I can't seem to get past "Connecting GSM network..." when I run the sketch. Anyone have any suggestions? It is the first time that I am trying to integrate a GPRS shield into my Arduino life. Just purchased it today. Thanks.
We can't comment until you post the sketch you are talking about.
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
What arduino controller are you using?
Tom.... ![]()
Do you mean the File->Examples->GSM->Tools->TestGPRS sketch?
Do you have a SIM card with a data plan installed?
Did you add your PIN number to the sketch?
How long did you wait for an error message? (Try waiting longer. The error message might tell you why it is failing.)
Sorry, this is the code. I should probably check to see if there is still a plan associated with the SIM that I am using. If not, would I be getting what I mentioned??
Thanks.
This test asks your APN data and try to connect
to arduino.cc site by GPRS.
Circuit:
* GSM shield attached
Created 18 Jun 2012
by David del Peral
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess; // GSM access: include a 'true' parameter for debug enabled
GPRS gprsAccess; // GPRS access
GSMClient client; // Client service for TCP connection
// messages for serial monitor response
String oktext = "OK";
String errortext = "ERROR";
// URL and path (for example: arduino.cc)
char url[] = "arduino.cc";
char urlproxy[] = "http://arduino.cc";
char path[] = "/";
// variable for save response obtained
String response = "";
// use a proxy
boolean use_proxy = false;
// initialize serial communications
use_proxy = false;
// start GSM shield
// if your SIM has PIN, pass it as a parameter of begin() in quotes
Serial.print("Connecting GSM network...");
if(gsmAccess.begin(PINNUMBER)!=GSM_READY)
Serial.println(errortext);
while(true);
Serial.println(oktext);
// read APN introduced by user
char apn[50];
Serial.print("Enter your APN: ");
readSerial(apn);
Serial.println(apn);
// Read APN login introduced by user
char login[50];
Serial.print("Now, enter your login: ");
readSerial(login);
Serial.println(login);
// read APN password introduced by user
char password[20];
Serial.print("Finally, enter your password: ");
readSerial(password);
// attach GPRS
Serial.println("Attaching to GPRS with your APN...");
if(gprsAccess.attachGPRS(apn, login, password)!=GPRS_READY)
else{
// read proxy introduced by user
char proxy[100];
Serial.print("If your carrier uses a proxy, enter it, if not press enter: ");
readSerial(proxy);
Serial.println(proxy);
// if user introduced a proxy, asks him for proxy port
int pport;
if(proxy[0] != '\0'){
// read proxy port introduced by user
char proxyport[10];
Serial.print("Enter the proxy port: ");
readSerial(proxyport);
// cast proxy port introduced to integer
pport = (int) proxyport;
use_proxy = true;
Serial.println(proxyport);
// connection with arduino.cc and realize HTTP request
Serial.print("Connecting and sending GET request to arduino.cc...");
int res_connect;
// if use a proxy, connect with it
if(use_proxy)
res_connect = client.connect(proxy, pport);
res_connect = client.connect(url, 80);
if (res_connect)
// make a HTTP 1.0 GET request (client sends the request)
client.print("GET ");
// if use a proxy, the path is arduino.cc URL
if(use_proxy)
client.print(urlproxy);
client.print(path);
client.println(" HTTP/1.0");
client.println();
// if you didn't get a connection to the server
Serial.print("Receiving response...");
boolean test = true;
while(test)
// if there are incoming bytes available
// from the server, read and check them
if (client.available())
char c = client.read();
response += c;
// cast response obtained from string to char array
char responsechar[response.length()+1];
response.toCharArray(responsechar, response.length()+1);
// if response includes a "200 OK" substring
if(strstr(responsechar, "200 OK") != NULL){
Serial.println("TEST COMPLETE!");
test = false;
// if the server's disconnected, stop the client:
if (!client.connected())
Serial.println("disconnecting.");
client.stop();
test = false;
Read input serial
int readSerial(char result[])
int i = 0;
while(1)
while (Serial.available() > 0)
char inChar = Serial.read();
if (inChar == '\n')
result[i] = '\0';
return 0;
if(inChar!='\r')
result[i] = inChar;
i++;
I waited several minutes, then tried it again with a PIN if there ever was one (but never added one for the SIM card), but still nothing past "Connecting GSM network...".
Which shield?
Running a GPRS Seeed shield, V2.1, on a UNO board.
The examples provided with the IDE are for the official Arduino shield based on the Quectel M10 chip, not the SIM900. They may use codes that are exclusive to the M10.
You were right! I went here (http://tronixstuff.com/2014/01/08/tutorial-arduino-and-sim900-gsm-modules/) and all worked well. Thanks
