I am just loosing it... never in my history of using computers have I been unable to "google" a solution, but here I am...
I have "flashed" GRBL to my arduino uno
I have added the GRBL and GRBL-Master to my library
I am using Arduino IDE 1.6.3
I can "include" the GRBL library and open the Serial Monitor
The serial monitor will read: Grbl 0.9i ['$' for help].
When I type $ nothing happens
Here is my question:
so what am I doing wrong, everything I read says I should get SOME information... I get nothing...
do motors need to be attached?
I KNOW, at one time I had this working and I could get SOME information when I sent the $...
I went out and bought a Protoneer GRBL shield as one of the first steps to building a CNC router (I already owned 3 Stepper motors), but now I don't know if I'm going to be able to feed the arduino "G-code..." I'm at a standstill...
I was writing a dissertation explaining more and opened the Serial Monitor because I couldn't remember what it was called. I started playing with the "settings" at the bottom of the screen next to the baud rate.
I knew the baud rate had to be 115,200, but I never found where I had to have the other box set to anything...
GRBL seems to work fine as long as I picked something OTHER than the default setting: "no line ending" ... all 3 other settings seemed to let Grbl work!
At least, when I sent "$", it gave me the "help" info I was expecting... I sent a few of the "help" codes and it returned information...
Sorry to bother all y'all with such a sophomoric (moronic) question, but maybe someday someone will have the same problem and THIS page will help them..
You need to send a line ending for a line-by-line interpreter.
Robin2:
GRBL is a complex program. Have you ever seen it working on an Arduino? (I don't mean to imply that it can't - I am just asking about your experience)
Then you need to get the Arduino library version from here and play with it - works out the
box nicely in my experience: http://blog.protoneer.co.nz/grbl-arduino-library/
And its not complex (compared to LinuxCNC for example)!
I don't understand, that library works out of the box in my experience?
Have you bricked your Arduino? You need to re-install the Arduino bootloader
after installing the non-library version of GRBL.
The protoneer version is, I think, several versions behind, which may be an
issue, but the convenience more than makes up for it for most use-cases I
reckon.
