gsm/gprs sim900 with NEO-6m gps to sms output compile errors
Hi all I am not sure why I am getting so many compile errors. Pretty new to this and advice what be very much appreciate here is the code followed by the compile errors
[code#include <SoftwareSerial.h>
#include "SIM900.h"
#include <TinyGPS.h>
#include "sms.h"
SMSGSM sms;
TinyGPS gps;
SoftwareSerial ss(2, 3);
SoftwareSerial SIM900(8, 7);
static void smartdelay(unsigned long ms);
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_str(const char *str, int len);
String strL, strN, poss, tareq, textForSMS;
char charL[10], charN[10], text[400];
int o = 1;
boolean started = false;
ss.begin(9600);
float flat, flon;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
while (o < 4) {
gps.f_get_position(&flat, &flon, &age);
textForSMS = "tareq Home"; //testing gps from here
Serial.println(textForSMS);
Serial.print("longitude: ");
print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
Serial.println("");
Serial.print("latitude : ");
print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
smartdelay(1000);
Serial.println(""); //till here
o++;
Serial.println("nil"); //to check whether 'if' works
dtostrf(flat, 8, 6, charL);
for (int i = 0; i < 10; i++)
strL += charL*;*
  • dtostrf(flon, 8, 6, charN);*
  • for (int i = 0; i < 10; i++)*
    _ strN += charN*;_
    _
    }_
    _
    tareq = "tareq Home Location";_
    _
    tareq = tareq + "\nlongitude: " + strN + "\nlatitude : " + strL;_
    _
    poss = tareq;_
    _
    poss.toCharArray(text, 400);_
    _
    gsm.begin(9600);_
    _
    delay(1000);_
    _
    Serial.println(text);_
    _
    if (sms.SendSMS("+8801839443686", text))_
    _
    {_
    _
    Serial.println("\nSMS sent OK.");_
    _
    }_
    _
    else*_
    * Serial.println("\nError sending SMS.");*
    * do {} while (1);*
    * //o++;*
    * unsigned long start = millis();*
    * do*
    * while (ss.available())*
    * gps.encode(ss.read());*
    * } while (millis() - start < ms);*
    * if (val == invalid)*
    * while (len-- > 1)*
    _ Serial.print('');_
    _
    Serial.print(' ');_
    _
    }_
    _
    else*_
    * Serial.print(val, prec);*
    * int vi = abs( val);*
    * int flen = prec + (val < 0.0 ? 2 : 1); // . and -*
    * flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;*
    * for (int i = flen; i < len; ++i)*
    * Serial.print(' ');*
    * smartdelay(0);*
    static void print_str(const char str, int len)
    _
    {_
    _
    int slen = strlen(str);_
    _
    for (int i = 0; i < len; ++i)_
    _ Serial.print(i < slen ? str : ' ');
    smartdelay(0);
    }][/code]
    and this is the compile errors
    ```*_
    *Arduino: 1.8.1 (Windows 7), Board: "Arduino/Genuino Uno"
In file included from C:\Program Files\Arduino\libraries\GSM_GPRS_GPS_Shield_GSMSHIELD\GSM.cpp:17:0:
C:\Program Files\Arduino\libraries\GSM\src/GSM.h:56:13: error: prototype for 'int GSM3ShieldV1AccessProvider::begin(long int)' does not match any in class 'GSM3ShieldV1AccessProvider'
#define GSM GSM3ShieldV1AccessProvider
C:\Program Files\Arduino\libraries\GSM_GPRS_GPS_Shield_GSMSHIELD\GSM.cpp:43:5: note: in expansion of macro 'GSM'
int GSM::begin(long baud_rate)
In file included from C:\Program Files\Arduino\libraries\GSM\src/GSM.h:45:0,
C:\Program Files\Arduino\libraries\GSM\src/GSM3ShieldV1AccessProvider.h:80:24: error: candidate is: virtual GSM3_NetworkStatus_t GSM3ShieldV1AccessProvider::begin(char*, bool, bool)
GSM3_NetworkStatus_t begin(char* pin=0,bool restart=true, bool synchronous=true);
C:\Program Files\Arduino\libraries\GSM_GPRS_GPS_Shield_GSMSHIELD\GSM.cpp:315:21: error: variable or field 'InitParam' declared void
void GSM::InitParam(byte group)
C:\Program Files\Arduino\libraries\GSM_GPRS_GPS_Shield_GSMSHIELD\GSM.cpp:315:21: error: 'byte' was not declared in this scope
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
_```*_
can anyone help please?
no one?
Well, you could edit your original post (under "More Actions..." -> "Modify Post") and put the code tags around your sketch, just like you did for the error messages... You misplaced the closing bracket on the starting code tag.
God I hate these forums. Really that's your response? I am not a developer you know where the code ends and begins based on my tag I am trying to help my son build a project and just needed advice not a spell checker with a red marker when its quite obvious that you knew where the code began and ended you just want to be high and mighty. So sick of that kind of crap here
