Hello, good evening, I am encountering such an error while trying to install esp32 microcontroller software. I would be very grateful if you could help me with this. Here is the code I am trying to install and the error I get.
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_TEMPLATE_NAME ""
#define BLYNK_AUTH_TOKEN ""
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "";
char pass[] = "";
// Debug console
Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass);
// You can also specify server:
//Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, "blynk.cloud", 80);
//Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, IPAddress(192,168,1,100), 8080);
Blynk.run();
// You can inject your own code or combine it with other sketches.
// Check other examples on how to communicate with Blynk. Remember
// to avoid delay() function!
ELF file SHA256: 00ca12905de1869b
E (388) esp_core_dump_flash: Core dump flash config is corrupted! CRC=0x7bd5c66f instead of 0x0
E (397) esp_core_dump_elf: Elf write init failed!
E (401) esp_core_dump_common: Core dump write failed with error=-1
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4832
load:0x40078000,len:16460
load:0x40080400,len:4
load:0x40080404,len:3504
entry 0x400805cc
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x4008e8d6 PS : 0x00060933 A0 : 0x800906c8 A1 : 0x3ffe3680
A2 : 0x1dd0b283 A3 : 0xffffffff A4 : 0x0000cdcd A5 : 0x00060923
A6 : 0x00000002 A7 : 0x0000000b A8 : 0x3ffafff8 A9 : 0x3ffaff78
A10 : 0x3ffaff4c A11 : 0x0000004a A12 : 0x3ffaff58 A13 : 0x3f408574
A14 : 0xfffffffc A15 : 0x0000000b SAR : 0x00000020 EXCCAUSE: 0x0000001c
EXCVADDR: 0x1dd0b283 LBEG : 0x400899cc LEND : 0x400899e2 LCOUNT : 0x00000000
Backtrace: 0x4008e8d3:0x3ffe3680 0x400906c5:0x3ffe36b0 0x40171a45:0x3ffe36d0 0x40171afd:0x3ffe36f0 0x400e1293:0x3ffe3710 0x400e13c8:0x3ffe3730 0x400e0532:0x3ffe3c10 0x40082ac6:0x3ffe3c40 0x400797e5:0x3ffe3c80 |<-CORRUPTED
I knowingly deleted the required private information in the code myself for privacy
