Hi everyone
well a little useless but fun project based on a private joke between friends.
As fans of HL1 we made joke about the FX in the game applied in toilets....never bet with me xD
The system is based on my led controller board wich includes an automatic gain amplifier + spectrum analyzer chip MGSEQ7.(perfect to sense ambiance "noises"
the nano board is the heart of the system.
this project has no other function except for fun.
it includes
46 RGB leds with LPD8806 controller
1pc beacon light (with rotary motor, I did not want a standard flashing model)
1pc 4D system SOMO II MP3 files player (I've make my own library because I find nothing on the net for it) the audio files comes from the Pak0.pak from HL1 game
1pc proximity capacitive sensor to detect when the finger approach the flush
2pcs floating level sensor to know if it's a short or complete flush
1pc PIR sensing detector to know if someone is approaching
I've built the system to have a very low idle power drain (even if the nano is not built for that I've make some modification on it) and the overall current drain is only 400µA
ok I'm not a pro of the software and the code was made in two days for test my hardware but now I can work further on it xD
here some pictures
the messages are played with random order but with a link of the action. like when the flush button is pressed with "somethink stink here!" from Barney xD
the ambiant "noises" are detected and you have "radioactive warning alerts" or other random messages
the messages are in french in the video but in english when you enter you have:
The flush button is connected to a capacitive sensor chip an AT42QT1010.
it's the small SOT-23-6 chip on the picture with the green led on. it detects my finger
the sensing electrode is the white wire from the little white box with level sensors.
Hi, nice project! I' m trying to use MSGEQ7 in my project and I would like to take the sound from a MIC. Can you post the preamplifying part fot the MSGEQ7, please? I' m using the configuration below.. but I don' t know why 3 of my 4 chips doesn' t work. I don' t understand if theese 3 chips were already burned or there' s a mistake in my scheme. Thank you!
your schematic seems to be good. are your sure about the pin counting?
the electret microphone is connected with the right polarity?
the ground is connected to the ground of the msgeq7?
I can post my schematic but it use an automatic gain amplifier from analog devices in SO14 package so it will be expensive and hard to solder for your application I think. But if you really want it I will post it.
Thank you for answer. It's no necessary that you post it. It' s all ok but only one chip is working. I bought the IC's from ebay and probably these chips are not good. The only good IC work perfectly.. It' s not a problem, I need only one MSGEQ7, but in the future I will avoid that seller. Thanks again.
Thanks raschemmel, could be this the problem even if I have no idea how to cut the amplified signal to 100mV. But I don' t want to spam this nice thread with my questions.
sory for the delay of the answer but the board donn't want to send me mail notification I don't know why.
I must work on some details and a clean software but why not?
the problem is the time because I'm working on lot of projects xD
