Hall sensor readings at high-speed
Hello,
I've been lurking around here for abit, but I never had an account... :wink: My issue is this:
I am working on a harddrive clock (essentially the same as this one: link), however I am not using a standard hall sensor.
The hall sensor I am using is salvaged from a defunct blackberry curve 8330, which uses hall sensors for trackball input. I have confirmed that the following datasheet is correct: (link). This sheet shows that the hall sensor is capable of measuring microsecond durations at a minimum (I think). I am supplying the sensor with GND and 5V and am simply interfacing with pin5 via analog input (is this the best way?). There are no capacitors, etc on the output line.
...this is the sensor by the way, it's pretty small!
The issue I am experiencing is that with the simplest code I can write I am not getting delay times (per rotation) of under 30 ms, which is incorrect (5400 rpm == 5.5 ms per rotation).
double hall = 0, hallpre = 0;
const int baseline = 1023;
const int sensitivity = 20;
boolean state = false;
unsigned long timerotat, timerotatprev, triggertime;
  Serial.println("Welcome to Paul's HDD Clock debug output!");
  delay(100);
 timerotat=millis();              // save the current time while magnet is NOT on sensor
 hall = analogRead(A1);
 while((hall < (baseline-sensitivity)) ) //& ((millis()-triggertime)>1))  //<- use with a filter value to stop flickering stopped on sensor
   if (!state)
     digitalWrite(13,1);
     state=true;
     timerotatprev=timerotat;           //the magnet crossed the sensor, output the current value - previous for rotation time after spun-up
 state=false;
 digitalWrite(13,0);
Here is typical output once the drive is spun up at 5400 rpm.
passed in: 34ms
passed in: 34ms
passed in: 33ms
passed in: 33ms
passed in: 34ms
passed in: 34ms
passed in: 33ms
passed in: 34ms
passed in: 33ms
passed in: 34ms
passed in: 33ms
passed in: 34ms
Any help would be awesome!
That hall effect sensor is a digital sensor, it either sees a magnetic field of sufficient strength or it does not, and outputs either a 0 or +5vdc voltage, nothing in between those two voltages. You should not be reading it as a analog value, but rather use a digitalRead function. You need to time the time period between successive pulses, perhaps using the pulseIn function. I'm afraid you really need a complete rewrite of your sketch using the proper approach.
Lefty
retrolefty:
...outputs either a 0 or +5vdc voltage, nothing in between those two voltages.
Great!
I was worried about the lack of difference between the saturated reading and the unsaturated reading too (1023 -> 922 approx), didn't seem surefire enough. I'll give this a try and post back with results tomorrow using digitalRead().
Well, I ended up finding the following circuit diagram for the sparkfun breakout board which uses the same hall sensors.
(link)
I've just constructed the same circuit but was unable to get a digitalRead() of any value other than 1. The voltage still dips by approx 0.6 volts when the magnet is nearby though. Is there any reason that I cannot just digitalRead() from the sensor with the output pulled up to Vcc? I'm polling it constantly for pulses so interrupts shouldn't matter at this point right?
What value resistor are you using to pull-up the sensor output pin to Vcc?
Lefty
retrolefty:
I'm using a 10k resistor at the moment, I also attached a 0.1 uf capacitor on the VCC and GND lines to no avail.
vapour:
retrolefty:
Can you post your code, showing how you are doing the digitRead() for this sensor?
Lefty
retrolefty:
I'd love to! (I've removed commented out lines)
void setup(){
void loop(){
  Serial.println(String(digitalRead(9)));
I was just hoping that I'd be able to poll it this way, not sure if I need to implement pulsein() to read the sensor.
