hi im using this sketch from the book arduino projects for the evil genius and it doesnt seem to be working. The data in the serial interface which should potentially be used to create a pulse rate graph, maxs out at 1023, the scale of the reading being between 0 and 1023. Has anyone any ideas where i may be going wrong, thanks:
int ledPin = 13;
int sensorPin = 0;
double alpha = 0.75;
int period = 20;
double change = 0.0;
I am using a simple circuit consisting of a IR LED and a IR phototransistor, this shines through your finger detecting your pulse by the variation in the data produced in the serial monitor. This is a bit embarrassing but how do you load a pic from your desktop using the html creator
/Users/christopherlaw/Desktop/max:msp/BLOG STUFF/20101101
I have checked the code rigorously and it came straight out of the book. All the components were the exact components with the exact codes given in the book from the suppliers. You would be given for thinking this is a fool proof setup he
thanks for your feedback
hey my circuit is set up here. Its a very simple circuit with a IR led and a IR photo transistor. Ive since removed the Led and the resistor as its unnecessary.there is only 1 data input to analogue A0.
