Guidance on how to send SD card .csv file using email -wi-fi
Hello Everyone,
I am very new to Arduino, I am working on one project where I am recording pressure sensor data in a .csv file. I want to send this file via email to a particular user. Please guide me over this or if you know any tutorial please post the link.
Also, I don't know what hardware I will need for my Arduino mega in order to do this email functioning.
You would generally send email by connecting to an SMTP (Simple Mail Transfer Protocol) server and passing it the headers and data. The headers will contain the From and To email addresses. For messages that contain files, like a .csv file, you would use a MIME (Multipurpose Internet Mail Extension) format message.
Note: Because having an SMPT server on the Internet that doesn't require authentication is a sure way to be used for spamming, almost every SMTP server you can reach will require authentication. That may be as simple as a username and password.
first WELCOME. welcome to the forum.
one of the things that will help you is to google what you want and add the word arduino
skateboard arduino
sculpture arduino
send csv file arduino
as you probably know, 90% of the stuff on the internet is out of date, wrong or does not fit your exact needs.
but, some searching will help you get some background and if not get you to your goal, it will get you closer.
it has been said that most of the tutorials are done by noobs and not fully working. when you get to a point you get stuck, please post the code you are working on, the link you got it from and what problems you have.
as a suggestion, when you find a side and they have code. copy the URL and paste that at the top of your sketch.
with a note of when and what you might say to yourself looking back.
another suggestion is to add a serial.Print line in setup with your sketch name.
the, in a year, when you pull out an old unit and have not clue what is on it, you connect it and see what it tells you.
