Hardware issues
How many kinds of vacuums are available?
If you are reading my page, you are considering looking to find what is the best vacuum cleaner for your house. It is not easy for you to get the right one. You will see a rainbow of different vacuum cleaners in various sizes, shapes, colors, features, and prices. However, you absolutely cannot give up on cleaning your house and bringing a new feeling to your family.
✫✫✫ Read More: Best vacuum cleaner for home - The best vacuum in the world
On our page, we will show you all the main types of vacuum cleaners. There are five types of vacuum cleaners. We believe that you will find it helpful at this time. Don’t leave our page.
Canister vacuum
The canister is listed on the list of top vacuum cleaners, which is in between the upright and the stick vacuums. It comes in a big set with a slender frame, which is the same as the stick vacuum cleaners. This vacuum is as mighty as the upright model. There is a canister attached with a wand, which maintains the carpet and also bare floors. This vacuum is the perfect choice for cleaning houses. It is easy to clean the stairs if you choose the lighter model. Moreover, it also comes with full accessories for cleaning different spaces from small to large. Besides, it is the most expensive vacuum with high technology and multifunction.
Stick vacuum
The stick vacuum is similar to the light upright. Stick vacuum cleaners might be the least powerful model, but it is perfect for cleaning in small places and works well on hardwood floors, light carpet, and rugs. This vacuum has a long, slender stick handle. Because of slimness, this model can be perfect for closet spaces since it can reach in the corners. It is easy to use and store. Usually, this type is battery-operated and inexpensive, around 25 to 500 USD. If you are living in a small apartment, it would be ideal.
➳➳➳ Find More Info: Best vacuum cleaner for home
Upright vacuum
This vacuum is the full-size device, which is the most common vacuum, and it comes with the most suction value for money. Its weight is around 10 to 18 pounds and it costs from 50 to 1000 dollars. Primarily, it is the strongest for cleaning up and is easy to use. Most people have used this vacuum at least one time in their life. It can be used on most surfaces from floors to carpet; it also comes with the accessories for cleaning narrow places. To have a good upright, it is better to go with a top vacuum cleaner brand.
Handheld vacuum
This vacuum is the mini vacuum, which costs from 20 to 250 dollars and only weighs five pounds or even less. This vacuum is recommended for small areas, cars, or boats. Although it is not as strong as the other devices, it allows you to work on the area that the powerful machine could not. This vacuum is especially used for cleaning up dirt and debris in narrow places; hence, it will not work well on the floors or carpet.
Robot vacuum
This model was invented recently and immediately became super popular and among the highest-rated vacuum cleaners on the market. This vacuum requires no effort. It can roam around your house and clean up any mess as it goes. This robotic vacuum can save your time and energy. Besides, it can reach even some places that the other machines could not, such as under a table, couch, etc. It is around 10 pounds in weight, easy to use, and a battery powered.
➜➜➜ See Page: Which is the best vacuum cleaner for home: Reviews and Buying Guide
We hope that our experience of five main types of these good vacuum cleaners would help you to find the right device for you to keep your house clean and fresh all the time. Please check it out carefully and enjoy your time!
Hello Sara,
Welcome to the forum.
Please read 'how to use this forum - please read' then go back and modify your question with a meaningful title and the various things suggested.
Don't assume that we all know which LED switch project you are talking about, there are lots of Arduino tutorials and you can't assume the people here are familiar with them. Please follow the instructions and post your code, a schematic and maybe a photo of what you have.
Thank you.
I wonder if the switch is one of these buttons:
If so (and you should still do as asked by PerryBebbington though) you should check the wiring to make sure you're actually switching the wires you connected. The only way to guarantee you're switching your wires without recourse to the diagram in the red box, is to connect across the diagonals.
But then, just a guess that you might have one of those pesky buttons (which also don't seem to "snap" nicely into breadboard holes) and you might have it wired wrong.
That is a fair question but as stated earlier without more information it cannot be answered directly. I would suggest getting the arduino cookbook, and reading that your project may be in it. It will also give you a background where this stuff comes from. A book on basic electronics would also be a great help, that will help you with the terms etc. Go on line there are an unbelievable amount of YouTube videos that will explain every part of what you are doing, remember some are better then others. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
