hi
is there a way to communicate with multi hc05 slaves (one at a time) with a hc05master.
one master and a slave no problem but i didn't find any flowchart to explain the way to do that
if someone could give help it would be kind.
THANKS
hi
THANKS
My understanding is that HC-05 master only connects with a slave by using a hard-coded address. A good source is here:
It might be simpler to use several masters, each dedicated to its exclusive slave.
Dear Nick thanks for answering;
but I've yet read phillipecantin blogs and others . I wanna know the way to the master be connected to one slave and to a second one and so on in order to have a piconet;
In all examples there is only a master joining a slave
May be I'm wrong?
thanks
Hello and welcome ![]()
I have never tried, but I think it is possible, but as you said, with only one slave at a time.
Here is the manual of the HC-05, read it carefully, it's not very detailed but at least you know all commands ![]()
I have a HC-05 as master and 2 HC-07 slaves. I will do some tests tomorrow and will post a demo sketch if I can get it working.
HI
I found out the way to have a HC05 master communicate with HC05 slaves
first set the master first set the slaves
AT+ROLE=1 // MASTER AT+ROLE=0 // SLAVE
AT+MODE =1 // link any address AT+MODE =1 // link any address
at+uart=38400 at+uart=38400
at+init //init spp at+init //init spp
in my case I've got 2slaves
at+inqm=0,2,48 //0=inquiry mode standard,2= slave number to find,timeout=1,28S*48
in my case 2 slaves found
addr slave1 2014,10,170790
addr slave2 2014,10,170304
then I've done
at+pair=2014,10,170790,20 // ADDR SLAVE1 followed by time out here 20seconds
at+link=2014,10,170790
then send your datas
for joining slave2
HARDWARE RESET MASTER
at+init
at+pair=2014,10,170304,20 // ADDR SLAVE2 followed by time out here 20seconds
at+link=2014,10,170304,20
THATS ALL if that could help someone
ps each command could be upper or lower case and have to end with \n\r
if you question the master or slave no nedd to type ?
Remy,
i have a project with the same requirements and i only have a problem with how to disconnect slave1 from the master then i connect it with slave2 when i used the command AT+DISC no respond as when the master connected to slave 1 both of them don't respond to AT commands
remy_A59330:
HII found out the way to have a HC05 master communicate with HC05 slaves
then I've done
for joining slave2
at+init
I did it according to your code. However, after I connect the first bluetooth, the led on hc05 turned on blink every 2 seconds, and it doesn't connect the second bluetooth. How should I do?
He is how I manage to have one master with two slaves, code and video at: https://www.saibatudomt.com.br/2018/01/conectando-3-dispositivos-arduino-utilizando-o-modulo-bluetooth-hc-05.html
Hope it helps
remy_A59330:
hiis there a way to communicate with multi hc05 slaves (one at a time) with a hc05master.
THANKS
remy_A59330:
then I've done
for joining slave2
at+init
I was reviewing this. My first blunder was that it did not enter AT + INIT mode, I was investigating and described that I had to hold down the button on the HC-05 module that would be master. This is how it works correctly. The problem arises in that after entering AT + PAIR and AT + LINK of the first slave, I cannot give "RESET BY HARDWARE" since I have pressed. Then I give it AT + RESET, to enter AT + PAIR and AT + LINK of the second slave, then at the end it only links to the second slave. I do this, from HYPERTERMINAL. Help. Thank you.
