GPS NEO6MV2 no data, even gibberish
Hello, I followed every thread about this module and I'm lost.
I use it with nano.
I have blinking diod on gps, but I don't receive anything.
I tried connecting VCC on gps with 3.3V PIN, 5VPIN and to 5V powerbank with shared ground with arduino.
I tried connecting TX on gps with either digital pin or rx pin.
I checked if there isn't any break on wire, everything is ok.
Bellow is simples code I found and use.
SoftwareSerial gps(2,-1);
  gps.begin(9600);
while (gps.available()>0)
    Serial.write(gps.read());
Baud in serial monitor set to 115200, I left on for half an hour (led blinking whole time), I got nothing.
gps.available() is always false
Welcome to the forum
I appreciate that you only want to receive data and not transmit it but I don't like the idea of using -1 as a pin number parameter.
What happens if you use a real pin number ?
My savior, I had it set to some pin at beginning, but since it didn't work and I saw -1 in working projects I set it to -1 maaaany tries and go and didn't thought to come back.
