Sorry if im posting in the wring section as im new to the forum.I just recived a 4 by 4 keypad and wired it up to arduino pins 7,6,5,4,3,2,1 and 0 then configured the library appropriately
byte rowPins[numRows] = {7,6,5,4}; //Rows 0 to 3
byte colPins[numCols]= {3,2,1,0}; //Columns 0 to 3
I also have a 1.8 inch adafruit display hooked up which works fine and i have it print key presses to the screen except only half the rows will cause a letter or number to pop up.The issue is not with being able to display only certain characters as i switched out '1' for 'd' and it printed fine.What am i doing wrong or what should i double check?
I followed this guide for getting wired up and using the library:
Full Code:
#include <Key.h>
#include <Keypad.h>
#include <Adafruit_ST7735.h>
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 4; //number of columns on the keypad
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
//Code that shows the the keypad connections to the arduino terminals
//initializes an instance of the Keypad class
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
// For the breakout, you can use any 2 or 3 pins
// These pins will also work for the 1.8" TFT shield
#define TFT_CS 10
#define TFT_RST 9 // you can also connect this to the Arduino reset
// in which case, set this #define pin to 0!
#define TFT_DC 8
// Option 1 (recommended): must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
// Option 2: use any pins but a little slower!
#define TFT_SCLK 13 // set these to be whatever pins you like!
#define TFT_MOSI 11 // set these to be whatever pins you like!
//Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
tft.initR(INITR_BLACKTAB);
tft.fillRect(0,0,tft.width(),tft.height(),ST7735_BLACK);
//If key is pressed, this key is stored in 'keypressed' variable
//If key is not equal to 'NO_KEY', then this key is printed out
//if count=17, then count is reset back to 0 (this means no key is pressed during the whole keypad scan process
char keypressed = myKeypad.getKey();
if (keypressed != NO_KEY)
tft.print(keypressed);
