 0x00, 0x91, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xc4, 0x95, 0x10, 0x00, 0x21, 0x21, 0x10, 0x00, 0x13, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xfa, 0x82, 0x48, 0xa5, 0x00, 0x94, 0x94, 0x82, 0x20, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff,
    0x00, 0x15, 0x25, 0x10, 0x21, 0x4a, 0x4a, 0x00, 0x05, 0x41, 0xff, 0xff, 0xff, 0xff, 0xff,
    0x00, 0x10, 0x92, 0x48, 0x02, 0x21, 0x21, 0x05, 0x7f, 0xfa, 0x7f, 0xff, 0xff, 0xff, 0xff,
    0x02, 0x0a, 0x49, 0x20, 0xa1, 0x4a, 0x94, 0xbb, 0xf6, 0xde, 0x7f, 0xff, 0xff, 0xff, 0xff,
    0x20, 0x85, 0x24, 0x81, 0x04, 0x24, 0x4a, 0x2f, 0xbf, 0xfb, 0x3f, 0xff, 0xff, 0xff, 0xff,
    0x08, 0x00, 0x92, 0x02, 0x05, 0x52, 0x90, 0x7e, 0xf7, 0x6f, 0x9f, 0xff, 0xff, 0xff, 0xff,
    0x21, 0x10, 0x00, 0x10, 0x89, 0x08, 0x4a, 0x77, 0xdd, 0xff, 0xcf, 0xff, 0xff, 0xff, 0xff,
    0x00, 0x00, 0x00, 0x40, 0x04, 0xa5, 0x21, 0xde, 0xff, 0xbb, 0x67, 0xff, 0xff, 0xff, 0xff,
    0x08, 0x89, 0x24, 0x00, 0x12, 0x52, 0x83, 0x7b, 0xee, 0xff, 0xe7, 0xff, 0xff, 0xff, 0xff,
    0x22, 0x20, 0x01, 0x02, 0xa9, 0x08, 0x1f, 0xff, 0xbf, 0xed, 0xb9, 0xff, 0xff, 0xff, 0xff
    Serial.begin (9600);
    mylcd.Init_LCD();
    Serial.println ();
    Serial.println ("Hello! SSD1283A 130*130 Donald Duck 120x120 pix 8bit image");
    Serial.println ("on Arduino Uno - Nano");
    Serial.println ("in setup print screen 0x07E0");
    mylcd.Fill_Screen (MAGENTA);
    drawBitmap(5, 5, duck_120_bitmap, 120, 120, WHITE, BLACK);   // draw the bitmap on the TFT display
    Serial.println ("in loop drawing 120x120 Duck bitmap");
 //   drawBitmap(5, 5, duck_120_bitmap, 120, 120, WHITE, BLACK);   // draw the bitmap on the TFT display
  //  mylcd.Fill_Screen (MAGENTA);
// ==================== subroutines ===================
void showbgd(int x, int y, const uint8_t *bmp, int w, int h, uint16_t color, uint16_t bg, uint8_t pad = 7)
    int yy, xx;
    uint8_t first = 1, RVS = pad & 0x80;
    uint16_t pixel;
    pad &= 31;
    uint16_t wid = (w + pad) & ~pad;                    //bits per row
    //tft.setAddrWindow(x, y, x + w - 1, y + h - 1); //
    mylcd.Set_Addr_Window(x, y, x + w - 1, y + h - 1); //
    for (yy = 0; yy < h; yy++) {
        uint32_t ofs = (RVS ? (h - yy - 1) : yy) * wid; //bit offset
        const uint8_t *p = bmp + (ofs >> 3);            //flash address
        uint8_t mask = 0x80 >> (ofs & 7);               //bit mask
        uint8_t c = pgm_read_byte(p++);
        for (xx = 0; xx < w; xx++) {
            if (mask == 0) {
                mask = 0x80;
            pixel = (c & mask) ? color : bg;
            //tft.pushColors(&pixel, 1, first);
            mylcd.Push_Any_Color(&pixel, 1, first, 0);
            first = 0;
            mask >>= 1;
    //tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1);
    mylcd.Set_Addr_Window(0, 0, mylcd.Get_Width() - 1, mylcd.Get_Height() - 1);
void drawBitmap(int16_t x, int16_t y, const uint8_t bitmap[], int16_t w, int16_t h, uint16_t color, uint16_t bg)
    showbgd(x, y, bitmap, w, h, color, bg, 7);
}e code here
Hi! Thanks for the code. sorry for the late reply, was busy settling the mechanical stuff for this project.
i dont quite understand this line.
im following this pin format
so could you show me how to change to match my configuration? Thanks a bunch
i have zero experience in this..
Hello floris
I tried your code on my nano, but all white screen, do you have any idea where can gos wrong?
Hi yhongz,
Thank you for your question. Are you referring to https://thesolaruniverse.wordpress.com/2020/02/14/1074/ ??
My questions to you to help you solve the problem are
-- what kind of display are you showing: a 130130 or a 240240 TFT? The pin location suggests that it is a 130*130 TFI display.
-- what is the display's controller chiop? A SSD1283A or something else?
-- can you give me a diagram which pins of the Nano are wired towchich pins of the TFT breakout.
-- are you using the correct libraries?
-- please send the sketch you are using.
regards, Floris Wouterlood, aka Photoncatcher
Hello Floris:
After some self modeify, I have successfuly displayed your pic!!!!!!!!
I am actually a beginner and your site is very useful to me, thanks for your effort
but I also have some questings here wanna ask
1. which pic to code tool you used? it's there any specific settings that I need to pay attention?
2. What's the usage of the "showbgd" function in the last part?
For your convenience I have paste your code below as reference
   #define MODEL SSD1283A
   #define CS   7
   #define CD   9
   #define SDA  A2   //if you use the hardware spi,this pin is no need to set
   #define SCK  A1   //if you use the hardware spi,this pin is no need to set
   #define RST  6
   #define LED  A3
   LCDWIKI_SPI mylcd(MODEL,CS,CD,-1,SDA,RST,SCK,LED);
    mylcd.Init_LCD();
    Serial.println ();
    int yy, xx;
    uint16_t pixel;
    pad &= 31;
            if (mask == 0) {
                mask = 0x80;
            first = 0;
            mask >>= 1;
Hi yhongz,
I love that picture. I created it myself (in color) by re-drawing from a Donald Duck strip and it was one of the the first that i managed to code as an 8-bit picture in .h format. Afterwards I reserached into fuIl 16-bit color for Arduino TFT displays (Arduino supports 16-bit color but not 24-bit color. I should go through my archived files to check what i exactly did with the DonaldDuck dithered B/W picture. I will post you somewhere this week.
Rgards, Floris Wouterlood - The Netherlands
| yhongz
March 4 |
Hello Floris:
IMG_0815 2.HEIC
   #define CS   7
   #define CD   9
   #define RST  6
   #define LED  A3
    mylcd.Init_LCD();
    Serial.println ();
    int yy, xx;
    uint16_t pixel;
    pad &= 31;
            if (mask == 0) {
                mask = 0x80;
            first = 0;
            mask >>= 1;
