Guru Meditation Error: Core 1 panic'ed (StoreProhibited)
#include "LCD_Test.h"
#include <WiFi.h>
#include <PubSubClient.h>
// WiFi credentials
const char* ssid = "";
const char
password = "
IPAddress server(
// Constants for LCD
const UWORD Imagesize = LCD_1IN28_HEIGHT * LCD_1IN28_WIDTH * 2;
UWORD *BlackImage; //pointer to point to a dynamically allocated arraye for image data
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
WiFiClient espClient;
PubSubClient client(espClient);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
Serial.println("MQTT connected. IP: ");
if (client.connect("arduinoClient")) {
Serial.println("connected");
client.subscribe("inTopic");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000);
// Timer variables
unsigned long previousMillis = 0;
const long interval = 200; // interval to collect data (milliseconds)
// Data collection variables
const int numReadings = 10; // Number of readings to collect
float accReadingsX[numReadings];
float accReadingsY[numReadings];
float accReadingsZ[numReadings];
float gyroReadingsX[numReadings];
float gyroReadingsY[numReadings];
float gyroReadingsZ[numReadings];
int readIndex = 0; // Index for storing readings
//Serial.println("Starting setup...");
// PSRAM Initialize
if (psramInit()) {
Serial.println("PSRAM is correctly initialized");
Serial.println("PSRAM not available");
if ((BlackImage = (UWORD *)ps_malloc(Imagesize)) == NULL){ //dynamic mem allocation
Serial.println("Failed to allocate memory for BlackImage");
exit(0);
// Module Initialization
if (DEV_Module_Init() != 0){
Serial.println("GPIO Init Fail!");
Serial.println("GPIO Init successful!");
// Initialize and clear the LCD
LCD_1IN28_Init(HORIZONTAL);
LCD_1IN28_Clear(WHITE);
// Create a new image cache and fill it with white
Paint_NewImage((UBYTE *)BlackImage, LCD_1IN28.WIDTH, LCD_1IN28.HEIGHT, 0, WHITE);
Paint_SetScale(65);
Paint_SetRotate(ROTATE_0);
Paint_Clear(WHITE);
// Display "Connecting to WiFi..." on the screen
//Paint_DrawString_EN(50, 120, "Connecting to WiFi...", &Font20, BLACK, WHITE);
//LCD_1IN28_Display(BlackImage);
Serial.println("LCD Initialized and message displayed.");
QMI8658_init();
Serial.println("QMI8658_init\r\n");
Serial.println(server);
//print(server)
client.setServer(server, 1883);
client.setCallback(callback);
// Set the buffer size to handle larger payloads
client.setBufferSize(8192);
Serial.print("Connecting to: ");
Serial.println(ssid);
// Connect to WiFi
WiFi.begin(ssid, password);
 Serial.print(".");
Serial.println("WiFi connected. IP: ");
delay(1500);
// Clear the screen and display WiFi connected message
Paint_Clear(WHITE);
Paint_DrawString_EN(50, 120, "WiFi connected", &Font20, BLACK, WHITE);
Serial.println("WiFi connected and message displayed.");
if (currentMillis - previousMillis >= interval) {
if (!client.connected()) {
  reconnect();
// Collect sensor data
float acc[3], gyro[3];
QMI8658_read_xyz(acc, gyro, NULL);
// Store the readings
if (readIndex < numReadings) {
  accReadingsX[readIndex] = acc[0];
  accReadingsY[readIndex] = acc[1];
  accReadingsZ[readIndex] = acc[2];
  gyroReadingsX[readIndex] = gyro[0];
  gyroReadingsY[readIndex] = gyro[1];
  gyroReadingsZ[readIndex] = gyro[2];
  readIndex++;
// If enough readings are collected, create and send the JSON message
if (readIndex >= numReadings) {
  char msg[1024];  // Adjust buffer size as needed
  snprintf(msg, sizeof(msg), "{\"accelerometer\":{\"accX\":[");
  for (int i = 0; i < readIndex; i++) {
    char temp[16]; // Buffer to store each reading as a string
    snprintf(temp, sizeof(temp), "%.2f", accReadingsX[i]);
    strncat(msg, temp, sizeof(msg) - strlen(msg) - 1);
    if (i < readIndex - 1) strncat(msg, ",", sizeof(msg) - strlen(msg) - 1);
  strncat(msg, "],\"accY\":[", sizeof(msg) - strlen(msg) - 1);
    char temp[16];
    snprintf(temp, sizeof(temp), "%.2f", accReadingsY[i]);
  strncat(msg, "],\"accZ\":[", sizeof(msg) - strlen(msg) - 1);
    char temp[16];
    snprintf(temp, sizeof(temp), "%.2f", accReadingsZ[i]);
  strncat(msg, "]},\"gyroscope\":{\"gyrX\":[", sizeof(msg) - strlen(msg) - 1);
    char temp[16];
    snprintf(temp, sizeof(temp), "%.2f", gyroReadingsX[i]);
  strncat(msg, "],\"gyrY\":[", sizeof(msg) - strlen(msg) - 1);
    char temp[16];
    snprintf(temp, sizeof(temp), "%.2f", gyroReadingsY[i]);
  strncat(msg, "],\"gyrZ\":[", sizeof(msg) - strlen(msg) - 1);
    char temp[16];
    snprintf(temp, sizeof(temp), "%.2f", gyroReadingsZ[i]);
  strncat(msg, "]}}", sizeof(msg) - strlen(msg) - 1);
  Serial.print("sensorData: ");
  Serial.println(msg);
  bool success = false;
  for (int attempt = 0; attempt < 3; attempt++) {  // Try publishing up to 3 times
    if (client.publish("IoTPRISMLAB_sensorData", msg)) {
      Serial.println("Data sent to MQTT");
      //Serial.println("MQTT connected. IP: ");
      success = true;
      Serial.println("Failed to send data to MQTT");
      Serial.print("MQTT state: ");
      Serial.println(client.state());
      delay(1000);  // Wait 1 second before retrying
  if (!success) {
    Serial.println("All attempts to send data to MQTT failed.");
  readIndex = 0; // Reset read index for the next batch of readings
client.loop();
I want to measure acc and gyro on esp32/s3 and turn on the lcd for data aquisition and transfer the data via wifi but i receive the error :Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
You posted your network's SSID and Password in your code.
For reasons of your security, this type of information in the forum is not recommended.
Use *** in place of both information.
Many thanks for mentioning.
