getting AT command on serial monitor while using gsm 900A
hello ,
i am getting AT command on serial monitor screen while i am using gsm 900A with arduino
what would be problem please help me!!!
Post code.
Use code tags.
here
direct.ino (4.02 KB)
See reply #1
#include <SoftwareSerial.h>
SoftwareSerial gps(10,11); // RX, TX
//String str="";
char str[70];
String gpsString="";
char *test="$GPGGA";
String latitude="No Range ";
String longitude="No Range ";
int temp=0,i;
boolean gps_status=0;
//lcd.begin(16,2);
gps.begin(9600);
Serial.println("Vehicle Tracking");
//lcd.setCursor(0,1);
Serial.println(" System ");
delay(2000);
gsm_init();
//lcd.clear();
Serial.println("AT+CNMI=2,2,0,0,0");
Serial.println("GPS Initializing");
Serial.println(" No GPS Range ");
get_gps();
delay(2000);
//lcd.clear();
Serial.println("GPS Range Found");
Serial.println("GPS is Ready");
delay(2000);
//lcd.clear();
Serial.println("System Ready");
temp=0;
serialEvent();
if(temp)
get_gps();
tracking();
void serialEvent()
while(Serial.available())
if(Serial.find("Track Vehicle"))
temp=1;
temp=0;
void gpsEvent()
gpsString="";
while(1)
while (gps.available()>0) //checking serial data from GPS
char inChar = (char)gps.read();
gpsString+= inChar; //store data from GPS into gpsString
i++;
if (i < 7)
if(gpsString[i-1] != test[i-1]) //checking for $GPGGA sentence
i=0;
gpsString="";
if(inChar=='\r')
if(i>65)
gps_status=1;
i=0;
if(gps_status)
void gsm_init()
// lcd.clear();
Serial.println("Finding Module..");
boolean at_flag=1;
while(at_flag)
Serial.println("AT");
while(Serial.available()>0)
if(Serial.find("OK"))
at_flag=0;
//lcd.clear();
Serial.println("Module Connected..");
//lcd.clear();
Serial.println("Disabling ECHO");
boolean echo_flag=1;
while(echo_flag)
Serial.println("ATE0");
echo_flag=0;
//lcd.clear();
Serial.println("Echo OFF");
//lcd.clear();
Serial.println("Finding Network..");
boolean net_flag=1;
while(net_flag)
Serial.println("AT+CPIN?");
if(Serial.find("+CPIN: READY"))
net_flag=0;
//lcd.clear();
Serial.println("Network Found..");
//lcd.clear();
void get_gps()
gps_status=0;
int x=0;
while(gps_status==0)
gpsEvent();
int str_lenth=i;
latitude="";
longitude="";
int comma=0;
while(x<str_lenth)
if(gpsString[x]==',')
comma++;
if(comma==2) //extract latitude from string
latitude+=gpsString[x+1];
else if(comma==4) //extract longitude from string
longitude+=gpsString[x+1];
x++;
int l1=latitude.length();
latitude[l1-1]=' ';
l1=longitude.length();
longitude[l1-1]=' ';
//lcd.clear();
Serial.println("Lat:");
Serial.print("latitude");
// lcd.setCursor(0,1);
Serial.print("Long:");
Serial.print("longitude");
i=0;x=0;
str_lenth=0;
delay(2000);
void init_sms()
Serial.println("AT+CMGF=1");
delay(400);
Serial.println("AT+CMGS="+91**********""); // use your 10 digit cell no. here
delay(400);
void send_data(String message)
Serial.println(message);
delay(200);
void send_sms()
Serial.write(26);
//void lcd_status()
// lcd.clear();
// lcd.print("Message Sent");
// delay(2000);
// lcd.clear();
// lcd.print("System Ready");
// return;
void tracking()
init_sms();
send_data("Vehicle Tracking Alert:");
send_data("Your Vehicle Current Location is:");
Serial.print("Latitude:");
send_data(latitude);
Serial.print("Longitude:");
send_data(longitude);
send_data("Please take some action soon..\nThankyou");
send_sms();
delay(2000);
// lcd_status();
i have solved this problem .
but another problem is that my gps is not working
how can i find the problem?
kju:
How did you solve the problem?
