Good Oscilloscope Projects for Beginners? / Skills Test / TDR
Hello all!
I am getting my first oscilloscope in the mail in a couple days :smiley:!
I’m wondering if any of you people on here have any good projects for oscilloscope beginners (not necessarily electronics beginners lol)? Yeah, I know, “Go ask Google”, right? Well, I want to get some different ideas from pros as I already did that.
If you have any idea at all, just reply! I’ll try it out :wink:.
Thanks in advance!
For testing your oscilloscope skills, scroll to reply #64! Or click here to scroll down.
For making a TDR (Time Domain Reflectometer), scroll to reply #81! Or click here to scroll down.
For testing a TDR, scroll to reply #106! Or click here to scroll down.
How many channels and what is the bandwidth?
Hi again @EmilyJane
Ah sorry, in my excitement I forgot to mention the basics lol.
It’s a “ Siglent Technologies SDS1202X-E”
Bandwidth = 200mhz
Channels = 2
Here is the link (amazon app):
What electronic circuitry do You have for practising?
Try reading the serial when downloading code or when Serial.printing.
Thanks @Railroader!
I have the basic Arduino kits, and lotssss of components. I build electrical projects all the time.
I like to check the actual performance of analog filters, the result of hardware switch debounce circuits, logic voltage levels, power supply noise, phase relationships, PWM signals that I don't use a library to create, interrupt latency, etc.
Basically put a probe on everything. :grinning:
:joy: do you mind if I quote that and sticky it on the top of it?
Thanks for the ideas :bulb:!
Go for it! :grinning:
O'scopes are wonderful tools to help visualize what is really going on in an electronic circuit.
Obligatory disclaimer: You can get an incorrect "picture" of what's happening by not using an oscilloscope correctly. Read up on some of the pitfalls.
Look at this thread.
See if you can get the same results.
Example display:
Thanks @LarryD !
Wow, I was just reading through that thread (it’s so long!). You are quite the oscilloscope pro! Great tutorials to follow; thanks @LarryD !
Lissajous figures are fun, and make you figure out XY mode.
You could try synthesizing the waveforms with relatively simple Arduino sketches.
google…
a7
learn how to make a TDR, a time domain reflectometer. you will need a handful of resistors, a few connectors, and a square wave source with a very short risetime
A very simple measurement to make would be the mains voltage. However DO NOT CONNECT YOUR SCOPE PROBE TO THE MAINS. Under any condition.
To to this you get a plug in power supply (aka wallwart) that puts out AC voltage. They are isolated from the mains and usually output 10 to 16 vac. You can measure the output of the wallwart and see the waveform that is indictive of the mains waveform.
This might just rise to the level of a bad suggestion.
Oops, too late, I rushed right off and fried my new scope when I connected the ground lead to the wrong mains wire.
This link tells you why:-
How not to blow up your oscilloscpe
A good thing to do would be to connect your scope to a microphone and try and see the tiny signals you get.
Look at the signal with different time base settings and see how it changes. Also look at the waveform under continuous reading and single shot. And look to see the effect the trigger voltage setting has for a single shot.
Any audio project is ideal for actually seeing the waveforms you are listening to and trying to relate what you here to what you see.
Also just touch the tip of the probe and see how much voltage you can pick up with a high impedance input, and then you will never get fooled again by floating input pins.
Get a Piezo disc sensor connect it up an tap it directly, see the hundred volts or so you can get from it, see that it goes positive and negative and look at the ringing and contact bounce you can get from it sometimes.
Yeah, I figured that might be a bad idea lol.
Thanks @Grumpy_Mike , @EmilyJane , @JohnRob and @Geek_Emeritus !
I was already thinking of building an audio amplifier, and I can use the o'scope to see what's going on. Also, I am going to try a resonance project with the o'scope and a mic hooked up to it.
I can't wait!
start with some simple tasks.
  • Read a simple HIGH/LOW Signal on a digital port, e.g. with a blink sketch. Measure the voltage difference between high & low, set cursors, calculate (if possible), set up the data to be shown on your screen.
  • Check a PWM output ("analogWrite")
  • Read one channel: analyse a serial.print output of "Hello World". Learn your scope how to trigger a signal, do a measurement of a short signal and make them visible on your screen.
  • Read two channels: try the same with I2C communication. Set the trigger to channel 1, set the trigger to channel 2...
  • measure the signal of long wires, see the effect what happens to your data lines if you connect with long wires.
  • start experimenting with "analog signals"
if you are still waiting for the delivery ... download the manual and read it. Repeat that as long as you don't have the scope :wink:
Thanks @noiasca !
I took your suggestion and started reading the manual. Boy is that manual long and a little complicated! Tbh, I’m a little lost in it, but I’m hoping once I get the o’scope, it will be a little clearer and I can try and follow along with it.
Here’s the manual for it for anyone interested:
I would advise against reading it first from start to finish as I have found it is only after a period of playing with something like this for a while that any thing in the manual will make much sense. I find it best to read the manual from start to finish once you have a basic idea of how the thing works.
In that way you get a lot more out of it.
