Hello all,
Has anyone tried to use SHARP LM32015T LCD with Arduino? It is quite old, size is 5,7", most likely 320X240.
Now I have powered it, +5 and -21 V, backlit from original circuit. As I found from similar datasheet (LM320191)- it has 4 data lines and 3 or 4 control lines, probably CS1, CS2, S and maybe disp OFF. As I understand display does not have integrated controller so data must be constantly transmitted. I clearly understand this connection project is economically unprofitable, only there would be interesting to see display with quite big dots working again.
I might be wrong but it looks like this LCD doesn’t have a controller so it needs continuous high speed refresh signals. I’m not sure an Arduino can generate the required timing by itself you may need something faster like an FPGA or a dedicated LCD driver
I was thinking about setting one high speed Arduino compatible board for LCD controlling, to use with another Arduino
Yeah that could actually work if the board you pick has tighter control over timing or supports fast GPIO toggling (like Teensy with its DMA or FlexIO) it might just be fast enough to generate the signals. Not totally sure it’ll match the LCD’s exact timing specs but definitely worth a shot
