Waveshare e-paper displays with SPI
Topic created by Jean-Marc Zingg
Hi E-Paper Fans
Waveshare has extended their range of small e-papers with SPI interface.
These e-paper displays are quite easy to use, and Waveshare has wiki pages for them with complete information, schematics, pdf specification, and code example.
Be aware of the difference between e-papers and TFTs: update of e-papers is rather slow, ~1s, so they make sense for slowly changing information.
E-paper display keep showing the information when powered off, and consume little power on update.
This topic is related to topic Good Display ePaper for Arduino
links:
http://www.waveshare.com/wiki/1.54inch_e-Paper_Module
http://www.waveshare.com/wiki/2.13inch_e-Paper_HAT
The 1.54 and 2.13 inch Waveshare e-paper modules are also supported by my GxEPD library; they use the same e-paper displays (Dalian Good Display Inc.).
Added support for 2.9 inch e-paper display to GxEPD (GxGDEH029A1) and more.
IoT example wiring 1.54inch e-Paper to Wemos D1 Mini:
BUSY->D6(MISO), RST->D4, DC->D3, CS->D8(SS), CLK->D5(SCK), DIN->D7(MOSI), GND->GNG, 3.3V->3.3V
SHT_SCL->D1, SHT_SDA->D2, 5V->300k->A0, D0->0.1k->RST(deep sleep wakeup)
BUSY wired to MISO to free D2 for 2-wire SHT31
2.9inch example:
BUSY->D2, RST->D4, DC->D3, CS->D8(SS), CLK->D5(SCK), DIN->D7(MOSI), GND->GND, 3.3V->3.3V
This is great, thank you!
Would you care to make your code compatible with the ESP32 as well?
I just got my ESP-32, so this may happen after my short holidays.
I'm user from germany, i try your scetch for 1.54 E-paper on wemos and it is running very well, but i will use a german-font.
Did you have a link to the fontgenerator so i will make a german font and perhaps graphic
Best regards, Helmut
Hallo Helmut
I am also interested in German fonts, but have no experience so far. Maybe you could ask for help in the German section of the Forum. Or wait for a response from an expert.
Jean-Marc
Dear ZinggJM,
could you tell us more how to use 2.9inch Waveshare display with Arduino Nano/Uno. Let's leave 5V-3.3V voltage conversion issues.
I don't know pin assignments and library usage:/
I tried to figure out pinout shown in i.e. GxGDEH029A1.cpp file but it is for DESTM32-S2 connection board for STM32 system not for Arduino:/
Please put some light how to talk to WaveShare e-papers from Arduino.
One of the problems i found during compilation is that variable used to store screen resolution is uint8_t. 2.9inch screen has 296 x 128 pixels so 296 is greater that uint8_t can handle so overflow errors appeard. This is just one of the errors.
I will look at this when I am back home.
Just to be sure what you are referring to: GxEPD library or Waveshare library?
I have not yet tried to use the Waveshare library, as I use Adafruit_GFX.
But Arduino UNO has not enough RAM for full screen buffer, as used in my GxEPD.
As far as I have looked into the Waveshare code, they use a smaller (line-) buffer for text output.
bogus105:
Dear ZinggJM,
I have decided that I will look at your problems as soon as your post is more specific, more clearly stated, and more correct.
My code is generic as far as possible, with target processor specific default values for the constructor.
The DESTM32-S2 connection board is NOT STM32 specific, but its pinout matches the DESTM32-S1 STM32 demo board from Good Display.
Please state which uint8_t variable (name it!) you mean, and what other errors you refer to.
Thank you ZinggJM for your answer.
You're right there was no much details in my previous post. It was rather indication:)
The only progress i made so far after playing with various libraries was when i modified Waveshare 'string' example found here:
in arduino/string/ folder.
The following files are in this folder:
Display_Lib.h
EPD_drive.cpp
EPD_drive.h
EPD_drive_gpio.cpp
EPD_drive_gpio.h
string.ino
As you said: Nano doesn't have enough RAM for these files so i included
#include <avr/pgmspace.h>
in two files:
Display_Lib.h
EPD_drive.h
and then i changed big data tables like:
const unsigned char waveshare[4736] = {........ton of data....};
to
const unsigned char waveshare[4736] PROGMEM = {........ton of data....};
Now compilation is errorless.
Loaded things up to Nano and my progress is e-paper screen was cleared (waveshare logo that was on screen when i bought it disappeared).
No test text string was displayed.
On serial monitor i can see this:
------------Clear full screen-----------------
full init
*set register Start
send data :
send data :
send data :
send data :
send data :
send data :
send data :
send data :
send data :
send data :
*set register end
send data :
Busy is Low
full clear
send data :
send data :
------start send display data!!---------<<<<<<<
Busy is Low
send data1
Busy is Low
full over
*set register Start
send data :
send data :
send data :
send data :
send data :
send data :
send data :
send data :
send data :
send data :
*set register end
send data :
Busy is Low
po operacji clear full
--------------Clear part screen------------
*set register Start
send data :
send data :
send data :
send data :
send data :
send data :
send data :
send data :
send data :
send data :
*set register end
send data :
Busy is Low
send data :
send data :
send data :
send data :
Busy is Low
Busy is Low
send data :
send data :
send data :
send data :
Busy is Low
po czyszczeniu czesciowym ekranu
h
FFFFFFD5 FFFFFFD5 FFFFFFD5 FFFF
and so on. I seems Nano resets itself.
I wonder why BUSY line on display module is low?
The code part that checks this looks like this:
function:
read busy
unsigned char WaveShare_EPD::ReadBusy(void)
unsigned long i=0;
for(i=0;i<400;i++){
// println("isEPD_BUSY = %d\r\n",isEPD_CS);
if(isEPD_BUSY==EPD_BUSY_LEVEL) {
Serial.println("Busy is Low \r\n");
return 1;
driver_delay_xms(10);
return 0;
In for loop that you can see that during first loop execution BUSY line is compared with EPD_BUSY_LEVEL, if its true "Busy is Low" is printed and the whole ReadBusy procedure is terminated with " return 1; ".
Why this procedure returns 0 or 1 if it is not checked anywhere in the code whether 0 or 1 is returned?
Then i modified main program loop to check BUSY line status: it is LOW all the time. Maybe there is sth wrong with my module?
I checked BUSY line with multimeter and in fact it is 0 V almost all the time:/
I'm using modified Nano board for 3.3V operation. Brief description is here:
https://forum.arduino.cc/index.php?topic=491012.0
Hi bogus105
Please use code tags for code, "</>" at top left, it makes your post more pleasant to read.
You do not provide any info concerning errors, so I forget about those.
When you put data into PROGMEM, you need to read it with the corresponding read function; there are tutorials about this.
The BUSY line is active when the controller takes time for commands, e.g. on update to display.
I have not yet tried to use the Waveshare code; I may do this, but not with UNO or NANO to avoid the need for level converters or series resistors.
Jean-Marc
I may reconsider to try with UNO and NANO, as I just received level converters that I want to use anyway:
https://www.aliexpress.com/item/8-channel-level-conversion-module-two-way-conversion-between-3-3V-and-5V-IO-access-5V/32811827434.html
I think any Arduino UNO or NANO user should have some of those ready at hand, or some other make.
TeK32:
Yes, I did. I have updated GxEPD on GitHub.
bogus105:
http://www.waveshare.com/wiki/File:2.9inch_e-Paper_Module_code.7z
Display_Lib.h
EPD_drive.cpp
EPD_drive.h
EPD_drive_gpio.cpp
EPD_drive_gpio.h
string.ino
in two files:
Display_Lib.h
EPD_drive.h
to
I could compile the Waveshare string example successfully for Arduino UNO and NANO.
The waveshare array is referenced nowhere in the code, and therefore not included in the link process, at least with the actual Arduino IDE 1.8.3.
Do you use an older version of Arduino, or have you done other changes to the code?
I would just ignore your posts, but try to answer, so other users interested in these displays do not become insecure.
Hello
I would like to use the "waveshare" 1.54 inch screen with an arduino MKR Zero, do you think this is possible?
Are the changes to be made to your library important?
This should be simple. The device has 32kB RAM, so the ~5kB display buffer is no problem.
I need to fix the GxIO_SPI class for AVR and SAM or all non-ESP processors, and will add SAMD.
I will make sure it compiles with SAMD, and try to check it with my MKR-1000 (sitting idle in some drawer waiting to be used).
I can't promise a deadline, but should be ready in less than a week or so.
Thank you
No problem for the delai, it will be a pleasure to use your library when it is ready
Sorry i'm not writing everyday ZinggJM nut i'm at work and i can't read this forum every day:)
Youv'e said you compiled Waveshare string example on Uno/Nano with no issues.
How?
I use Arduino IDE 1.6.8
When attempt to compile original 'string.ino' example from waveshare i got error: global variables use 3 313 bytes (161%) od dynamic memory, leaving -1 265 bytes for local variables. Maxiumum is 2 048 bytes.
So 'string' exmple simply won't fit in Uno/Nano:/
I also tried to load an example from your library: GxEPD_SPI_TestExample
The following errors came up:
In file included from C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.cpp:31:0,
                 from C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master\examples\GxEPD_SPI_TestExample\GxEPD_SPI_TestExample.ino:37:
C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.h:37:30: warning: integer overflow in expression [-Woverflow]
 #define GxGDEH029A1_Y_PIXELS 296
C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.h:41:28: note: in expansion of macro 'GxGDEH029A1_Y_PIXELS'
 #define GxGDEH029A1_HEIGHT GxGDEH029A1_Y_PIXELS
C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.h:43:53: note: in expansion of macro 'GxGDEH029A1_HEIGHT'
 #define GxGDEH029A1_BUFFER_SIZE GxGDEH029A1_WIDTH * GxGDEH029A1_HEIGHT / 8
C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.h:85:21: note: in expansion of macro 'GxGDEH029A1_BUFFER_SIZE'
     uint8_t _buffer[GxGDEH029A1_BUFFER_SIZE];
C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.h:85:44: error: overflow in constant expression
C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.h:85:44: error: size of array '_buffer' is negative
C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.cpp: In member function 'virtual void GxGDEH029A1::fillScreen(uint16_t)':
C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.cpp:112:28: note: in expansion of macro 'GxGDEH029A1_BUFFER_SIZE'
   for (uint16_t x = 0; x < GxGDEH029A1_BUFFER_SIZE; x++)
C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.cpp: In member function 'virtual void GxGDEH029A1::drawBitmap(const uint8_t*, uint32_t)':
C:\Users\Raport\Documents\Arduino\libraries\GxEPD-master/GxGDEH029A1/GxGDEH029A1.cpp:147:28: note: in expansion of macro 'GxGDEH029A1_BUFFER_SIZE'
   for (uint32_t i = 0; i < GxGDEH029A1_BUFFER_SIZE; i++)
exit status 1
Error compiling for board Arduino Nano.
Does it mean it's not suitable for Arduino Nano because of Nano's poor memory reservours?
Have a good day.
Now you have understood what I need from you if I should try to help you.
First, as I already told you, the waveshare string example can be successfully compiled for Arduino Nano.
I did not yet try to run it on my Nano, but I have it ready complete with level converter.
Second, the current version of my GxEPD on GitHub is not suitable for UNO or Nano, as it needs a buffer of ~5kB in RAM. And the current GxIO_SPI only works correctly on ESP8266 and ESP32, because the setFrequency() method only works for these. I work on a fix for this. For these displays max SPI frequency is 4MHz.
Third, you need to upgrade your Arduino IDE to the actual version (1.8.3) to compile the waveshare string example, as I already told you. And GxEPD most likely will need version 1.8.x, at least for UNO, Nano.
Fourth, I will provide a new version of the small e-paper GxEPD classes for AVR (UNO and Nano) with reduced buffer and support for bitmaps in PROGMEM. Only the reduced part of the display will be available for use with Adafruit_GFX. An initial version for 2.9inch runs on my Nano. But this is not my priority.
Bear in mind that I am a hobby Arduino user like you; I do this for fun, and provide help only as long as I consider it a pleasure.
Now i understand:) Thank you for your time. Your reply convinced me to order esp8266. Too much constrains with Nano - RAM size being the most anoying.
I'll try to change IDE to the newest one but as i said - i can play with arduino at work only and IDE must be installed by company's administrator (he's not at work now and it's not easy to convience him to do it thanks to company policy:(:(:frowning:
