Hi I would like to generate several freq of PWM signals with varying Duty cycles. The Frequency/Duty values are given by Python code (transmitting through serially UART-Pyserial.
I am sharing the code of Python here. I would like to request you to build an Arduino code that can accept values(read values) from Python serially and then generate PWM freq and duty cycle. Please suggest the arduino code.
Python code:
def arduinosignal_default_setting(env):
duty = [x1,x2,x3,x3] # 4 elements (x1,x2,x3,x4 are integer values for different Duty)
frequency = [y1, y2, y3, y4] # 4 elements (y1,y2,y3,y4 are integer values for different Frequencies)
f_index = 0
f_length = len(frequency)
d_length = len(duty)
# First while loop to iterate over frequency array
while f_index < f_length:
# Get current frequency
f_value = frequency[f_index]
# Second while loop to iterate over duty array
d_index = 0
while d_index < d_length:
# Keep environment running and check measurements
env.multimeter_default_setting()
if env.mult_measure > 20:
# Skip this d_index value and continue with the next one
print(f"Skipping duty cycle {d_index} because measurement is {env.mult_measure} (greater than 20)")
d_index += 1
continue # Skip to the next iteration of the inner while loop
# Get current duty
d_value = duty[d_index]
# Simulate sending data to Arduino through serial
data_to_send = f"Frequency: {f_value}, Duty: {d_value}\n"
SerialObj = serial.Serial('COM6') # Ensure the correct port
SerialObj.baudrate = 9600
SerialObj.bytesize = 8
SerialObj.parity = 'O'
SerialObj.stopbits = 1
SerialObj.timeout = None
TransmitString = SerialObj.write(data_to_send.encode())
print(f"Sent -> {data_to_send.strip()}")
ReceivedString = SerialObj.readline().decode()
print(f"Received -> {ReceivedString.strip()}")
d_index += 1 # Increment the duty index
time.sleep(0.1) # Delay between operations
# Increment the frequency index after processing all duty cycles
f_index += 1
SerialObj.close()
The Arduino code would depend on which Arduino you have.
Furthermore, there are severe limitations on the possible frequencies and duty cycles, also depending on which Arduino you have, so you will need to do a bit more research on the topic.
If you would like someone to write code for you, post on the Jobs and Paid Collaboration forum section.
In Arduino, the frequency and duty cycle of PWM (Pulse Width Modulation) signals can be adjusted using various timers and settings, depending on the pins you are working with. Below, I will outline the general concepts and formulas for setting the frequency and duty cycle on an Arduino UNO.
PWM Frequency and Duty Cycle on Arduino UNO
The Arduino UNO uses Timer0, Timer1, and Timer2 to generate PWM signals on different pins. Each timer has different default settings and capabilities.
1. Frequency Calculation:
The frequency of the PWM signal depends on the clock speed of the microcontroller and the settings of the timer's prescaler and TOP value. The general formula for calculating the PWM frequency is:
PWM Value: The value set using analogWrite(). For an 8-bit timer, this can range from 0 to 255.
TOP: For an 8-bit timer, this is 255 by default.
Example: Setting PWM Frequency and Duty Cycle on Arduino UNO
Here's an example of how to adjust the frequency and duty cycle using Timer1, which controls pins 9 and 10.
// Set pin 9 as output
pinMode(9, OUTPUT);
// Set Timer1 to Fast PWM mode, 8-bit
TCCR1A = _BV(WGM10) | _BV(COM1A1);
TCCR1B = _BV(WGM12) | _BV(CS11); // Set prescaler to 8
// Set Duty Cycle: 50%
OCR1A = 128; // 50% of 255
// Nothing needed here; PWM is handled by Timer1
Explanation of the Example:
TCCR1A and TCCR1B: These registers configure Timer1's mode and prescaler.
_BV(WGM10) and _BV(WGM12): Set Timer1 to Fast PWM, 8-bit mode.
_BV(CS11): Sets the prescaler to 8.
OCR1A = 128;: Sets the duty cycle to 50% (128/255).
Key Points:
Changing the prescaler will affect the frequency.
Adjusting OCR1A will change the duty cycle.
Using these formulas and adjusting the timer registers will allow you to set the PWM frequency and duty cycle on the Arduino UNO according to your requirements.
