@LillSlick
You should check out my robot at Kickstarter: http://www.kickstarter.com/projects/tkjelectronics/balanduino-balancing-robot-kit.
The source code is available at Github: Balanduino/Firmware/Balanduino at master · TKJElectronics/Balanduino · GitHub. It will pretty much answer all your questions ![]()
WOW thanks for the reply on such a short notice! Your code is very elaborate, youre very thorough. I dont need complicated stuff, only want to balance the damn thing
no time for other stuff, i have to present my work in 4 days or else im screwed, it is my first robotics project, im an automation engineer and this project was proposed by my boss and was stupid enough to tell a deadline without even having the hardware, they gave me all the hardware 3-4 days ago and they said 1week ... so now after ive done the phisical part i would like to get the code done, ill use your data acquisition and kalman filtering and i have to get the motors to balance the robot. I had a look on your code and saw you have much control over the motors, im not using the encoders, i dont care if one of the wheels will have a different caracteristic, plus im using two PmodHB5 h-bridges, the pins: Dir/En/Vcc/GND ive merged them and i thoat ill send the same command for them all, if dir is 1, only 1 pin is high and bolth h-bridges should behave in the same manner, and the PWM is the same for both ill send 1 pwm to 1 pin which runs both h-bridges at the same time... thats what i thoat, and wanna get this sorted as soon as possible so i dont get buttfucked by my bosses :)). Its kinda hard putting up with 10 hours of work and after that, concentrate on the "other project" but they dont care. Can u have some pointers, how should i implement a simplified version of ur code so that the robot balances itsself based on the kalman calculus uve done in the mpu6050 file and thats about it... is it complicated? jasons done some cool stuff with the motor control, he has an if decision there which does two types of commands for the motors, one aggressive command and one conservative command, thats kinda nice but i wont have the time to experiment with it. So, i only need the basics working, after that, ill build on it as you built on your own project which frankly is a super-project! Im very interested in this project, i love it, i want to take it to a whole new level, but for my own, not for some fool who thinks hes gonna unemploy me. Sorry for misspelling ive done so far, hope you can give me some pointers :). Thanks! Best regards, Cata PS: ill post the code i was talking about ![]()
BalancingRobot.rar (4.11 KB)
@LillSlick
You should take a look at the old version of the code here: GitHub - TKJElectronics/BalancingRobotArduino: This is the Arduino version of the code for my balancing robot/segway, but basically you can just comment out these lines: Balanduino/Balanduino.ino at master · TKJElectronics/Balanduino · GitHub and then remove all the code related to the encoders. I would recommend that.
But you really need to work hard all weekend to make it in 4 days! It should be possible to make it balance if your hardware is alright.
This was my first attempt to make a balancing robot: TKJ Electronics » Sneak Peak: Segway guide + code. It didn't use the encoders - you might want to take a look at the source code below the video.
I just looked at Jason's robot: transistor.io, but he using a servo. I'm using a brushed DC motor.
How long are you? Have you build the entire hardware and checked that all hardware is working as intended? It's important that you get the basics like the IMU, motor and all the other stuff working before you start writing the software to make it balance.
I got all the hardware done, the H-Bridges and motors are working correctly, the mechanical part is balanced(almost standing on its own) wiring is done, the only thing i need to do is code. ill attach some pictures i took while building it, theyre not the final product as it looks now, but it should give you an idea :). Thanks for the pointers, i`ll get right on it!
The pictures are a little to big for the forum so i`ll share them like this:
https://dl.dropboxusercontent.com/u/40769383/20130623_190515.png
https://dl.dropboxusercontent.com/u/40769383/20130627_005027.png
https://dl.dropboxusercontent.com/u/40769383/20130702_120216.jpg
Looks alright. Maybe a little to wide and what's up with that big cable box on the middle level? Is there anything inside it? ![]()
Any progress with the code?
I also noticed that you actually got encoders on those motors. If you have time I would recommend implementing them as well ![]()
yes thats my power box, i got a battery in there 9V one, i dont know if its going to be enough... i hope so! with the code, ive tried some stuff, but i think i messed it up when I choose to command both Enable pins and Direction pins through the same pin, for the Enable the pin number 3 and for the Direction - pin number 1 on the arduino UNO. I`m using PmodHB5 drivers, up to 2A. I was using this code, your example for collecting and filtering data and my stupid coding :)) :
Kristian Lauszus, TKJ Electronics
Web : http://www.tkjelectronics.com
e-mail : kristianl@tkjelectronics.com
#include <Wire.h>
#include "Kalman.h" // Source: https://github.com/TKJElectronics/KalmanFilter
#define APWM 3 // left motor PWM
//#define RPWM 10 // right motor PWM
#define ADIR 1 // left motor direction
//#define RDIR 12 // right motor direction
#define KP 0.5 // proportional controller gain [LSB/deg/loop]
#define KD 0.5 // derivative controller gain [LSB/deg/loop]
Kalman kalmanX; // Create the Kalman instances
Kalman kalmanY;
/* IMU Data */
int16_t accX, accY, accZ;
int16_t tempRaw;
int16_t gyroX, gyroY, gyroZ;
double accXangle, accYangle; // Angle calculate using the accelerometer
double temp; // Temperature
double gyroXangle, gyroYangle; // Angle calculate using the gyro
double compAngleX, compAngleY; // Calculate the angle using a complementary filter
double kalAngleX, kalAngleY; // Calculate the angle using a Kalman filter
uint32_t timer;
uint8_t i2cData[14]; // Buffer for I2C data
float output = 0.0;
// Make sure all motor controller pins start low.
digitalWrite(APWM, LOW);
// digitalWrite(RPWM, LOW);
digitalWrite(ADIR, LOW);
// digitalWrite(RDIR, LOW);
// Set all motor control pins to outputs.
pinMode(APWM, OUTPUT);
// pinMode(RPWM, OUTPUT);
pinMode(ADIR, OUTPUT);
// pinMode(RDIR, OUTPUT);
pinMode(13, OUTPUT);
Wire.begin();
i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz
i2cData[1] = 0x00; // Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling
i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s
i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g
while(i2cWrite(0x19,i2cData,4,false)); // Write to all four registers at once
while(i2cWrite(0x6B,0x01,true)); // PLL with X axis gyroscope reference and disable sleep mode
while(i2cRead(0x75,i2cData,1));
if(i2cData[0] != 0x68) { // Read "WHO_AM_I" register
Serial.print(F("Error reading sensor"));
while(1);
delay(100); // Wait for sensor to stabilize
/* Set kalman and gyro starting angle */
while(i2cRead(0x3B,i2cData,6));
accX = ((i2cData[0] << 8) | i2cData[1]);
accY = ((i2cData[2] << 8) | i2cData[3]);
accZ = ((i2cData[4] << 8) | i2cData[5]);
// atan2 outputs the value of -π to π (radians) - see http://en.wikipedia.org/wiki/Atan2
// We then convert it to 0 to 2π and then from radians to degrees
accYangle = (atan2(accX,accZ)+PI)*RAD_TO_DEG;
accXangle = (atan2(accY,accZ)+PI)*RAD_TO_DEG;
kalmanX.setAngle(accXangle); // Set starting angle
kalmanY.setAngle(accYangle);
gyroXangle = accXangle;
gyroYangle = accYangle;
compAngleX = accXangle;
compAngleY = accYangle;
timer = micros();
/* Update all the values */
while(i2cRead(0x3B,i2cData,14));
tempRaw = ((i2cData[6] << 8) | i2cData[7]);
gyroX = ((i2cData[8] << 8) | i2cData[9]);
gyroY = ((i2cData[10] << 8) | i2cData[11]);
gyroZ = ((i2cData[12] << 8) | i2cData[13]);
double gyroXrate = (double)gyroX/131.0;
double gyroYrate = -((double)gyroY/131.0);
gyroXangle += gyroXrate*((double)(micros()-timer)/1000000); // Calculate gyro angle without any filter
// gyroYangle += gyroYrate*((double)(micros()-timer)/1000000);
//gyroXangle += kalmanX.getRate()*((double)(micros()-timer)/1000000); // Calculate gyro angle using the unbiased rate
//gyroYangle += kalmanY.getRate()*((double)(micros()-timer)/1000000);
//compAngleX = (0.93*(compAngleX+(gyroXrate*(double)(micros()-timer)/1000000)))+(0.07*accXangle); // Calculate the angle using a Complimentary filter
//compAngleY = (0.93*(compAngleY+(gyroYrate*(double)(micros()-timer)/1000000)))+(0.07*accYangle);
kalAngleX = kalmanX.getAngle(accXangle, gyroXrate, (double)(micros()-timer)/1000000); // Calculate the angle using a Kalman filter
//kalAngleY = kalmanY.getAngle(accYangle, gyroYrate, (double)(micros()-timer)/1000000);
timer = micros();
//temp = ((double)tempRaw + 12412.0) / 340.0;
// PD controller.
output += kalAngleX * KP + gyroXrate * KD;
// Clip as float (to prevent wind-up).
if(output < -255.0) { output = -255.0; }
if(output > 255.0) { output = 255.0; }
if(kalAngleX > 3) {
digitalWrite(ADIR, HIGH);
analogWrite(APWM,output);
if(kalAngleX > 300) {
/* Print Data */
Serial.print(accX);Serial.print("\t");
Serial.print(accY);Serial.print("\t");
Serial.print(accZ);Serial.print("\t");
Serial.print(gyroX);Serial.print("\t");
Serial.print(gyroY); Serial.print("\t");
Serial.print(gyroZ);Serial.print("\t");
Serial.print(accXangle);Serial.print("\t");
Serial.print(gyroXangle);Serial.print("\t");
//Serial.print(compAngleX);Serial.print("\t");
Serial.print(kalAngleX);Serial.print("\t");
Serial.print(output);Serial.print("\t");
Serial.print("\t");
// Serial.print(accYangle);Serial.print("\t");
// Serial.print(gyroYangle);Serial.print("\t");
// Serial.print(compAngleY); Serial.print("\t");
// Serial.print(kalAngleY);Serial.print("\t");
//Serial.print(temp);Serial.print("\t");
Serial.print("\r\n");
delay(1);
Based on your mpu6050 example for data filtering and i added some lines to make something move ![]()
The wheels go in separate directions... it doesnt balance its self. Im going through your code now, im commenting the parts with the encoders and EEPROM readings and all the stuff that stands for the BT, PS3, WII so on... In the baladuino library ive modified the ports, i`m using pin 3 for the pwm and pin 1 for the enable signal that means portD,
/* Left motor */
#define leftPort PORTD // a fost #define leftPort PORTC
#define leftPortDirection DDRD
#define leftA PINC6 // PC6 - M1A - pin 23
#define leftB PINC7 // PC7 - M1B - pin 24
#define leftPWM PIND2 // a fost #define leftPWM PIND5 // PD5 - PWM1A (OC1A) - pin 18
/* Right motor */
#define rightPort PORTD
#define rightPortDirection DDRD
#define rightA PINB0 // PB0 - M2A - pin 25
#define rightB PINB1 // PB1 - M2B - pin 26
#define rightPWM PIND4 // same as my pin 5 --> PD4 - PWM1B (OC1B) - pin 17
/* Pins connected to the motor drivers enable pins */
const uint8_t leftEnable = 1; // was const uint8_t leftEnable = 21;
//const uint8_t leftEnable = 4; // was const uint8_t rightEnable = 22;
One question until now : targetAngle - you said " the resting angle of the robot" <=== where do i find that? gyro reading? and when the robot is balancing or?
So now i`m going through your code and making something much more simpler, only to balance the robot.
I agree with you on the Encoders, I will implement them, but not now... first i want to show them a simple thing, then i can work on it to get the complicated stuff
make a REAL balancing robot.
I still need to figure out how this works
/* Set PWM frequency to 20kHz - see the datasheet http://www.atmel.com/Images/doc8272.pdf page 128-135 */
// Set up PWM, Phase and Frequency Correct on pin 18 (OC1A) & pin 17 (OC1B) with ICR1 as TOP using Timer1
TCCR1B = _BV(WGM13) | _BV(CS10); // Set PWM Phase and Frequency Correct with ICR1 as TOP and no prescaling
ICR1H = (PWMVALUE >> 8); // ICR1 is the TOP value - this is set so the frequency is equal to 20kHz
ICR1L = (PWMVALUE & 0xFF);
/* Enable PWM on pin 18 (OC1A) & pin 17 (OC1B) */
// Clear OC1A/OC1B on compare match when up-counting
// Set OC1A/OC1B on compare match when downcounting
TCCR1A = _BV(COM1A1) | _BV(COM1B1);
setPWM(leftPWM,0); // Turn off pwm on both pins
setPWM(rightPWM,0);
and how to do it for arduino uno and for my pins ![]()
getting this strange error.. dunno wtf to do about it ![]()
In file included from Schita001.ino:2:
Balanduino.h:59: error: redefinition of 'const uint8_t leftEnable'
Balanduino.h:58: error: 'const uint8_t leftEnable' previously defined here
Schita001:11: error: 'Kalman' does not name a type
Schita001.ino: In function 'void setup()':
Schita001:18: error: 'rightEnable' was not declared in this scope
Schita001:75: error: 'kalman' was not declared in this scope
Schita001.ino: In function 'void loop()':
Schita001:118: error: 'kalman' was not declared in this scope
Schita001:125: error: 'kalman' was not declared in this scope
Motor.ino: In function 'void moveMotor(Command, Command, double)':
Motor:9: error: 'PINC7' was not declared in this scope
Motor:13: error: 'PINC7' was not declared in this scope
Motor.ino: In function 'void stopMotor(Command)':
Motor:32: error: 'PINC7' was not declared in this scope
with the code based on the data acquisition and something to get the motors moving i get some results but the Output of the PD controller is not very good... i`ll attach a file so you can take a look.
Sensors.txt (74.2 KB)
You are using an Uno (ATmega328P), right?
Then pin 3 is located on PIND3 and not PIND2.
See this page for more information: http://arduino.cc/en/Hacking/PinMapping168.
Target angle is the balancing point of the robot - this is usually 180, but you might have to change it if you CG is offset to either side. I used that when I mounted a GoPro on mine: http://www.kickstarter.com/projects/tkjelectronics/balanduino-balancing-robot-kit/posts/450808.
Regarding the PWM registers. You should read the datasheet: http://www.atmel.com/Images/Atmel-8271-8-bit-AVR-Microcontroller-ATmega48A-48PA-88A-88PA-168A-168PA-328-328P_datasheet.pdf at page 128 to 138.
This error is caused because you are defining the same varaible twice:
Try renaming one of them two "rightEnable":
You need to download the Kalman library I wrote: GitHub - TKJElectronics/KalmanFilter: This is a Kalman filter used to calculate the angle, rate and bias from from the input of an accelerometer/magnetometer and a gyroscope..
PINC7 is not available is on the ATmega328P:
Simply uncomment it for now.
Regarding the "Sensors.txt". Please tell me what is the output from each column or I will not be able to help you ![]()
Yes 328 it is, my CG is as much as possible on the middle part, it's pretty well balanced, i wrote the columns but as i recon they didnt save... so its like this: accX/gyroX/KalmanXangle/PD output
i'll try the mods u've suggested, the pwm values are the same for mine to, right?
and one more thing the PmodHB5 doesn't give information on the max frequency, how do i find it? i saw ur's is 20kHz... i dunno my max...
Hmm that doesn't look right. Are you using the example code I wrote?
The PWM value is the same, it will automatically scale the value from 0-100 to 0-PWMVALUE: Balanduino/Motor.ino at master · TKJElectronics/Balanduino · GitHub.
The PWMVALUE is set automatically here: Balanduino/Balanduino.h at master · TKJElectronics/Balanduino · GitHub.
You will need to look in the datasheet. After that change this value: Balanduino/Balanduino.h at master · TKJElectronics/Balanduino · GitHub to the desired frequency.
hey, i made a stupid version starting from the data acquisition code you provided
they wanted to see my progress so ... now i have until Thursday to finish, and one of them was so impressed hes gonna send me tomorrow to do some work 210 KM away from home, just to be sure i dont finish on time. This said, ill show u my code, ill have to implement that motor control of yours, i hope i`ll succeed.
Lemme show you how it works until now :
And my stupid code is:
#include <Wire.h>
#include <PID_v1.h>
#define LPWM 3 // left motor PWM
#define RPWM 5 // right motor PWM
#define LDIR 4 // left motor direction
#define RDIR 7 // right motor direction
#define KP 5 // proportional controller gain [LSB/deg/loop]
#define KD 2.5 // derivative controller gain [LSB/deg/loop]
#define W_radius 0.0035 // meters
#define minOutput 0
#define maxOutput 250
Kalman kalmanY;
/* IMU Data */
int16_t tempRaw;
double velocity;
double Setpoint = 0, Input, Output;
double aggKp=8, aggKi=0.5, aggKd=2;
double consKp=4, consKi=0.02, consKd=1;
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
uint32_t timer;
float output = 0.0;
digitalWrite(LPWM, LOW);
digitalWrite(LDIR, LOW);
pinMode(LPWM, OUTPUT);
pinMode(LDIR, OUTPUT);
// PID library
myPID.SetOutputLimits(minOutput,maxOutput);
myPID.SetSampleTime(1);
myPID.SetMode(AUTOMATIC);
// Serial.begin(115200);
Wire.begin();
while(1);
// atan2 outputs the value of -? to ? (radians) - see http://en.wikipedia.org/wiki/Atan2
// We then convert it to 0 to 2? and then from radians to degrees
timer = micros();
accY = ((i2cData[2] << 8) | i2cData[3])/1000;
timer = micros();
velocity = accY/W_radius;
Input = velocity;
double sens = Setpoint-Input;
if(sens>1)
myPID.SetControllerDirection(DIRECT);
else if(sens<-1)
myPID.SetControllerDirection(REVERSE);
double gap = abs(Setpoint-Input);
if(gap<10)
myPID.SetTunings(consKp, consKi, consKd);
myPID.SetTunings(aggKp, aggKi, aggKd);
myPID.Compute();
// Output = map(Output, 0, 1000, 0, 255);
if(Output<minOutput+20){ Output=0; }
if(sens>=0)
digitalWrite(RDIR, HIGH);
analogWrite(LPWM,Output);
analogWrite(RPWM,Output);
digitalWrite(LDIR, HIGH);
delay(1);
Its not good, but ... it does SOMETHING, as you can observe im not using the kalman angle, i loaded that library but the code does not work it always gives me error at that single line :
#include <Kalman.h> // Kalman filter library - see:...
So, im making progress, but i really need to set that speed, and controller you recommended. Ill get right on it, i have 2 hours until i have to go to sleep because i`m awfully tired. Keep in touch, what do you say about my code? stupid huh? :))
You should use either the complimentary or Kalman filter or you won't be able to make it balance!
Sounds like you are not that happy about your co-workers?
What is your profession?
See the following example on how to include the Kalman library: https://github.com/TKJElectronics/Example-Sketch-for-IMU-including-Kalman-filter/tree/master/IMU6DOF/MPU6050.
The simply is to simply add it next to the .ino file and then add it like so: https://github.com/TKJElectronics/Example-Sketch-for-IMU-including-Kalman-filter/blob/master/IMU6DOF/MPU6050/MPU6050.ino#L19.
Hope you will get it working before your deadline!
i'm in the automation department, but the people are envious... i'm still getting that error when i create the Kalman instance at line 43,not at the include line, i'll be working on the robot later... now i'm 200km away, if you would be kind to keep an eye on the forum i will appreciate your effort! or if you have an instant messaging possibility that would be great
i'll catch up with you later, when I get home. thanks a lot for doing this, i would be nothing without your help!
Okay. That's because you haven't included it properly for some reason. Either put it next to the ino file and include it like so:
#include "Kalman.h"
Or put it in your libraries folder as any other Arduino library and include it like so:
#include <Kalman.h>
You can find me on Google Plus. Simply just search for Kristian Lauszus ![]()
Glad you appreciate my help!
Hi Kristian ! First of all thank you a lot for your guide ! It is really helpful.
I am a french student in an engeneering school and I am using the crius aiop v2 on my robot. On this board there is an MPU6050 and I am communicating with it thanks to your code. I tested a lot of codes like the one on arduino playground but yours is definetely the best.
However I am still having some issues with this sensor...
Correct me if I am wrong but when I am reading the raw data for the accelerometer I am supposed to get for x, y and z : 0 , 0 and 0.98 right ?
However when I am just reading the right registers (my sensor is put still on my desk) I am getting those values instead :
accX accY accZ
8324.00 4768.00 14496.00
8208.00 4768.00 14536.00
8216.00 4704.00 14296.00
8288.00 4684.00 14608.00
8356.00 4724.00 14464.00
8372.00 4784.00 14588.00
8280.00 4736.00 14408.00
8332.00 4748.00 14356.00
Since I am using your code, the sensor is set on a scale range of +/-2g which means that the sensitivity of the accelerometer is of 16384 LSB/g. I know that to understand the raw datas I need to divide them with the sensitivity and get something near 0, 0, 0.98 even if there is an error.
However with the values I am having it is no where near from what it should be...
I tried the code from arduino playground and I am having the same raw datas... Your guide is really clear but I must be missing something... I am just reading the right registers but those raw datas doesn't make any sense at all...
So I would like to know if you think those datas are strange and if you happened to find something similar, I happened to find some talk on the internet which says that there is a version of the MPU6050 that doesn't have the same scale ranges and not the same sensitvities... I don't think I have that much of bad luck...
Thank you for your help,
Ben.
Hi everybody!
I'm using Lsm303.it include accelerometer and magnetometer.And i want to use accelerometer to estimate velocity but this is very noise.Can i combine
accelerometer and magnetometer into kalman filter to filter the signal of accelerometer.Thank!
@Ben91
No the raw data is not in g's, but a 16-bit signed value. See the datasheet: http://www.invensense.com/mems/gyro/documents/PS-MPU-6000A.pdf page 13.
So if you are using a range of +-2 it means that you must divide the value by 16384 to convert it into g's.
@hnk1412
No I don't believe it's possible to estimate the velocity like that without a lot of noise. You might be better of with using a GPS sensor.
Hey, great guide! I've been following it at the very early stage of a quadcopter build.
The accelerometer seems to be working fine but I'm having a bit of trouble with the gyroscope values. They don't seem to make sense, they don't go below 0 when spun counterclockwise.
Would someone mind looking through my code and seeing if anything doesn't look right?
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#include <Wire.h>
#include <Servo.h>
// I2Cdev and L3G4200D must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include <I2Cdev.h>
#include <L3G4200D.h>
#include <HMC5883L.h>
#include <ADXL345.h>
// default address is 105
// specific I2C address may be passed here
L3G4200D gyro;
ADXL345 accel;
HMC5883L mag;
int16_t magX, magY, magZ;
int16_t accValX, accValY, accValZ;
float accBiasX, accBiasY, accBiasZ;
float accAngleX, accAngleY;
float R;
float gyroBiasX, gyroBiasY, gyroBiasZ;
float gyroRateX, gyroRateY, gyroRateZ;
float gyroBias_oldX, gyroBias_oldY, gyroBias_oldZ;
float pitchComp, rollComp;
double t_0, t_1;
const float alpha = 0.5;
Servo magYservo; // create servo object to control a servo
int val = 0; // variable to read the value from the analog pin
int throttle = 0;
double gyro_sensitivity = 70; //From datasheet, depends on Scale, 2000DPS = 70, 500DPS = 17.5, 250DPS = 8.75.
void setSpeed(int speed, int throttle){
int angle = map(speed, 0, 80, 59, 133);
magYservo.write(angle + throttle);
//Serial.println(angle);
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
// initialize serial communication
// (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
// it's really up to you depending on your project)
Serial.begin(14400);
magYservo.attach(9);
setSpeed(0, 0);
// initialize device
//Serial.println("Initializing I2C devices...");
gyro.initialize();
accel.initialize();
mag.initialize();
// verify connection
// Serial.println("Testing device connections...");
// Serial.println(accel.testConnection() ? "ADXL345 (accelerometer) connection successful" : "ADXL345 (accelerometer) connection failed");
// Serial.println(mag.testConnection() ? "HMC5883L (magnetometer) connection successful" : "HMC5883L (magnetometer) connection failed");
// Serial.println(gyro.testConnection() ? "L3G4200D (gyro) connection successful" : "L3G4200D connection failed");
// data seems to be best when full scale is 2000
gyro.setFullScale(2000);
// Calculate bias for the Gyro i.e. the values it gives when it's not moving
for(int i=1; i < 100; i++){
gyroBiasX += gyro.getAngularVelocityX();
gyroBiasY += gyro.getAngularVelocityY();
gyroBiasZ += gyro.getAngularVelocityZ();
accBiasX += accel.getAccelerationX();
accBiasY += accel.getAccelerationY();
accBiasZ += accel.getAccelerationZ();
delay(1);
gyroBiasX = gyroBiasX / 100;
gyroBiasY = gyroBiasY / 100;
gyroBiasZ = gyroBiasZ / 100;
accBiasX = accBiasX / 100;
accBiasY = accBiasY / 100;
accBiasZ = accBiasZ / 100;
// Calculate true sensitivity
gyro_sensitivity = ((gyro_sensitivity/1000)/3.3)*1023; //16-bit resolution gyro. 2^16-1 = 65535
t_0 = millis();
// Accelerometer //
double accPitch, accRoll;
accel.getAcceleration(&accValX, &accValY, &accValZ);
R = sqrt(sq(accValX)+sq(accValY)+sq(accValZ));
accPitch = acos(accValX/R)*RAD_TO_DEG-90;
accRoll= -acos(accValY/R)*RAD_TO_DEG-90;
// Seems to do the same as above
// accPitch = -(atan2(accValX, sqrt(accValY*accValY + accValZ*accValZ))*180)/M_PI;
// accRoll = (atan2(-accValY, accValZ)*180)/M_PI;
if(accValZ < 0)//360 degrees
if(accPitch < 0)
accPitch = -180-accPitch;
accPitch = 180-accPitch;
if(accRoll < 0)
accRoll = -180-accRoll;
accRoll = 180-accRoll;
// GYRO //
double gyroPitch, gyroRoll;
// read raw angular velocity measurements from device
gyro.getAngularVelocity(&gyroX, &gyroY, &gyroZ);
gyroRateX = (gyroX - gyroBiasX)/gyro_sensitivity;
gyroRateY = (gyroY - gyroBiasY)/gyro_sensitivity;
t_1 = millis();
gyroPitch += gyroRateX * (t_1 - t_0)/1000;
gyroRoll += gyroRateY * (t_1 - t_0)/1000;
t_0 = millis();
// MAGNOMETER //
mag.getHeading(&magX, &magY, &magZ);
//Heading Estimation
float magYaw = atan2(magY, magX);
if(magYaw < 0)
magYaw += 2 * M_PI;
magYaw = (magYaw*180)/M_PI;
//Complementary Filter
pitchComp = 0.98 *(pitchComp+gyroPitch) + 0.02 *accPitch;
rollComp = 0.98 *(rollComp+gyroRoll) + 0.02 * accRoll;
Serial.print(accPitch);
Serial.print(",");
Serial.print(accRoll);
Serial.print(",");
Serial.print(magYaw);
Serial.print("\n");
if (Serial.available()) {
throttle = Serial.parseInt();
setSpeed(accPitch, throttle);
delay(50);
@gerry87
Please send me a link to the library you are using, so I can see the code.
Also please see this code: https://github.com/TKJElectronics/Example-Sketch-for-IMU-including-Kalman-filter/blob/master/IMU6DOF/MPU6050/MPU6050.ino. It's shows a better way to calculate the angle using the accelerometers.
Lauszus:
@gerry87
Please send me a link to the library you are using, so I can see the code.Also please see this code: https://github.com/TKJElectronics/Example-Sketch-for-IMU-including-Kalman-filter/blob/master/IMU6DOF/MPU6050/MPU6050.ino. It's shows a better way to calculate the angle using the accelerometers.
i2cdevlib/Arduino at master · jrowberg/i2cdevlib · GitHub here is the library, and here's the specific one for the L3G4200D i2cdevlib/Arduino/L3G4200D at master · jrowberg/i2cdevlib · GitHub
The better way you mention to calculate the angle is it:
Thanks, I'll try it when I get back home. Does this account for the 360 degrees (inverted)?
