Greetings, I am new to Arduino, I want to set up a small setup for home use.
The basic Use case is
There is a Small Water Tank at ground level that get supply of water once during the day, and then there is a bigger water tank on the roof of the house (2 story house) that we use a motor to pump water up to when we get water supplied to the ground level tank.
What I want to do, is use 3 Float Valve Switches (something like this one) to control the motor using an arduino. Basically when there is water above a certain threshold in water tank on the ground level and water is below a certain level in the tank on the roof we turn on the motor. And if water corsses a certain level (fills the tank) on the tank above or drops below a certain level on the tank on ground floor ( ground floor tank is about to be empty) we turn off the motor.
Now from my research I know I need 3 Float valve Switches which send signals to the arduino (planning to use a nano for the project) based on the state of these switches (easy if else code ) I want to send a signal to a relay (like this one) to turn on the motor and then cut off the signal when the right condition is met.
From my research, I should connect the switches to input pins using a Pull Down resister or the Internal Pull up resistor (based on this article) but from what I have read this also results in problem if the wire is too long.
Considering the switches will be quite a distance from the arduino (specially the one on the roof water tank) we will end up with 25-30 ft of wire if not more. The noise on this will most probably cause a lot of issues.
What are good solutions here considering insulating the wire isnt an option.
What if I used two Arduino, one on the roof for the Float valve on the roof, and a relay so we send a 220v signal down that can then act as an input to the arduino on the ground (via a reverse relay ?).
Some one suggested using 2 arduino and suing Xbee for wireless communication but Xbee modules are expensive and I am looking for a cheap solution
I am completely blank here and any help
Thanks ![]()
