Hello guys i'm new programing arduino and i want a joystick with 3 axis moving on arduino uno, but just the Z axis active, can someone tell me if my code is wrong or i miss something. Image at Attchments thanks
Being new does not excuse posting code as an image...
Please post here using code tags
Also explain how you wired everything
J-M-L:
Being new does not excuse posting code as an image...Please post here using code tags
int xPin = A1;
int yPin = A0;
int buttonPin = 2;
int xPosition = 0;
int yPosition = 0;
int buttonState = 0;
pinMode(xPin, INPUT);
pinMode(yPin, INPUT);
pinMode(buttonPin, INPUT_PULLUP);
xPosition = analogRead(xPin);
yPosition = analogRead(yPin);
buttonState = digitalRead(buttonPin);
Serial.print("X: ");
Serial.print(xPosition);
Serial.print(" | Y: ");
Serial.print(yPosition);
Serial.print(" | Button: ");
Serial.println(buttonState);
delay(100);
Works perfectly for me... x and y pots both display 512 in the middle and go from 0 to 1023 as expected.
const byte xPin = A1;
const byte yPin = A0;
const byte buttonPin = 2;
int xPosition = analogRead(xPin);
int yPosition = analogRead(yPin);
int buttonState = digitalRead(buttonPin);
delay(100);
No point in making things longer than they have to be.
Also, note the code tags.
should work - double check your wiring - if all is fine there, then your unit is defective probably...
thanks guys.
