Yah i see there is a button on the adruino, it would be great if you can help me on the code for changing the message by using that button( i just need simple messages such as: help, hello, etc... i could change the message later),or do i have to build another button seperate from the adruino
im kinda bad on programming
im truly appreciate for any help, comments from anyone
//– Columns (Negative Cathodes) –
int latchPin1 = 2; //Arduino pin connected to Green 10 RCK of TPIC6C595
int clockPin1 = 3; //Arduino pin connected to Yellow 15 SRCK of TPIC6C595
int dataPin1 = 4; //Arduino pin connected to Blue 2 SER IN of TPIC6C595
//– Rows (Positive Anodes) –
int latchPin2 = 5; //Arduino pinn connected to Green Latch 12 ST_CP / RCK of 74HC595
int clockPin2 = 6; //Arduino pin connected to Yellow Clock 11 SH_CP / SCK of 74HC595
int dataPin2 = 7; //Arduino pin connected to Blue Data 14 DS / SI of 74HC595
//=== B I T M A P ===
// 8 is # of rows, 73is # of LED matrix we have
byte bitmap[8][3]; // Change the 3 to however many matrices you want to use.
int numZones = sizeof(bitmap) / 8;
int maxZoneIndex = numZones-1;int numCols = numZones * 8;
//=== F O N T ===
// Font courtesy of aspro648
// http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1203747843/22
// First char is @, next is A, B, etc. Only lower case, no symbols.
// The @ will display as space character.
byte alphabets[][5] = {
{0,0,0,0,0},
{31, 36, 68, 36, 31},
{127, 73, 73, 73, 54},
{34, 65, 65, 65, 62},
{127, 65, 65, 34, 28},
{65, 65, 73, 73, 127},
{127, 72, 72, 72, 64},
{62, 65, 65, 69, 38},
{127, 8, 8, 8, 127},
{0, 65, 127, 65, 0},
{2, 1, 1, 1, 126},
{127, 8, 20, 34, 65},
{1, 1, 1, 1, 127},
{127, 32, 16, 32, 127},
{127, 32, 16, 8, 127},
{62, 65, 65, 65, 62},
{127, 72, 72, 72, 48},
{62, 65, 69, 66, 61},
{127, 72, 76, 74, 49},
{50, 73, 73, 73, 38},
{64, 64, 127, 64, 64},
{126, 1, 1, 1, 126},
{124, 2, 1, 2, 124},
{126, 1, 6, 1, 126},
{99, 20, 8, 20, 99},
{96, 16, 15, 16, 96},
{67, 69, 73, 81, 97},};
//=== S E T U P ===
Serial.begin(57600);
pinMode(latchPin1, OUTPUT);
pinMode(clockPin1, OUTPUT);
pinMode(dataPin1, OUTPUT);
pinMode(latchPin2, OUTPUT);
pinMode(clockPin2, OUTPUT);
pinMode(dataPin2, OUTPUT);
//– Clear bitmap –
for (int row = 0; row < 8; row++) {
for (int zone = 0; zone <= maxZoneIndex; zone++) {
bitmap[row][zone] = 0;
//=== F U N C T I O N S ===
// This routine takes whatever we’ve setup in the bitmap array and display it on the matrix
void RefreshDisplay()
int rowbit = 1 << row;
digitalWrite(latchPin2, LOW); //Hold latchPin LOW for as long as we’re transmitting data
shiftOut(dataPin2, clockPin2, MSBFIRST, ~rowbit); //Transmit data
//– Start sending column bytes –
digitalWrite(latchPin1, LOW); //Hold latchPin LOW for as long as we’re transmitting data
//– Shift out to each matrix (zone is 8 columns represented by one matrix)
for (int zone = maxZoneIndex; zone >= 0; zone–) {
shiftOut(dataPin1, clockPin1, MSBFIRST, bitmap[row][zone]);
//– Done sending Column bytes, flip both latches at once to eliminate flicker
digitalWrite(latchPin1, HIGH); //Return the latch pin high to signal chip that it no longer needs to listen for information digitalWrite(latchPin2, HIGH); //Return the latch pin high to signal chip that it no longer needs to listen for information
delayMicroseconds(500);//make it easier for us to see, you can change this number
// Converts row and colum to actual bitmap bit and turn it off/on
void Plot(int col, int row, bool isOn)
int zone = col / 8;
int colBitIndex = col % 8;
byte colBit = 1 << colBitIndex;
if (isOn)
bitmap[row][zone] = bitmap[row][zone] | colBit;
else bitmap[row][zone] = bitmap[row][zone] & (~colBit);}
// Plot each character of the message one column at a time, updated the display, shift bitmap left.
void AlphabetSoup(){char msg[] = “HELLO “;
for (int charIndex=0; charIndex < (sizeof(msg)-1); charIndex++)
int alphabetIndex = msg[charIndex] – ‘@’;
if (alphabetIndex < 0) alphabetIndex=0;
//– Draw one character of the message –
for (int col = 0; col < 7; col++)
// Set the pixel to what the alphabet say for columns 0 thru 4, but always leave columns 5 and 6 blank.
bool isOn = 0;
if (col<5) isOn = bitRead( alphabets[alphabetIndex][col], 7-row ) == 1;
Plot( numCols-1, row, isOn); //The shift loop below will scroll it leftward.
//– The more times you repeat this loop, the slower the text scroll –
for (int refreshCount=0;refreshCount < 5; refreshCount++)
RefreshDisplay();
//– Shift the bitmap one column to left –
for (int row=0; row<8; row++)
for (int zone=0; zone < numZones; zone++)
bitmap[row][zone] = bitmap[row][zone] >> 1;
// Roll over lowest bit from the next zone as highest bit of this zone.
if (zone < maxZoneIndex) bitWrite(bitmap[row][zone], 7, bitRead(bitmap[row][zone+1],0));
//=== L O O P ===
AlphabetSoup();
/* if (Serial.available() > 0) {
AlphabetSoup(Serial.read());
