Hello I'm working on a project for an automatic door and need some assistance
#include <Servo.h>
#include <NewPing.h>
#define TRIG_PIN 8
#define ECHO_PIN 9
#define SERVO_PIN 10
#define MAX_DISTANCE 200 // Maximum distance (in cm) to ping for
void setup () {
  Servo.attach(SERVO_PIN);
  NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
void loop () {
  unsigned int distance = sonar.ping_cm();
  if (distance < 30) {
   servo.write(180); // rotate servo to 180 degrees
   Serial.print("Object is too close! Distance: ");
   Serial.println(distance);
   servo.write(0); // rotate servo to 0 degrees
   Serial.print("Object is at safe distance. Distance: ");
  delay(50);
Every time I try to run the code it show's an error saying":\Users\HP\Documents\Arduino\sketch_may7f\sketch_may7f.ino: In function 'void setup()':
C:\Users\HP\Documents\Arduino\sketch_may7f\sketch_may7f.ino:10:8: error: expected unqualified-id before '.' token
C:\Users\HP\Documents\Arduino\sketch_may7f\sketch_may7f.ino: In function 'void loop()':
C:\Users\HP\Documents\Arduino\sketch_may7f\sketch_may7f.ino:15:27: error: 'sonar' was not declared in this scope
C:\Users\HP\Documents\Arduino\sketch_may7f\sketch_may7f.ino:17:4: error: 'servo' was not declared in this scope
C:\Users\HP\Documents\Arduino\sketch_may7f\sketch_may7f.ino:17:4: note: suggested alternative: 'Servo'
Servo
C:\Users\HP\Documents\Arduino\sketch_may7f\sketch_may7f.ino:21:4: error: 'servo' was not declared in this scope
C:\Users\HP\Documents\Arduino\sketch_may7f\sketch_may7f.ino:21:4: note: suggested alternative: 'Servo'
Servo
exit status 1
Compilation error: expected unqualified-id before '.' token" but I don't know what to do please help
See below the changes/adjustments I have made in you sketch. It is compiled now. You may ask questions why such cahages are needed.
#include <Servo.h>
#define TRIG_PIN 8
#define ECHO_PIN 9
Servo myServo;
void setup ()
  myServo.attach(SERVO_PIN);
void loop ()
  if (distance < 30)
    myServo.write(180); // rotate servo to 180 degrees
    myServo.write(0); // rotate servo to 0 degrees
  delay(50);
It seems I forgot to declare the servo but for the ping sonar I didn't even know how thanks please explain the sonar declaration
Bu that line was in the setup() function of your sketch of post #1. I have just made it global so that the object sonar could be accessed from loop()/any function.
