hardware setup: HC125, LM2937, HC-06 and my Arduino
Hello!
Thank you for your help before! Now i need some guiding for wiring.
I am going to make some test with bluetooth, and went to the only "radioshack" in denmark... (only physical one), and they didn't have a MOFSET that i was recommended to use, so he found some alternatives that i could use instead.
These were as the title says, HC125 and LM2937.
Now I am home with these two components and have never worked with them.
And I am having a hard time finding guides online.
He basicly explained the HC125, but i didnt write down where each write should go..
I have an arduino nano.
I found the picture from where he explained how it worked.
Can you guide me to where each wire should go?
Arduino nano through that+LM2937 to bluetooth?
my guess was;
  1. 5v in
  2. Arduino data in
  3. Arduinop data out
  4. ground.
  5. 3.3v in from LM2937.
He couldn't explain which of the 3 pins on were was on the LM2937. But i can find that online.
Thank you in advance!
Holse:
my guess was;
  1. 5v in
  2. Arduino data in
  4. ground.
I'd check the 3v3 line from nano. enough current to HC125 and bluetooth ?
You will find datasheet for your parts on web. Connect Vin (RAW) to LM2937 in (pin1) GND<->GND (pin2). Pin 3 (output 3v3) to HC125 pin 14
All output-enable to GND. 5V-I/O from nano to 1A,2A.. 1Y,2Y -> bluetooth.
