Hello
Pour un petit projet, je cherche à détecter le déplacement d'un objet.
Je suis suis procuré un MPU-6050.
Je l'ai branché à mon arduino UNO, et j'ai utilisé cette exemple:
// MPU-6050 Short Example Sketch
// By Arduino User JohnChi
// August 17, 2014
// Public Domain
#include<Wire.h>
const int MPU_addr=0x68; // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
void loop(){
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Serial.print("AcX = "); Serial.print(AcX);
Serial.print(" | AcY = "); Serial.print(AcY);
Serial.print(" | AcZ = "); Serial.print(AcZ);
Serial.print(" | Tmp = "); Serial.print(Tmp/340.00+36.53); //equation for temperature in degrees C from datasheet
Serial.print(" | GyX = "); Serial.print(GyX);
Serial.print(" | GyY = "); Serial.print(GyY);
Serial.print(" | GyZ = "); Serial.println(GyZ);
delay(333);
Trouver ici:
http://playground.arduino.cc/Main/MPU-6050#short
Sa marche nikel, j'ai bien les valeurs dans mon terminal série:
AcX = -7692 | AcY = 8896 | AcZ = -12668 | Tmp = 25.71 | GyX = -155 | GyY = -331 | GyZ = -146
AcX = -7680 | AcY = 8940 | AcZ = -12608 | Tmp = 25.61 | GyX = -118 | GyY = -289 | GyZ = -91
AcX = -7696 | AcY = 8984 | AcZ = -12568 | Tmp = 25.66 | GyX = -103 | GyY = -320 | GyZ = -145
AcX = -7820 | AcY = 8948 | AcZ = -12700 | Tmp = 25.71 | GyX = -111 | GyY = -293 | GyZ = -122
Je bloque sur la gestion des valeurs, je pense qu'il faut que j'utilise les valeurs en A (pour accélération ? )
Mais suivant comment mon objet est posé, les valeurs changes.
Merci de votre aide !!!!
