Hi All, I have seen online a digital compass. Here is the link;
[digital compass](https://Digital Compass Altimeter Barometer Thermo)
I need a compas for an arduino sketch I am working on. I have been trying to use an ordinary magnetic compass. The problem with this is that if you don't have it perfectly horizontal you don't get an accurate reading.
I am hoping this compass does not have that problem of having to be horizontal for reading. This one is stand alone.
Is any body on this forum familiar with this compass and can suggest it as a good replacement of an ordinary magnetic compass?
your link doesnt work
sorry about that. always have problems with things like that. Can you suggest how to do it? The data on the compass is in my downloads file.
So you downloaded it from somewhere. The best way to share it is to find the link where you downloaded from and then post that link here.
Click on the upload button, find the file and click on it.
That is the one I am looking at. Do you know if it is any good for compass bearings? That is the only function I want although I see it has other useful functions.
The main thing is that I don't have to make sure it is horizontal when I take a compass bearing otherwise it is no better than the simple magnetic compass I have already.
Thanks xfpd.
For $20, I hope it is good. Garmin (popular with bicycle riders and long distance trekkers) are pin point accurate at $300, and can be loaded with a strip map for indicating the right direction on a simple LCD screen (no maps, just a direction arrow).
OK, how do you envision interfacing your Arduino with the stand-alone compass? Does the compass have some kind of interface that you can easily connect a microcontroller to (I2C, UART etc.)? It doesn't look like it to me.
I'd try a search like this if it needs to be part of an Arduino project: Amazon.com : arduino compass
I think electronic compass modules are always a little iffy. Even smartphones (that rely on a variety of inputs and a lot of advanced processing) tend to have problems getting a good bearing if you're standing still. Once moving, it clears up because they can use GPS location to work out direction and heading. So the question is how well you're going to get this to work in the first place. The earth magnetic field is kind of a subtle thing to detect and any detection is easily affected.
