Hi ! I'm working on a DIY Weller RT soldering station project, based on the work done by Matthias Wagner :
His original design uses an Arduino Pro Mini (5V, 16MHz), which features an Atmega328-AU. I'm working on implementing the project on a single PCB with the same chip (the TQFP package) which I will solder myself (I'm essentially getting rid of the Arduino board).
Therefore, I'm trying to figure out how to burn a bootloader and program the chip. If I'm right the bootloader can be burned through ICSP with an Arduino UNO (which I own) and then the chip can be programmed through FTDI like the Arduino Pro Mini.
Now I have questions. I know they have been discussed before on this very forum and elsewhere, but it seems that there is no definitive answer...
The program has been written for an Atmega328-AU, I'm wondering if I could use an Atmega328P-AU instead, which has lower power consumption (again, correct me if I'm wrong here).
The Atmega328-AU and Atmega328P-AU have two extra ADC pins compared to the DIP-packaged versions. When burning the bootloader on the chip, what board should I choose in the Arduino IDE board list for the Atmega328-AU and the Atmega328P-AU respectively, to make sure that the 2 extra ADC pins become functional ? As an example if I burn the UNO (Atmega328P-PU DIP which doesn't have the extra ADC pins) bootloader in an Atmega328P-AU (TQFP package which does have the two extra pins), will the Arduino IDE allow me to use the two extra ADC pins offered by the TQFP version ?
Do I really have to burn the bootloader through ICSP and then send my program to the chip through FTDI ? Is there a cheap solution requiring less pins ? Because when designing my PCB, I would like to avoid having to place 6 pads for ICSP and another 6 pads for FTDI, my PCB would get a little bit messier and I'd rather avoid having to route an extra 12 traces...
I will really appreciate any help you can provide ![]()
