"Hanging" ThingsSpeak ethernet sketch
Hi everyone
I'm trying to use the sketch below to test sending data out to ThingsSpeak using the arduino ethernet shield, but for some reason this sketch seems to "hang" after running once. The serial output that I get is:
Connecting to the internet via ethernet...
(an IP number here...)
Temperature: 15
1=15
Connected to thingspeak.com
1=15
Fields sent sent to www.thingspeak.com
I've looked at this sketch over and over and over and I can't seem to find what the problem is. Does anyone have any suggestions of what I could modify to make it send data continuously every ~60sec? I think that I'm almost there, but I can't seem to find the trouble line(s)... :slight_smile:
#include <SPI.h>
#include <Ethernet.h>
// ThingSpeak Settings
char thingSpeakAddress[] = "api.thingspeak.com";
String writeAPIKey = "XXXXXX"; // Add your Thingspeak API key here
EthernetClient client;
const int SETDELAY = 60 * 1000;
int status;
int failedConnectionAttempCounter;
  connectToInternet();
void connectToInternet()
  if (client.connected())
    client.stop();
  Serial.println("Connecting to the internet via ethernet...");
  byte mac[] = { XXXXXXXXXXX }; // Must be unique on local network
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore
    for(;;){
  Serial.println(Ethernet.localIP());
  Serial.println("\n");
  ReportTemperatureToSerialOut();
  ReportTemperatureToThingspeak();
void ReportTemperatureToSerialOut()
  Serial.print("Temperature: ");
  Serial.println("15");
void ReportTemperatureToThingspeak()
  // Use short field names i.e. 1 instead of field1
  String fields = "1=15";
  Serial.println(fields);
  if (client.connect(thingSpeakAddress, 80))
    Serial.println("Connected to thingspeak.com");
    // Create HTTP POST Data
    client.print("POST /update HTTP/1.1\n");
    client.print("Host: api.thingspeak.com\n");
    client.print("Connection: close\n");
    client.print("X-THINGSPEAKAPIKEY: XXXXXXXXXXX\n");
    client.print("Content-Type: application/x-www-form-urlencoded\n");
    client.print("Content-Length: ");
    client.print(fields.length());
    client.print("\n\n");
    client.print(fields);
    Serial.print(fields);
    Serial.print("\n");
    Serial.println("Fields sent sent to www.thingspeak.com");
    delay(SETDELAY);
    Serial.println("Connection to thingSpeak Failed");
    failedConnectionAttempCounter++;
    // Re-start the ethernet connection after three failed connection attempts
    if (failedConnectionAttempCounter > 3 )
      Serial.println("Re-starting the ethernet connection...");
      failedConnectionAttempCounter = 0;
Wrap a string in an instance of a String. Why? Useless waste of resources.
But, is typically global.
I think that should be \r\n.
    delay(SETDELAY);
Why? The blink without delay example needs reading, understanding, and embracing.
You send something to the server. The server generates a response. Why don't you read the response?
Hmmm I've not been able to help, but glad I stumbled across this thread. I had never heard of ThingSpeak but now I've been tweeting through its proxy (@JimDuino) and currently publishing my house temp (degrees C) on channel 9882. Good shit.
Thanks PaulS
it looks like the problem is on how my sketch is handling the information from the server. I will have to look at this in greater depth to see what's the issue.
