GSM & GPS - PROBLEM CODING REQUEST SMS
Hi guys,
i need some advice or help.
my project is about gps tracker. Im using GSM (SIM800L EVB) , GPS SKYLAB SKM53 and Arduino UNO.
Ok, i have no problem with my first coding. Which is i request from serial monitor like "GPS LOCATION" . After serial find GPS LOCATION . i will SUCCESS receive sms with the latitude and longitude.
BUT i have problem with my second coding. When i request the GPS LOCATION from my handphone it will show my number and the "GPS LOCATION" in serial monitor. BUT i did not get any SMS.
What is my mistake?
Here is my coding.
My first coding..
#include <TinyGPS.h>
#include <SoftwareSerial.h>
#include <AltSoftSerial.h>
#include "SIM900.h"
#include "sms.h"
SMSGSM sms;
char number[]="01********";
char message[40];
char value_str[12];
char message1[40];
char value_str1[12];
char message2[40];
char value_str2[12];
int temp=0,i;
unsigned long fix_age;
AltSoftSerial  GPS (8,9);
TinyGPS gps;
void gpsdump(TinyGPS &gps);
bool feedgps();
void getGPS();
long lat, lon;
float LAT, LON;
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20];
void setup(){
 GPS.begin(9600);
    if (gsm.begin(2400)){
    Serial.println("\nstatus=READY");
    started=true;
  else Serial.println("\nstatus=IDLE");
  serialEvent();
  if(temp)
    getGPS();
    sendLocation();
void serialEvent()
  while(Serial.available())
    if(Serial.find("GPS LOCATION"))
      temp=1;
    temp=0;
void sendLocation(){
  GPS.listen();
    long lat, lon;
  unsigned long fix_age, time, date, speed, course;
  unsigned long chars;
  unsigned short sentences, failed_checksum;
  // retrieves +/- lat/long in 100000ths of a degree
  getGPS();
  gps.get_position(&lat, &lon, &fix_age);
  int latitude=LAT/100000;
  int longitude=LON/100000;
  Serial.print("Latitude : ");
  Serial.print(LAT/1000000,7);
  Serial.print(" :: Longitude : ");
  Serial.println(LON/1000000,7);
  Serial.println("Sending message");
  //Sending the latitude and longitude
  if(started){
    //start to build up message
    message[0]='\0';
    strcat(message,"The current location is  ");
    strcat(message1,"\n Latitude= ");
    itoa(latitude,value_str1,10);
    strcat(message2,"\n Longitude= " );
   itoa(longitude,value_str2,10);
    strcat(message,value_str);
    strcat(message1,value_str1);
    strcat(message2,value_str2);
    strcat(message1,message2);
    strcat(message,message1);
    sms.SendSMS(number,message);
  Serial.println("\nSMS sent OK");
  delay (30000);
void getGPS(){
  bool newdata = false;
  unsigned long start = millis();
  // Every 1 seconds we print an update
  while (millis() - start < 1000)
    if (feedgps ()){
      newdata = true;
  if (newdata)
    gpsdump(gps);
bool feedgps(){
  while (GPS.available())
    if (gps.encode(GPS.read()))
      return true;
  return 0;
  //byte month, day, hour, minute, second, hundredths;
  gps.get_position(&lat, &lon);
  LAT = lat;
  LON = lon;
    feedgps(); // If we don't feed the gps during this long routine, we may drop characters and get checksum errors
My second coding which is i'm in trouble
#include "SIM900.h"
#include "sms.h"
SMSGSM sms;
char number[]="01*******";
char message[40];
char value_str[4];
char message2[40];
char value_str2[4];
TinyGPS gps;
bool feedgps();
void getGPS();
long lat, lon;
float LAT, LON;
int numdata;
char n[20];
char sms1[20];
int temp=0,i;
char location;
char c = location;
void setup(){
  GPS.begin(9600);
    started=true;
  strcat(sms1,"gps location");
  serialEvent();
  if(smsbuffer == sms1)
     getGPS();
    sendLocation();
void serialEvent()
    //Read if there are messages on SIM card and print them.
    Serial.println("Awaiting Message:");
    if(gsm.readSMS(smsbuffer, 160, n, 20))
      Serial.println(n);
      Serial.println(smsbuffer);
  GPS.listen();
  long lat, lon;
  getGPS();
delay(5000);
GPS.end();
  if(started){
    message[0]='\0';
    strcat(message,"Latitude= ");
    itoa(latitude,value_str,10);
    strcat(message2,"\n Longitude= ");
    strcat(message,message2);
  delay (30000);
void getGPS(){
    if (feedgps ()){
      newdata = true;
  if (newdata)
    gpsdump(gps);
bool feedgps(){
      return true;
  return 0;
  LAT = lat;
  LON = lon;
Thank You for the help =)
What is my mistake?
It is in thinking that you can use two instances of software serial to listen to two different devices. You MUST get hardware that has multiple hardware serial ports. Get over it.
