Hello all,
I'm trying out my new GSM shield module and have succesfully gone trough the first 2 sketches from:
- Testing the modem and network connection
- Sending a SMS message
However, I'm stuck with the third sketch "Connecting to the internet". I've modified it a bit to better look at the problem (I'm returning a check if the PIN succeeds and when the GPRS connection works:
// include the GSM library
#include <GSM.h>
// PIN number if necessary
#define PINNUMBER ""
// APN information obrained from your network provider
#define GPRS_APN "web.pro.be" // replace with your GPRS APN
#define GPRS_LOGIN "" // replace with your GPRS login
#define GPRS_PASSWORD "" // replace with your GPRS password
// initialize the library instances
GSMClient client;
GPRS gprs;
GSM gsmAccess;
// This example downloads the URL "http://arduino.cc/latest.txt"
char server[] = "arduino.cc"; // the base URL
char path[] = "http://arduino.cc/latest.txt"; // the path
int port = 80; // the port, 80 for HTTP
int PIN_OK = 0;
// initialize serial communications
Serial.println("Starting Arduino web client.");
// connection state
boolean notConnected = true;
// Start GSM shield
// pass the PIN of your SIM as a parameter of gsmAccess.begin()
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY && !PIN_OK){
Serial.println("PIN OK");
PIN_OK = 1;
digitalWrite(4,HIGH);
else if (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)==GPRS_READY){
Serial.println("GPRS OK");
notConnected = false;
digitalWrite(5,HIGH);
Serial.println("Not connected");
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, port))
Serial.println("connected");
// Make a HTTP request:
client.print("GET ");
client.print(path);
client.println(" HTTP/1.0");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available())
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.available() && !client.connected())
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for(;;)
The result is this:
PIN OK
And it stays that way... I do not get an error, I do not get a "'succesfull" message. Just this.
However, when I go to debug mode gsmAccess(true) then I get this:
AT%13%
0 9>AT%13%%13%%10%OK%13%%10%
AT+CPIN=....%13%
9 44>AT+CPIN=....%13%%13%%10%+CPIN: READY%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
44 75>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
75 120>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%%13%%10%Call Ready%13%%10%
AT+CGREG?%13%
120 23>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
23 54>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
54 85>AT+CGREG?%13%%13%%10%+CGREG: 0,1%13%%10%%13%%10%OK%13%%10%
AT+IFC=1,1%13%
85 102>AT+IFC=1,1%13%%13%%10%OK%13%%10%
AT+CMGF=1%13%
102 118>AT+CMGF=1%13%%13%%10%OK%13%%10%
AT+CLIP=1%13%
118 6>AT+CLIP=1%13%%13%%10%OK%13%%10%
ATE0%13%
6 17>ATE0%13%%13%%10%OK%13%%10%
AT+COLP=1%13%
17 23>%13%%10%OK%13%%10%
PIN OK
AT%13%
48 57>AT%13%%13%%10%OK%13%%10%
AT+CPIN=....%13%
57 92>AT+CPIN=....%13%%13%%10%+CPIN: READY%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
92 123>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
123 40>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%%13%%10%Call Ready%13%%10%
AT+CGREG?%13%
40 71>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
71 102>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
102 5>AT+CGREG?%13%%13%%10%+CGREG: 0,1%13%%10%%13%%10%OK%13%%10%
AT+IFC=1,1%13%
5 22>AT+IFC=1,1%13%%13%%10%OK%13%%10%
AT+CMGF=1%13%
22 38>AT+CMGF=1%13%%13%%10%OK%13%%10%
AT+CLIP=1%13%
38 54>AT+CLIP=1%13%%13%%10%OK%13%%10%
ATE0%13%
54 65>ATE0%13%%13%%10%OK%13%%10%
AT+COLP=1%13%
65 71>%13%%10%OK%13%%10%
AT+CGATT=1%13%
71 77>%13%%10%OK%13%%10%
AT+QIFGCNT=0%13%
77 83>%13%%10%OK%13%%10%
AT+QICSGP=1,"web.pro.be","",""%13%
83 89>%13%%10%OK%13%%10%
AT+QIMUX=0%13%
89 95>%13%%10%OK%13%%10%
AT+QIMODE=1%13%
95 101>%13%%10%OK%13%%10%
AT+QINDI=1%13%
101 107>%13%%10%OK%13%%10%
AT+QIREGAPP%13%
107 113>%13%%10%OK%13%%10%
AT+QIACT%13%
113 119>%13%%10%OK%13%%10%
GPRS OK
connecting...
AT+QIDNSIP=1%13%
119 125>%13%%10%OK%13%%10%
AT+QIOPEN="TCP","arduino.cc",80%13%
125 3>%13%%10%OK%13%%10%
125 14>%13%%10%OK%13%%10%%13%%10%CONNECT%13%%10%
connected
GET http://arduino.cc/latest.txt HTTP/1.0%13%%10%%13%%10%
14 10>HTTP/1.1 200 OK%13%%10%Server: Apache%13%%10%Last-Modified: Wed, 05 Jun 2013 10:14:56 GMT%13%%10%Content-Type: text/plain%13%%10%Content-Length: 5%13%%10%
HTTP/1.1 200 OK
Server: Apache
Content-Type: text
111 107>/plain%13%%10%Content-Length: 5%13%%10%Accept-Ranges: bytes%13%%10%Date: Mon, 24 Jun 2013 20:33:11 GMT%13%%10%X-Varnish: 982801640%13%%10%Age: 0%13%%10%Via: 1.1
/plain
Content-Length: 5
X-Varnish:
80 40>982801640%13%%10%Age: 0%13%%10%Via: 1.1 varnish%13%%10%Connection: close%13%%10%X-Cache: MISS%13%%10%%13%%10%0105%10%%13%%10%CLOSED%13%%10%
982801640
Via: 1.1 varnish
Connection: close
X-Cache: MISS
0105
disconnecting.
+++AT+QICLOSE%13%
41 41>
And everything looks to be working fine...
I'm powering the arduino by USB and 12V external power source (lightgrid). Can somebody help me please? I'm out of ideas...
