guide/library for messaging protocol for radio
Hi
I'm currently working with some LoRa radios which are being used to transmit and receive various information. At the moment, I'm developing my own messaging codes to accompany certain information (e.g. sending a tx with "REQUEST_SETTINGS" which the other radio may respond to with "MODE = 20, SPEED = 3.321").
I'm still working on this but I have to admit that it is rather tiresome having to parse each message and to develop all of the messaging codes. I was therefore wondering whether there are any libraries which do most of the heavy lifting for me? To be clear, I have a LoRa library which interfaces with the LoRa device but that is at a fairly low level (e.g. send message with string) and I was wondering whether there is something at a higher level.
If not, please could someone recommend some reading as to what considerations I should take into account when developing the messaging (I'm fairly new to networking/protocols so any guidance would be great).
Thanks
You can avoid parsing by serialising/deserialising a C struct. (subject to LoRa packet size limits)
You'll still need to write code to do the 'if request is this, then send this'.
sbaratheon:
Why not just send 'S' for settings? Single characters make the parsing simple.
...R
mikb55:
thanks, completely forgot about some form of binary serialisation!
Be careful using structures to send and receive data across different Arduino platforms, the structure construction or padding can be different.
Its not clear to me what your question is about, are you just after an easier way of filling a LoRa packet with a mixture of variable types (including arrays) or looking for some standardised way of passing sensor type data such as in the cayenne format ?
srnet:
Hi
Yes, I've just been looking at binary serialisation and it seems that padding/endianness can cause issues.
I'm basically looking for a simple way to transfer plain old data (PODs) structures via LoRa. For example, I want to transfer this struct (among others):
struct settings
    uint32_t waitPeriodSecs = 5;
    uint32_t epoch = 838382;
    char callsign[10] = "station283";
Is there a relatively simple way of doing this? At the moment, I've just using a simple data format which is a pain to work with e.g.
WAIT_PERIOD_SECS=5, EPOCH=838382, CALLSIGN=station283
Thanks
Nothing could be simpler. Just send the struct as a packet, like you would any other packet.
The receiver has to know all about the struct, of course, taking into account the limitations noted in reply #4.
The following will fail because it takes 11 bytes to store the C-string "station283", including the required zero terminator.
sbaratheon:
Cant see how, apart from sending a packet for each variable.
A LoRa packet is just a series of bytes and the receiver has no way of knowing how to decode these bytes into meaningful data unless you define the variables you want to extract. A structure is the clearest and most obvious (when reading a program listing) way of how to achieve this.
Whilst I have produced example programs for my LoRa library using structures to send and receive data, I avoid structures in general as you cannot be sure the example will work across platforms.
On method I adopted to avoid the use of structures was to build a packet like this (it uses specific Library functions);
  LoRa.startWriteSXBuffer(0);                         //start the write at SX12XX internal buffer location 0
  LoRa.writeBufferChar(trackerID, sizeof(trackerID));     //+4 bytes (3 characters plus null (0) at end)
  LoRa.writeFloat(latitude);                          //+4 = 8 bytes
  LoRa.writeFloat(longitude);                         //+4 = 12 bytes
  LoRa.writeUint16(altitude);                         //+2 = 14 bytes
  LoRa.writeUint8(satellites);                        //+1 = 15 bytes
  LoRa.writeUint16(voltage);                          //+2 = 17 bytes
  LoRa.writeInt8(temperature);                        //+1 = 18 bytes total to send
  TXPacketL = LoRa.endWriteSXBuffer();                //closes packet write and returns the length of the packet to send
At the receiver you need to read out the variables in the same type and order;
  LoRa.startReadSXBuffer(0);               //start buffer read at location 0
  LoRa.readBufferChar(receivebuffer);      //read in the character buffer
  latitude = LoRa.readFloat();             //read in the latitude
  longitude = LoRa.readFloat();            //read in the longitude
  altitude = LoRa.readUint16();            //read in the altitude
  satellites = LoRa.readUint8();           //read in the number of satellites
  voltage = LoRa.readUint16();             //read in the voltage
  temperature = LoRa.readInt8();           //read in the temperature
  RXPacketL = LoRa.endReadSXBuffer();      //finish packet read, get received packet length
Accepted its not as clear as using a structure, but it has the very significant advantage of being platform agnostic.
One additional benefit is that the routines above do not use a memory buffer\array for building the packet, variables are written direct to the LoRa devices internal buffer.
The previously mentioned Cayenne uses identifier bytes to describe the type of data that follows, voltage, temperature, GPS co-ordinate etc. Thus the receiver does not actually need to know the structure or variable type of the data sent.
jremington:
I'm not sure that I understand what you mean. The LoRa packet must be a byte/char array and so the question arises as to how a struct is serialised to said byte/char array.
As noted above, it seems that a simple binary serialisation using memcpy is unreliable as between different arduino architectures.
srnet:
Thanks, that's helpful. One other method might be using a text serialisation library e.g. [ArduinoJson](http://"Thanks, that's helpful. One other method might be using a text serialisation library e.g. ArduinoJson.").
There is no such requirement. Use a cast to get around assumptions in your code.
Post the code you use to send a packet, and we can show you how to modify the call to send anything.
sbaratheon:
I agree with @jremington, since you can write direct to the buffer the LoRa device internally uses to send a packet, there is no requirement for the data you are writing (and sending as a packet) to be in an 'array' at all.
You can do something like this
void serializePacket(struct settings *s, uint8_t *data) {
	data[0] = (uint8_t)(s->waitPeriodSecs >> 24);
	data[1] = (uint8_t)(s->waitPeriodSecs >> 16);
	data[2] = (uint8_t)(s->waitPeriodSecs >> 8);
	data[3] = (uint8_t)s->waitPeriodSecs;
	data[4] = (uint8_t)(s->epoch >> 24);
	data[5] = (uint8_t)(s->epoch >> 16);
	data[6] = (uint8_t)(s->epoch >> 8);
	data[7] = (uint8_t)s->epoch;
	uint8_t n = 8;
	uint8_t i;
	for (i = 0; i < 10; i++) {
		data[n++] = s->callsign[i];
void deserializePacket(struct settings *s, uint8_t *data) {
	s->waitPeriodSecs = (uint32_t)((data[0] << 24) | (data[1] << 16) | (data[2] << 8) | data[3]);
	s->epoch = (uint32_t)((data[4] << 24) | (data[5] << 16) | (data[6] << 8) | data[7]);
	uint8_t n = 8;
	uint8_t i;
		s->callsign[i] = data[n++];
I've not compiled this or tested this at all, but it should give you an idea of how you could do it. This takes care of the endianness issue. It also result in a much smaller payload than your text based approach.
jremington:
Ok, thanks. I use the following to send a message:
bool sendText(const char* msg)
    DEBUG("Sending Message: ");
    DEBUG_NL(msg);
    if (strlen(msg) > MAX_LORA_PACKET)
      return false;
    if ( !remoteStationRadio.beginPacket() )
        return false;
    remoteStationRadio.print(msg); // prints up to, but not including, the null symbol
    if ( !remoteStationRadio.endPacket() )
        return false;
    return true;
I'm using this library in case it helps.
One of many approaches to sending a struct would be to replace this line in the above
with
    remoteStationRadio.write( (uint8_t *) &name_of_struct, sizeof(name_of_struct)); // send the struct
(this actually works for any type of variable, not just structs).
Substitute "name_of_struct" with whatever you call your struct. Of course, you will need to make the struct accessible to the sending function, either in the argument list, or as a global variable.
I would probably write a separate function, named something like sendBinary(), along the lines of the existing function sendText(), but with an additional argument giving the message size in bytes.
jremington:
with
I would probably write a separate function, named something like sendStruct(), along the lines of the existing function sendText(), but with an additional argument giving the message size in bytes.
Thanks very much.
As I understand it, this effectively casts the struct (or any other object) to a byte array. For my own learning, please could you explain how this avoids the padding issue (srnet's post #4 above)?
Padding is only an issue if you are mixing processor architectures, which leads to many other problems as well. An "int" could have one, two or four bytes, for example.
If you plan on using several different node architectures, then a human readable text-based message protocol can be cost effective, and it makes debugging and long term data storage easier.
You might even consider XML, for which there is an Arduino parser called tinyXML.
