Grumpy_Mike:
Common cathode LEDs are not very common and so not many chips are designed to drive them.
Really? That is all i seem to find when I look at bi-color & RGB LEDs...[/quote]
What do you expect - he drives on the wrong side of the road, his light switches are upside down, his electrical outlets have too much voltage and low frequency, and he spells some words wrong. Actually I think Mike is referring to 7-segment LED displays not bi-color LEDs.
No, why do you think there are very few common cathode LED drivers? The reason is that traditionally you always had a greater current sink capacity from logic gates than current source. So it made sense to drive them with current sinking. This is no good for driving common cathode LEDs.
I didn't know that.
No matter how hard the U.S try we will always be at least 5 hours ahead of you.
I don't know we are talking about common anode when the led the subject is about is common cathode...
Still want a good led driver IC
I think I will revise what I need from the driver:
The more ports (aka. output pin) that can be individually controlled on 1 chip the better, so long as the price-per-port ratio is reasonable
Each port needs to be able to control the brightness of the led,
while still allowing the LED to be directly powered from the LED driver's port(typical 7.5mA // 15mA max @ 100% duty cycle?)
Built in current control would be nice
Serial control or I2C (if any other type please include a link to a tutorial)
DIP chips only
Needs to keep the selected ports on/off until the chip gets a new command
Total cost to control 242 ports on however many ICs needed should cost less than $35.00 USD
I'm not sure it meets all your requirements but the MAX7219 / MAX7221 will allow you to drive 64 LEDs (32 Bi Colour C/C LEDS). You can chain them but depending on your update rate that may not be suitable.
sixeyes:
what do u mean by the update rate?
It needs to be controlling a 111111 Bi-color LED cube... with only one layer on at a time. (121 Bi-color LEDs max on at any time)
so it would need to cycle between 11 to 22, (22 layers if i have only one color per layer on at a time,)
layers at a rate that the human eye will see no flickering... 40Hz???? I don't know for sure...
The MAX7219/MAX7221 is controlled by sending a 16 bit command to the chip. If you want individual control of each LED you're going to have to send one command per LED. If you have 242 LEDs and 40Hz that means ~ 10,000 updates a second, so you've got lots of time. There is a library to drive the chip although I've not used it (yet).
OK maybe it is harsh but I think it is true, the OP said:-
I'm looking to buy a few LED Driver IC's for an 11*11 LED Bi-color display.
That chip handles an 8 X 8 matrix for a single colour. So how are you going to extend it to handle an extra 3 columns and rows and an extra colour? It's internal memory is only 8 X 8.
So how do you propose using that chip for this situation?
and be @ a reasonable price
This is an expensive chip, are you suggesting that he uses three of them?
I was planning to use the chip myself for use with bi colour common cathode LEDs. That's why I posted when no one else had suggested anything. If you have 4 LEDs per bank and 8 banks per chip. I was imagining that he would need 4 chips.
Depends where you source them. I bought 5 on ebay from Hong Kong for < £10. But I agree if you're buying from Farnell / RS it's way too expensive.
yeah except every single cathode is connected to ground, so no columns or rows, just 121 or 242 pins to control...
Well as Mike pointed out there aren't many chips to drive common cathode LEDs and they can be pricey.
If you want to drive the LEDs using the MAX7219 you'd need to connect 32 LEDs to each chip. You will get individual control over each LED, it's just that the chip does not have 64 pins.
The chip is designed to drive seven segment displays but you can use it to control 64 LEDs or 32 BiColour LEDs.
It's a matrix chip, 8 * 8 = 64.
You don't connect the common cathodes to ground. You connect them to the anodes to SEG A-G/DP pins and the cathodes to DIGIT 0-7 pins.
If you imagine a chess board, the SEG pins connect to the rows and the DIGIT pins connect to the columns. You place you LED in each square connected between the two lines.
yeah but it's one of 11 layers... so all the cathodes per layer need to be connected to make it a layer, and in addition I already have soldered the cube up..
