I am trying to do a project that I found on Instructables. I have all of the components for it, but when I verify, I get errors. I have looked up some problems and changed the time code to <TimeLib.h> as some have suggested for time related problems, but I'm still getting errors. Can someone look through it? It's a few years old, which is why some of the code needs to be updated, but I don't know what else needs to change. I've included the errors I get. There are many tabs of code, so I'm not sure how to post all of them on here. Please let me know if you can provide help.
Retro PacMan Clock Instructable
TimeLib.h file
time.h - low level time and date functions
July 3 2011 - fixed elapsedSecsThisWeek macro (thanks Vincent Valdy for this)
- fixed daysToTime_t macro (thanks maniacbug)
#ifndef _Time_h
#ifdef __cplusplus
#define _Time_h
#include <inttypes.h>
#ifndef AVR
#include <sys/types.h> // for __time_t_defined, but avr libc lacks sys/types.h
#endif
#if !defined(__time_t_defined) // avoid conflict with newlib or other posix libc
typedef unsigned long time_t;
#endif
// This ugly hack allows us to define C++ overloaded functions, when included
// from within an extern "C", as newlib's sys/stat.h does. Actually it is
// intended to include "time.h" from the C library (on ARM, but AVR does not
// have that file at all). On Mac and Windows, the compiler will find this
// "Time.h" instead of the C library "time.h", so we may cause other weird
// and unpredictable effects by conflicting with the C library header "time.h",
// but at least this hack lets us define C++ functions as intended. Hopefully
// nothing too terrible will result from overriding the C library header?!
extern "C++" {
typedef enum {timeNotSet, timeNeedsSync, timeSet
} timeStatus_t ;
typedef enum {
dowInvalid, dowSunday, dowMonday, dowTuesday, dowWednesday, dowThursday, dowFriday, dowSaturday
} timeDayOfWeek_t;
typedef enum {
tmSecond, tmMinute, tmHour, tmWday, tmDay,tmMonth, tmYear, tmNbrFields
} tmByteFields;
typedef struct {
uint8_t Second;
uint8_t Minute;
uint8_t Hour;
uint8_t Wday; // day of week, sunday is day 1
uint8_t Day;
uint8_t Month;
uint8_t Year; // offset from 1970;
} tmElements_t, TimeElements, *tmElementsPtr_t;
//convenience macros to convert to and from tm years
#define tmYearToCalendar(Y) ((Y) + 1970) // full four digit year
#define CalendarYrToTm(Y) ((Y) - 1970)
#define tmYearToY2k(Y) ((Y) - 30) // offset is from 2000
#define y2kYearToTm(Y) ((Y) + 30)
typedef time_t(*getExternalTime)();
//typedef void (*setExternalTime)(const time_t); // not used in this version
/* Useful Constants */
#define SECS_PER_MIN (60UL)
#define SECS_PER_HOUR (3600UL)
#define SECS_PER_DAY (SECS_PER_HOUR * 24UL)
#define DAYS_PER_WEEK (7UL)
#define SECS_PER_WEEK (SECS_PER_DAY * DAYS_PER_WEEK)
#define SECS_PER_YEAR (SECS_PER_WEEK * 52UL)
#define SECS_YR_2000 (946684800UL) // the time at the start of y2k
/* Useful Macros for getting elapsed time */
#define numberOfSeconds(time) (time % SECS_PER_MIN)
#define numberOfMinutes(time) ((time / SECS_PER_MIN) % SECS_PER_MIN)
#define numberOfHours(time) (( time% SECS_PER_DAY) / SECS_PER_HOUR)
#define dayOfWeek(time) ((( time / SECS_PER_DAY + 4) % DAYS_PER_WEEK)+1) // 1 = Sunday
#define elapsedDays(time) ( time / SECS_PER_DAY) // this is number of days since Jan 1 1970
#define elapsedSecsToday(time) (time % SECS_PER_DAY) // the number of seconds since last midnight
// The following macros are used in calculating alarms and assume the clock is set to a date later than Jan 1 1971
// Always set the correct time before settting alarms
#define previousMidnight(time) (( time / SECS_PER_DAY) * SECS_PER_DAY) // time at the start of the given day
#define nextMidnight(time) ( previousMidnight(time) + SECS_PER_DAY ) // time at the end of the given day
#define elapsedSecsThisWeek(time) (elapsedSecsToday(time) + ((dayOfWeek(time)-1) * SECS_PER_DAY) ) // note that week starts on day 1
#define previousSunday(time) (time - elapsedSecsThisWeek(time)) // time at the start of the week for the given time
#define nextSunday(time) ( previousSunday(time)+SECS_PER_WEEK) // time at the end of the week for the given time
/* Useful Macros for converting elapsed time to a time_t */
#define minutesToTime_t ((M)) ( (M) * SECS_PER_MIN)
#define hoursToTime_t ((H)) ( (H) * SECS_PER_HOUR)
#define daysToTime_t ((D)) ( (D) * SECS_PER_DAY) // fixed on Jul 22 2011
#define weeksToTime_t ((W)) ( (W) * SECS_PER_WEEK)
/* time and date functions */
int hour(); // the hour now
int hour(time_t t); // the hour for the given time
int hourFormat12(); // the hour now in 12 hour format
int hourFormat12(time_t t); // the hour for the given time in 12 hour format
uint8_t isAM(); // returns true if time now is AM
uint8_t isAM(time_t t); // returns true the given time is AM
uint8_t isPM(); // returns true if time now is PM
uint8_t isPM(time_t t); // returns true the given time is PM
int minute(); // the minute now
int minute(time_t t); // the minute for the given time
int second(); // the second now
int second(time_t t); // the second for the given time
int day(); // the day now
int day(time_t t); // the day for the given time
int weekday(); // the weekday now (Sunday is day 1)
int weekday(time_t t); // the weekday for the given time
int month(); // the month now (Jan is month 1)
int month(time_t t); // the month for the given time
int year(); // the full four digit year: (2009, 2010 etc)
int year(time_t t); // the year for the given time
time_t now(); // return the current time as seconds since Jan 1 1970
void setTime(time_t t);
void setTime(int hr,int min,int sec,int day, int month, int yr);
void adjustTime(long adjustment);
/* date strings /
#define dt_MAX_STRING_LEN 9 // length of longest date string (excluding terminating null)
char monthStr(uint8_t month);
char* dayStr(uint8_t day);
char* monthShortStr(uint8_t month);
char* dayShortStr(uint8_t day);
/* time sync functions */
timeStatus_t timeStatus(); // indicates if time has been set and recently synchronized
void setSyncProvider( getExternalTime getTimeFunction); // identify the external time provider
void setSyncInterval(time_t interval); // set the number of seconds between re-sync
/* low level functions to convert to and from system time */
void breakTime(time_t time, tmElements_t &tm); // break time_t into elements
time_t makeTime(tmElements_t &tm); // convert time elements into time_t
} // extern "C++"
#endif // __cplusplus
#endif /* _Time_h */>
Errors:
enabled in File > Preferences.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Mega (ATmega1280)"
In file included from Retro_Pacman_Clock_code.ino:24:
DS1307RTC.h:17: error: 'time_t' does not name a type
DS1307RTC.h:18: error: 'time_t' has not been declared
DS1307RTC.h:19: error: 'tmElements_t' has not been declared
DS1307RTC.h:20: error: 'tmElements_t' has not been declared
Retro_Pacman_Clock_code.ino: In function 'void setup()':
Retro_Pacman_Clock_code:162: error: 'class DS1307RTC' has no member named 'get'
Retro_Pacman_Clock_code:162: error: 'setSyncProvider' was not declared in this scope
Retro_Pacman_Clock_code:163: error: 'setSyncInterval' was not declared in this scope
Retro_Pacman_Clock_code:164: error: 'timeStatus' was not declared in this scope
Retro_Pacman_Clock_code:164: error: 'timeSet' was not declared in this scope
Retro_Pacman_Clock_code:167: error: 'setTime' was not declared in this scope
Retro_Pacman_Clock_code.ino: In function 'void loop()':
Retro_Pacman_Clock_code:315: error: 'hour' was not declared in this scope
Retro_Pacman_Clock_code:315: error: 'minute' was not declared in this scope
Retro_Pacman_Clock_code.ino: In function 'void UpdateDisp()':
Retro_Pacman_Clock_code:3852: error: 'hour' was not declared in this scope
Retro_Pacman_Clock_code:3853: error: 'minute' was not declared in this scope
Retro_Pacman_Clock_code.ino: In function 'void clocksetup()':
Retro_Pacman_Clock_code:4669: error: 'hour' was not declared in this scope
Retro_Pacman_Clock_code:4670: error: 'minute' was not declared in this scope
Retro_Pacman_Clock_code:4956: error: 'class DS1307RTC' has no member named 'get'
Retro_Pacman_Clock_code:4956: error: 'setSyncProvider' was not declared in this scope
Retro_Pacman_Clock_code:4957: error: 'setSyncInterval' was not declared in this scope
