! HELP ! LCD Ecran
Bonjour j’ai effectué un montage pour un écran LCD voir le code ci dessous, la compilation est bonne mais l’écran reste Bleau et n’affiche rien, qui pourrait m’aider au plus vite
Cordialement !
#include <LiquidCrystal.h>
#include<EEPROM.h>
const int rs = 7, en = 6, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
const int stsp = A0;
const int inc = A1;
const int dec = A2;
const int set = A3;
const int buzz = 9;
const int relay = 8;
int hrs = 0;
int Min = 0;
int sec = 0;
unsigned int check_val = 50;
int add_chk = 0;
int add_hrs = 1;
int add_min = 2;
bool RUN = true;
bool min_flag = true;
bool hrs_flag = true;
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Mr. Screw Driver");
lcd.setCursor(0, 1);
lcd.print("COUNTDOWN TIMER");
pinMode(stsp, INPUT_PULLUP);
pinMode(inc, INPUT_PULLUP);
pinMode(dec, INPUT_PULLUP);
pinMode(set, INPUT_PULLUP);
pinMode(buzz, OUTPUT);
pinMode(relay, OUTPUT);
digitalWrite(relay, LOW);
digitalWrite(buzz, LOW);
if (EEPROM.read(add_chk) != check_val)
EEPROM.write(add_chk, check_val);
EEPROM.write(add_hrs, 0);
EEPROM.write(add_min, 1);
hrs = EEPROM.read(add_hrs);
Min = EEPROM.read(add_min);
delay(1500);
INIT();
if (digitalRead(stsp) == LOW)
lcd.clear();
delay(250);
RUN = true;
while (RUN)
lcd.clear();
lcd.print(" TIMER STOPPED");
lcd.print("----------------");
delay(2000);
RUN = false;
INIT();
digitalWrite(relay, HIGH);
sec = sec - 1;
if (sec == -1)
sec = 59;
Min = Min - 1;
if (Min == -1)
Min = 59;
hrs = hrs - 1;
if (hrs == -1) hrs = 0;
lcd.print("****************");
lcd.setCursor(4, 0);
if (hrs <= 9)
lcd.print('0');
lcd.print(hrs);
lcd.print(':');
if (Min <= 9)
lcd.print('0');
lcd.print(Min);
lcd.print(':');
if (sec <= 9)
lcd.print('0');
lcd.print(sec);
if (hrs == 0 && Min == 0 && sec == 0)
RUN = false;
for (int i = 0; i < 20; i++)
digitalWrite(buzz, HIGH);
delay(100);
delay(100);
INIT();
if (digitalRead(set) == LOW)
while (min_flag)
lcd.clear();
lcd.print("SET MINUTE: ");
lcd.print(Min);
delay(100);
if (digitalRead(inc) == LOW)
Min = Min + 1;
if (Min >= 60) Min = 0;
delay(100);
if (digitalRead(dec) == LOW)
Min = Min - 1;
if (Min <= -1) Min = 0;
delay(100);
min_flag = false;
delay(250);
while (hrs_flag)
lcd.clear();
lcd.print("SET HOUR: ");
lcd.print(hrs);
delay(100);
hrs = hrs + 1;
if (hrs > 23) hrs = 0;
delay(100);
hrs = hrs - 1;
if (hrs <= -1) hrs = 0;
delay(100);
hrs_flag = false;
delay(250);
if (hrs == 0 && Min == 0)
lcd.clear();
lcd.print(" INVAID TIME");
delay(2000);
EEPROM.write(add_hrs, hrs);
EEPROM.write(add_min, Min);
INIT();
void INIT()
sec = 0;
lcd.clear();
lcd.print("Start / Set Time");
lcd.setCursor(4, 1);
if (hrs <= 9)
lcd.print('0');
lcd.print(hrs);
lcd.print(':');
if (Min <= 9)
lcd.print('0');
lcd.print(Min);
lcd.print(':');
if (sec <= 9)
lcd.print('0');
lcd.print(sec);
min_flag = true;
hrs_flag = true;
Merci d’éditer votre post en utilisant le :pencil2: dans la barre d’outil juste sous votre post et rajoutez les balises de de code (c’est difficilement lisible tel quel) :
  • sélectionner la partie du texte qui correspond au code
  • appuyez sur l’icône <code/> dans la barre d’outils pour indiquer que c’est du code
(Assurez vous aussi d’indenter le code correctement dans l’IDE avant de le copier pour le coller ici. Cela se fait en pressant ctrlT sur PC ou cmdT sur un Mac)
il serait bon de (re)lire les recommandations listées dans “Les bonnes pratiques du Forum Francophone”
Pour votre question testez votre montage avec un des exemples de votre bibliothèque
Pas de doublon !!!
Tu as déjà un fil de discussion traitant de ce sujet.
Je pense qu'effectivement il est grand temps de lire "les bonnes pratiques du forum".
