Got the boards, no WiFi antenna. What gives?
Hmmmm! it sounds like you have a pile of parts that will probably not do anything but burn energy.
I moved your topic to an appropriate forum category @doughpatterson.
In the future, when creating a topic please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Hi @doughpatterson. Please check the packaging of the GIGA R1 WiFi board carefully. An antenna is included with the board:
Note that the antenna has a very minimalistic physical form factor, so it might be easy to miss if you don't look carefully.
If you verify that the antenna was not included in the Arduino GIGA Display Bundle you received, then contact Arduino customer service via this form:
