@ZinggJM
I have been trying to get the GDEW0213Z16 to run. You list your library as supporting so I assume i am not at the completely wrong address.
I am just very very confused on the pins ?
I am using a nodeMCU V1.0 so essentially i am using an ESP8266
so i assume this line is the one i am looking for:
``` GxEPD2_BW<GxEPD2_213_flex, GxEPD2_213_flex::HEIGHT> display(GxEPD2_213_flex(/*CS=D8*/ SS, /*DC=D3*/ 0, /*RST=D4*/ 2, /*BUSY=D2*/ 4)); // GDEW0213I5F ```
But then again I am really not sure as the last view characters don't match up, I have found the full name of the display used in the library but couldn't backtrack what pins to use from that point.
I am trying to run the whole thing via the GDE021/DESTM32-S2 display driver, for which you have made a small text with the pinout (and jumper position) and marked the display down as "usable" with this driver.
Though when it comes to connecting i am completely lost:
This is your message i am tralking about:
DESTM32-S2 pinout (top, component side view):
| VCC |o o| VCC 5V
| GND |o o| GND
| 3.3 |o o| 3.3V
| nc |o o| nc
| nc |o o| nc
| nc |o o| nc
| MOSI |o o| CLK
| DC |o o| D/C
| RST |o o| BUSY
| nc |o o| BS
CS = D8 ... What CS?
From what i could gather there is no CS? (chip select), or did the name change? Can't find anything with the instructions from good displays either. CS from the NodeMCU? but what does D8 stand for ?
CD=D3, ok
3,3 to 3.3 and GND to GND, ok
RST = D4, OK
BUSY=D2 ,OK
BS = GND , you mentioned this somewhere, can't find it right now though
.... and the others? as it stands MOSI, CLK, D/C
If i try falling back onto some other instructions from waveshare or similar products, i don'T really know what to connect stuff to either because of this section:
// mapping suggestion from Waveshare SPI e-Paper to generic ESP8266
// BUSY -> GPIO4, RST -> GPIO2, DC -> GPIO0, CS -> GPIO15, CLK -> GPIO14, DIN -> GPIO13, GND -> GND, 3.3V -> 3.3V
// NOTE: connect 4.7k pull-down from GPIO15 to GND if your board or shield has level converters
// NOTE for ESP8266: using SS (GPIO15) for CS may cause boot mode problems, use different pin in case, or 4k7 pull-down
// mapping of Waveshare e-Paper ESP8266 Driver Board
// BUSY -> GPIO16, RST -> GPIO5, DC -> GPIO4, CS -> GPIO15, CLK -> GPIO14, DIN -> GPIO13, GND -> GND, 3.3V -> 3.3V
As i don't have GPIO and do not know the D# equivalent i am not sure what to do here.
I love your library and have tried reading into it more and the lib from Adafruit, but i can't even get the demo example (GxEPD2_Example.ino) to run anyways so playing around with it is nearly impossible.
Regards,
Zwei
