Hi All, sorry for the cross posting but I'm desperate!can someone please try and point out what I'm doing wrong! I'm trying to print out the heart rate that I'm detecting and passing into Arduino. I can't get it to print properly and I've tried everything!
int heart = 12; //digital pin being used
int heartDetect=0; // detects the value of digital pin 12
int heartRate = 0; // Assigned the value of heartDetect added to itself over a period of time.
int time = 20000; // The time value that I'm using.
extern volatile unsigned long timer0_overflow_count; //Sets the timer
Serial.begin(300);//need to use a slow serial
pinMode(heart, INPUT);//declare pin 12 as an INPUT
heartDetect = digitalRead(heart); //heartDetect is assigned the value of pin 12
if (timer0_overflow_count < time){ //If it's less than 20 seconds
heartRate = heartRate + heartDetect; //Add the value of heartRate to itself plus the value of heartDetect
//Serial.print(" ");
//Serial.print(heartRate, DEC);
//Serial.print(0, BYTE);
else if (timer0_overflow_count > time){ //else If it's over 20 seconds
Serial.print(" ");
Serial.print(heartRate, DEC); //print out the value of heartRate
timer0_overflow_count = 0; //reset the timer
heartRate = 0; //reset heartRate
For some reason, the only way I can get the value of 'heartRate' to print to serial in the 'else if' statement is to un-comment the serial.print() lines within the 'if' statement. If I don't do this i get a random value assigned to heartRate.
I only want the value of 'heartRate' to be printed to the serial every 20 seconds. I would really appreciate any comments if you have an idea of how I could get around this problem. Thanks,
Tom
