What will you do with the quaternion?
This code works fine but with the MPU-6050, which has no North reference, the yaw value is relative to the starting orientation and will drift. Be sure to calibrate the gyro.
Note that if you print out the quaternion values every pass through loop, the gyro integration will probably fail and introduce large errors into the orientation.
// MPU-6050 Mahony IMU (yaw angle is relative to starting orientation)
// last update 7/9/2020
#include "Wire.h"
// AD0 low = 0x68 (default for Sparkfun module)
// AD0 high = 0x69
int MPU_addr = 0x68;
// vvvvvvvvvvvvvvvvvv VERY VERY IMPORTANT vvvvvvvvvvvvvvvvvvvvvvvvvvvvv
//These are the previously determined offsets and scale factors for accelerometer and gyro for
// a particular example of an MPU-6050. They are not correct for other examples.
//The IMU code will NOT work well or at all if these are not correct
float A_cal[6] = {265.0, -80.0, -700.0, 0.994, 1.000, 1.014}; // 0..2 offset xyz, 3..5 scale xyz
float G_off[3] = { -499.5, -17.7, -82.0}; //raw offsets, determined for gyro at rest
#define gscale ((250./32768.0)*(PI/180.0)) //gyro default 250 LSB per d/s -> rad/s
// ^^^^^^^^^^^^^^^^^^^ VERY VERY IMPORTANT ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
// GLOBALLY DECLARED, required for Mahony filter
// vector to hold quaternion
float q[4] = {1.0, 0.0, 0.0, 0.0};
// Free parameters in the Mahony filter and fusion scheme,
// Kp for proportional feedback, Ki for integral
float Kp = 30.0;
float Ki = 0.0;
// with MPU-9250, angles start oscillating at Kp=40. Ki does not seem to help and is not required.
// with MPU-6050, some instability observed at Kp=100 Now set to 30.
// char s[60]; //snprintf buffer, if needed
// globals for AHRS loop timing
unsigned long now_ms, last_ms = 0; //millis() timers
// print interval
unsigned long print_ms = 200; //print angles every "print_ms" milliseconds
float yaw, pitch, roll; //Euler angle output
Wire.begin();
Serial.println("starting");
// initialize sensor
// defaults for gyro and accel sensitivity are 250 dps and +/- 2 g
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
// AHRS loop
static int i = 0;
static float deltat = 0; //loop time in seconds
static unsigned long now = 0, last = 0; //micros() timers
//raw data
int16_t ax, ay, az;
int16_t gx, gy, gz;
int16_t Tmp; //temperature
//scaled data as vector
float Axyz[3];
float Gxyz[3];
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr, 14, true); // request a total of 14 registers
int t = Wire.read() << 8;
ax = t | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
ay = t | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
az = t | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp = t | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
gx = t | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
gy = t | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
gz = t | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Axyz[0] = (float) ax;
Axyz[1] = (float) ay;
Axyz[2] = (float) az;
//apply offsets and scale factors from Magneto
for (int i = 0; i < 3; i++) Axyz[i] = (Axyz[i] - A_cal[i]) * A_cal[i + 3];
Gxyz[0] = ((float) gx - G_off[0]) * gscale; //250 LSB(d/s) default to radians/s
Gxyz[1] = ((float) gy - G_off[1]) * gscale;
Gxyz[2] = ((float) gz - G_off[2]) * gscale;
// snprintf(s,sizeof(s),"mpu raw %d,%d,%d,%d,%d,%d",ax,ay,az,gx,gy,gz);
// Serial.println(s);
now = micros();
deltat = (now - last) * 1.0e-6; //seconds since last update
last = now;
Mahony_update(Axyz[0], Axyz[1], Axyz[2], Gxyz[0], Gxyz[1], Gxyz[2], deltat);
// Compute Tait-Bryan angles.
// In this coordinate system, the positive z-axis is down toward Earth.
// Yaw is the angle between Sensor x-axis and Earth magnetic North
// (or true North if corrected for local declination, looking down on the sensor
// positive yaw is counterclockwise, which is not conventional for NED navigation.
// Pitch is angle between sensor x-axis and Earth ground plane, toward the
// Earth is positive, up toward the sky is negative. Roll is angle between
// sensor y-axis and Earth ground plane, y-axis up is positive roll. These
// arise from the definition of the homogeneous rotation matrix constructed
// from quaternions. Tait-Bryan angles as well as Euler angles are
// non-commutative; that is, the get the correct orientation the rotations
// must be applied in the correct order which for this configuration is yaw,
// pitch, and then roll.
// http://en.wikipedia.org/wiki/Conversion_between_quaternions_and_Euler_angles
// which has additional links.
roll = atan2((q[0] * q[1] + q[2] * q[3]), 0.5 - (q[1] * q[1] + q[2] * q[2]));
pitch = asin(2.0 * (q[0] * q[2] - q[1] * q[3]));
//conventional yaw increases clockwise from North. Not that the MPU-6050 knows where North is.
yaw = -atan2((q[1] * q[2] + q[0] * q[3]), 0.5 - (q[2] * q[2] + q[3] * q[3]));
// to degrees
yaw *= 180.0 / PI;
if (yaw < 0) yaw += 360.0; //compass circle
pitch *= 180.0 / PI;
roll *= 180.0 / PI;
now_ms = millis(); //time to print?
if (now_ms - last_ms >= print_ms) {
last_ms = now_ms;
// print angles for serial plotter...
// Serial.print("ypr ");
Serial.print(yaw, 0);
Serial.print(", ");
Serial.print(pitch, 0);
Serial.print(", ");
Serial.println(roll, 0);
// Mahony scheme uses proportional and integral filtering on
// the error between estimated reference vector (gravity) and measured one.
// Madgwick's implementation of Mayhony's AHRS algorithm.
// See: http://www.x-io.co.uk/node/8#open_source_ahrs_and_imu_algorithms
// Date Author Notes
// 29/09/2011 SOH Madgwick Initial release
// 02/10/2011 SOH Madgwick Optimised for reduced CPU load
// last update 07/09/2020 SJR minor edits
// IMU algorithm update
void Mahony_update(float ax, float ay, float az, float gx, float gy, float gz, float deltat) {
float recipNorm;
float vx, vy, vz;
float ex, ey, ez; //error terms
float qa, qb, qc;
static float ix = 0.0, iy = 0.0, iz = 0.0; //integral feedback terms
float tmp;
// Compute feedback only if accelerometer measurement valid (avoids NaN in accelerometer normalisation)
tmp = ax * ax + ay * ay + az * az;
if (tmp > 0.0)
// Normalise accelerometer (assumed to measure the direction of gravity in body frame)
recipNorm = 1.0 / sqrt(tmp);
ax *= recipNorm;
ay *= recipNorm;
az *= recipNorm;
// Estimated direction of gravity in the body frame (factor of two divided out)
vx = q[1] * q[3] - q[0] * q[2];
vy = q[0] * q[1] + q[2] * q[3];
vz = q[0] * q[0] - 0.5f + q[3] * q[3];
// Error is cross product between estimated and measured direction of gravity in body frame
// (half the actual magnitude)
ex = (ay * vz - az * vy);
ey = (az * vx - ax * vz);
ez = (ax * vy - ay * vx);
// Compute and apply to gyro term the integral feedback, if enabled
if (Ki > 0.0f) {
ix += Ki * ex * deltat; // integral error scaled by Ki
iy += Ki * ey * deltat;
iz += Ki * ez * deltat;
gx += ix; // apply integral feedback
gy += iy;
gz += iz;
// Apply proportional feedback to gyro term
gx += Kp * ex;
gy += Kp * ey;
gz += Kp * ez;
// Integrate rate of change of quaternion, q cross gyro term
deltat = 0.5 * deltat;
gx *= deltat; // pre-multiply common factors
gy *= deltat;
gz *= deltat;
qa = q[0];
qb = q[1];
qc = q[2];
q[0] += (-qb * gx - qc * gy - q[3] * gz);
q[1] += (qa * gx + qc * gz - q[3] * gy);
q[2] += (qa * gy - qb * gz + q[3] * gx);
q[3] += (qa * gz + qb * gy - qc * gx);
// renormalise quaternion
recipNorm = 1.0 / sqrt(q[0] * q[0] + q[1] * q[1] + q[2] * q[2] + q[3] * q[3]);
q[0] = q[0] * recipNorm;
q[1] = q[1] * recipNorm;
q[2] = q[2] * recipNorm;
q[3] = q[3] * recipNorm;
