Help Identifying Display, and use
I found this 3.2 display in my junk box today, while looking for a touch screen to use on a new project.
I purchased this quite a while ago, and cannot find the documentation, or any info on it, so if anybody can help ID a maker, wiring (to esp32), example code (I would like to use the Display, The Touch, and the SD.
The only Chip Number I can read is U2 "HR2046 1703"
I can use this in 8 bit mode if it allows.
Thank You!
2.8 Inch Tft Touch Display Module Support Stm32/c51
https://www.amazon.co.uk/SRMAN-Display-Support-Development-Capacitive-blue/dp/B0BZGSS5WD
We can see it's a SPI device (MISO, MOSI) but wow so many pins 16 of which appear to be the data lines (DB0 to DB15)
I would search for a SPI connected device example in the Arduino Project HUB, or Instructables and also try https://dronebotworkshop.com/touchscreen-arduino/#TFT_LCD_Display
As always, begin with lcdwiki.com
3.2inch 16BIT Module ILI9341 SKU:MRB3205
Thanks everybody, I will file these away with this LCD, as it would be a PITA to get it wired to my exp32. I will find a use for it in a future arduino project.
