HC-05 not transmitting at 8MHz arduino frequency
I run an Arduino Pro Mini on ATMega328 3.3V 8MHz, that transmits analog data to App Inventor, and I am unable to transmit data over Bluetooth at 8MHz frequency. When the Pro Mini runs at 16MHz, it does not have this issue.
What is the issue running at a slower frequency, and how can I make Bluetooth run on 8MHz frequency on Pro Mini?
The Arduino code is down below:
#include <SoftwareSerial.h>
#include <Wire.h>
SoftwareSerial BT(10, 11);
byte value;
unsigned long pmillis_bt = 0;
  BT.begin(9600);
///////////////////main///////////////////
void loop () {
  if (millis() - pmillis_bt >= 100) { //this function replaces the delay function
    byte Data[3];
    byte cmmd[20];
    int insize;
    char str[256];
    int i = analogRead(A0); //the value to be read and sent via bluetooth
    value = BT.read();
    Data[0] = 'a';
    Data[1] = i / 256;
    Data[2] = i % 256;
    sprintf(str, "%d", i, Data[0], Data[1], Data[2]);
    Serial.println(str);
    if (value == 49) {
      for (int j = 0; j < 3; j++)
        BT.write(Data[j]);
      value = 0;
    pmillis_bt = millis();
Your format statement has ONE format specifier. That means that you supply ONE more argument, NOT 4.
Do you KNOW that SoftwareSerial is calculating the time between bits correctly for an 8MHz system?
Why are you running at 8MHz?
Run the Pro Mini on a 3.7V lithium battery, that's why it's running on 3.3V 8MHz
BlastCookie:
I can't see how you can fiddle with bluetooth but you might try using hardware serial instead. Also, Is bluetooth a bare module, or on a breakout board, if so, what sort, and how is powered?
Nick_Pyner:
It is a bare HC-05 module, running on a 3.7v lithium-polymer battery
