My go kart's 2-speed transmission can shift with either a pneumatics system, or a servo. Using either I would like to have paddle shifters (like a formula 1 car) and I was hoping someone could give some insight on which is better for physically shifting, and how to build the paddles + code for them (Using RobotOpen protocol RobotOpen Documentation — RobotOpen 1.0 documentation )
Simple button code for moving a servo.
//zoomkat servo button test 12-29-2011
#include <Servo.h>
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
int button2 = 5; //button pin, connect to ground to move servo
int press2 = 0;
Servo servo1;
pinMode(button1, INPUT);
pinMode(button2, INPUT);
servo1.attach(7);
digitalWrite(4, HIGH); //enable pullups to make pin high
digitalWrite(5, HIGH); //enable pullups to make pin high
press1 = digitalRead(button1);
if (press1 == LOW)
servo1.write(170);
press2 = digitalRead(button2);
if (press2 == LOW)
servo1.write(10);
I don't know about your gearbox, but I would add a "throttle closed?" line before I actually move the servo in any direction. Otherwise you might shift under full load.
You would need a NO-pushbutton ( or magnet/reedrelais combo) at the throttle, that closes when the pedal is in idle position.
press1 = digitalRead(button2);
throttle = digitalRead(reed-relais);
if (press1 == LOW && throttle == LOW)
servo1.write(170);
if (press2 == LOW && throttle ==LOW)
servo1.write(10);
