Im in grade 10, our research is visualbot, it is for blind people. our problem is our audio, as well as the ultrasonic and servo motor. but ill focus on the audio first.
* Play wave audio files with Arduino.
* This is a free software with NO WARRANTY.
* https://simple-circuit.com/
#include <SPI.h> // include Arduino SPI library
#include <SD.h> // include Arduino SD library
#include "TMRpcm.h" // include TMRpcm library
TMRpcm audio;
File root;
void setup(void) {
Serial.print("Initializing SD card...");
if (!SD.begin()) {
Serial.println("failed!");
while (true)
; // stay here.
Serial.println("OK!");
audio.speakerPin = 9; // set speaker output to pin 9
root = SD.open("/"); // open SD card main root
printDirectory(root, 0); // print all files names and sizes
audio.setVolume(6); // 0 to 7. Set volume level
audio.quality(1); // Set 1 for 2x oversampling Set 0 for normal
// main loop
if (!audio.isPlaying()) {
// no audio file is playing
File entry = root.openNextFile(); // open next file
if (!entry) {
// no more files
root.rewindDirectory(); // go to start of the folder
return;
uint8_t nameSize = String(entry.name()).length(); // get file name size
String str1 = String(entry.name()).substring(nameSize - 4); // save the last 4 characters (file extension)
if (str1.equalsIgnoreCase(".wav")) {
// the opened file has '.wav' extension
audio.play(entry.name()); // play the audio file
Serial.print("Playing file: ");
Serial.println(entry.name());
else {
// not '.wav' format file
entry.close();
return;
// a small function for buttons debounce
bool debounce(int bt) {
byte count = 0;
for (byte i = 0; i < 5; i++) {
if (!digitalRead(bt))
count++;
delay(10);
if (count > 2) return 1;
else return 0;
void printDirectory(File dir, int numTabs) {
while (true) {
File entry = dir.openNextFile();
if (!entry) {
// no more files
for (uint8_t i = 0; i < numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs + 1);
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
// end of code.
Simple Circuit
this is the code i use. i used a simple sound, it worked but when i use my own sound it doesn't.. please help me
