Having Trouble with sending IR codes to my AC
Hey guys, I am kinda new to Arduino projects. And I'm working on a project which will be applied in a room that includes two Air Conditioners. First AC runs 7/24. My goal is to control the second AC with IR led connected to Arduino. I get my IR codes by IRremote library's ReceiveDemo example sketch. Below, you can see my received AC_ON and AC_OFF codes and how I used them on my sender codes. I designed my circuit to transmit these codes, I point the LED right to the AC from about 1 meter away. I confirmed that IR LED works from my Phone camera but AC does not respond to any of them. What am I doing wrong? What should I do?
AC_ON
Protocol=PulseDistance Raw-Data=0x2 35 bits LSB first
Send on a 8 bit platform with:
uint32_t tRawData[]={0x50400419, 0x2};
IrSender.sendPulseDistanceWidthFromArray(38, 9000, 4350, 650, 1650, 650, 550, &tRawData[0], 35, PROTOCOL_IS_LSB_FIRST, , );
AC_OFF
uint32_t tRawData[]={0x50000411, 0x2};
How I used them on my code (on different lines):
uint32_t tRawData_ON[]={0x50400419, 0x2};
uint32_t tRawData_OFF[]={0x50000411, 0x2};
IrSender.sendPulseDistanceWidthFromArray(38, 9000, 4350, 650, 1650, 650, 550, &tRawData_ON[0], 35, PROTOCOL_IS_LSB_FIRST, 1000, 0);
IrSender.sendPulseDistanceWidthFromArray(38, 9000, 4350, 650, 1650, 650, 550, &tRawData_OFF[0], 35, PROTOCOL_IS_LSB_FIRST, 1000, 0);
Dis you try the ReceiveDemo to see how it decodes your transmissions?
No, I did not. I will be back with the results today. Thanks.
What kind of AC?
That raw in your code doesn't look typical AC remote code, maybe only small fraction of it.
Typical looks like this:
Raw: (139) 9068, -4404, 708, -1580, 712, -488, 712, -484, 712, -1580, 712, -1580, 708, -1580, 712, -488, 708, -488, 708, -1584, 708, -1584, 708, -1580, 708, -492, 708, -488, 704, -496, 704, -492, 708, -492, 708, -492, 704, -492, 708, -492, 708, -488, 712, -488, 712, -1580, 708, -1580, 712, -488, 712, -484, 712, -488, 712, -488, 712, -484, 712, -1580, 712, -484, 712, -1580, 712, -484, 716, -484, 712, -1580, 712, -484, 712, -19848, 684, -512, 704, -496, 708, -492, 708, -488, 708, -492, 708, -488, 712, -488, 712, -488, 708, -488, 712, -488, 712, -484, 712, -488, 712, -488, 708, -1580, 712, -488, 712, -484, 712, -488, 708, -488, 712, -488, 712, -488, 708, -488, 712, -488, 708, -488, 712, -488, 712, -488, 708, -488, 712, -488, 708, -492, 708, -488, 708, -492, 708, -1584, 704, -1584, 708,
Typical 24000btu/h AC. When I asked ChatGPT to give me a code to receive raw data. I received this, just looks like the one you sent.
Received RAW data: rawData[74]:
-3276750
+9050,-4350
  • 700,-1600 + 700,- 500 + 700,- 500 + 700,- 500
  • 650,-1650 + 650,-1600 + 700,- 500 + 700,- 500
  • 700,- 500 + 650,- 550 + 650,-1650 + 650,- 550
  • 650,- 550 + 650,- 550 + 650,- 500 + 700,- 550
  • 650,- 550 + 650,- 550 + 650,- 550 + 600,- 600
  • 600,- 550 + 650,- 550 + 650,- 550 + 650,- 550
  • 650,- 550 + 600,- 600 + 600,- 600 + 600,- 600
  • 600,-1700 + 600,- 550 + 650,-1650 + 650,- 550
  • 600,- 600 + 600,-1700 + 600,- 600 + 600
I have played with quite many, they are normally at least length in that example. Yours look like a start of a complete signal.
What library you use?
What brand/model is your AC?
I use IRremote.hpp library in arduino. My AC is
Sigma Comfort SGM24INVDMS. Should I use IRlib?
Get your signal with this first, it's done for air conditioners and post your result
most sensible outputs are these with choices 4 and 5.( 4 for Hyundai etc. codes, 5 for Samsung etc. codes)
Enter choice: 4
Ready to decode IR for choice '4'
################# Start
Number of symbols: 71
Symbols:
Hh10001000001000000000000000001010010W00000000000000100000000000001100
Bytes:
00: 1000|1000 | 11 | 00010001
01: 0010|0000 | 04 | 00000100
02: 0000|0000 | 00 | 00000000
03: 0000|1010 | 50 | 01010000
04: 01004: 0000|0000 | 00 | 00000000
05: 0000|0010 | 40 | 01000000
06: 0000|0000 | 00 | 00000000
07: 0000|1100 | 30 | 00110000
11,04,00,50,00,40,00,30
Timings (in us):
PAUSE SPACE: 20012
HEADER MARK: 9104
HEADER SPACE: 4396
BIT MARK: 619
ZERO SPACE: 560
ONE SPACE: 1662
Decoding known protocols...
Looks like a Gree protocol
Checksum does not match
POWER OFF
MODE COOL
Temperature: 20
FAN: 1
SLEEP: OFF
SWING: OFF
Unknown protocol
Bytecount: 8
################# End
Enter choice: 5
Ready to decode IR for choice '5'
Symbols:
Bytes:
Timings (in us):
PAUSE SPACE: 19980
HEADER MARK: 9076
HEADER SPACE: 4400
BIT MARK: 632
ZERO SPACE: 546
ONE SPACE: 1654
POWER OFF
MODE COOL
Temperature: 20
FAN: 1
SLEEP: OFF
SWING: OFF
Unknown protocol
Bytecount: 8
Ok, maybe some new or slightly modified Gree rebranded and not recognized for checksum...
Take the bits and timings and insert them in rawsender.ino (in examples) and give a try with with your transmitter (check the right pin) to see if AC responds.
By the way, how is your circuit?
It contains only IR led and DHT22. nothing much
Not transistor driven?
Well, there is a little issue about trying with transmitter. The AC is at the company, I am an intern there, I do not have access to arduino IDE from company computers (cyber security protocol, I do not know why). So, I took the remote controller at home to collect signals and make changes on my codes. I can only give it a try tomorrow.
One more thing, I have about 25 different codes for all temperature transitions, fans etc. When I implement the PAUSE SPACE, HEADER MARK, HEADER SPACE, BIT MARK, ZERO SPACE, ONE SPACE, can I use common values or is it differ for all of them?
No. Should I use?
If you want "usable" range yes. But first make that AC to respond, even at 5cm distance. With correct circuit you can arrive to 10 meters.
Once you have the timings correct, you can just send different codes like that
Hh10001000001000000000000000001010010W00000000000000100000000000001100.
Every temp/fan setting is changing that code little bit. It's much more efficient than sending raw timings.
Ideally you find a library that can decode it, but for arduino I don't know any better.
I just tested it and it does not turn on my AC. It sends signal but AC does not get the codes. Can you help me?
What was the distance when you tried?
Can you see led pulsing on your camera (with this last code)?
Are you using 940nm led?
Distance was about 10-30cm.
Yes, I checked the led with my phone camera, it sends the signal.
I don’t know if its 940nm, I pulled it out from an old air curtain remote.
