Having issues with GRBL compiling for Arduino Nano Every.
Compiler Messages:
Arduino: 1.8.4 (Windows 10), Board: "Arduino Nano Every, None (ATMEGA4809)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jim\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jim\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jim\OneDrive\Documents\Arduino\libraries -fqbn=arduino:megaavr:nona4809:mode=off -vid-pid=0X2341_0X0058 -ide-version=10804 -build-path C:\Users\jim\AppData\Local\Temp\arduino_build_3568 -warnings=none -build-cache C:\Users\jim\AppData\Local\Temp\arduino_cache_68800 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\examples\grblUpload\grblUpload.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jim\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jim\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jim\OneDrive\Documents\Arduino\libraries -fqbn=arduino:megaavr:nona4809:mode=off -vid-pid=0X2341_0X0058 -ide-version=10804 -build-path C:\Users\jim\AppData\Local\Temp\arduino_build_3568 -warnings=none -build-cache C:\Users\jim\AppData\Local\Temp\arduino_cache_68800 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\examples\grblUpload\grblUpload.ino
Using board 'nona4809' from platform in folder: C:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7
Using core 'arduino' from platform in folder: C:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7
Detecting libraries used...
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "C:\Users\jim\AppData\Local\Temp\arduino_build_3568\sketch\grblUpload.ino.cpp" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\AppData\Local\Temp\arduino_build_3568\sketch\grblUpload.ino.cpp" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\eeprom.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\gcode.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\jog.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\limits.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\main.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\motion_control.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\nuts_bolts.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\planner.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\print.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\probe.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\protocol.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\report.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\serial.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\settings.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\spindle_control.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\stepper.c" -o "nul"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\system.c" -o "nul"
Generating function prototypes...
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\AppData\Local\Temp\arduino_build_3568\sketch\grblUpload.ino.cpp" -o "C:\Users\jim\AppData\Local\Temp\arduino_build_3568\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\jim\AppData\Local\Temp\arduino_build_3568\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\AppData\Local\Temp\arduino_build_3568\sketch\grblUpload.ino.cpp" -o "C:\Users\jim\AppData\Local\Temp\arduino_build_3568\sketch\grblUpload.ino.cpp.o"
Compiling libraries...
Compiling library "GRBLStepCraft"
"C:\Users\jim\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/deprecated" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino" "-IC:\Users\jim\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\variants\nona4809" "-IC:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft" "C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c" -o "C:\Users\jim\AppData\Local\Temp\arduino_build_3568\libraries\GRBLStepCraft\coolant_control.c.o"
In file included from C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\grbl.h:47:0,
from C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c:21:
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c: In function 'coolant_init':
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\cpu_map.h:108:33: error: 'DDRC' undeclared (first use in this function); did you mean 'DD7'?
#define COOLANT_FLOOD_DDR DDRC
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c:26:3: note: in expansion of macro 'COOLANT_FLOOD_DDR'
COOLANT_FLOOD_DDR |= (1 << COOLANT_FLOOD_BIT); // Configure as output pin
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\cpu_map.h:108:33: note: each undeclared identifier is reported only once for each function it appears in
In file included from C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\grbl.h:43:0,
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c: In function 'coolant_get_state':
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\nuts_bolts.h:64:32: error: invalid operands to binary & (have 'PORT_t {aka struct PORT_struct}' and 'int')
#define bit_istrue(x,mask) ((x & mask) != 0)
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c:41:9: note: in expansion of macro 'bit_istrue'
if (bit_istrue(COOLANT_FLOOD_PORT,(1 << COOLANT_FLOOD_BIT))) {
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c: In function 'coolant_stop':
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c:65:24: error: invalid operands to binary & (have 'PORT_t {aka struct PORT_struct}' and 'int')
COOLANT_FLOOD_PORT &= ~(1 << COOLANT_FLOOD_BIT);
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c: In function 'coolant_set_state':
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c:89:23: error: invalid operands to binary | (have 'PORT_t {aka struct PORT_struct}' and 'int')
COOLANT_FLOOD_PORT |= (1 << COOLANT_FLOOD_BIT);
C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft\coolant_control.c:95:23: error: invalid operands to binary & (have 'PORT_t {aka struct PORT_struct}' and 'int')
Using library GRBLStepCraft in folder: C:\Users\jim\OneDrive\Documents\Arduino\libraries\GRBLStepCraft (legacy)
exit status 1
Error compiling for board Arduino Nano Every.
