Help me to combine these codes and the servo motor to return to its original position
Please check if my code is correct
I need my servo to go back to its original position
#include <LiquidCrystal.h>
#include <Wire.h>
#include <RTClib.h>
#include <EEPROM.h>
#include <Servo.h>
RTC_DS3231 rtc;
Servo servo;
const int analogInPin = A1;
const int rs = 12, en = 11, d4 = 6, d5 = 5, d6 = 4, d7 = 3; // lcd pins
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int buzz = 13;
int addr=17;
int sensorValue = 0;
int servoPin = 2;
int i = 0;
const int buttonPin2 = 9;
const int buttonPin3 = 8;
const int buttonPin1 = A0;
const int buttonPin4 = 7; // the pin that the pushbutton is attached to
int val2 = 0;
int val3=0;
int pushVal;
int bS1 = 0; // current state of the button
int lBS1 = 0; // previous state of the button
int bS2 = 0; // current state of the button
int lBS2 = 0;
int bS3 = 0; // current state of the button
int lBS3 = 0;
int bS4 = 0; // current state of the button
int lBS4 = 0;
// configure the pins to the right mode
int buzz8amHH = 07; // HH - hours ##Set these for reminder time in 24hr Format
int buzz8amMM = 00; // MM - Minute
int buzz8amSS = 00; // SS - Seconds
int buzz2pmHH = 02; // HH - hours
int buzz2pmMM = 00; // MM - Minute
int buzz2pmSS = 00; // SS - Seconds
int buzz8pmHH = 07; // HH - hours
int buzz8pmMM = 00; // MM - Minute
int buzz8pmSS = 00; // SS - Seconds
int nowHr, nowMin, nowSec;
void gwsMessege(){ // print get well soon messege
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Stay Healthy :)"); // Give some cheers
lcd.setCursor(0, 1);
lcd.print("Get Well Soon :)");// wish
void helpScreen() { // function to display 1st screen in LCD
lcd.clear();
lcd.print("Press Buttons");
lcd.print("for Reminder...!");
void timeScreen() { // function to display Date and time in LCD screen
DateTime now = rtc.now(); // take rtc time and print in display
lcd.clear();
lcd.print("Time:");
lcd.setCursor(6, 0);
lcd.print(nowHr = now.hour(), DEC);
lcd.print(":");
lcd.print(nowMin = now.minute(), DEC);
lcd.print(":");
lcd.print(nowSec = now.second(), DEC);
lcd.print("Date: ");
lcd.print(now.day(), DEC);
lcd.print("/");
lcd.print(now.month(), DEC);
lcd.print("/");
lcd.print(now.year(), DEC);
servo.attach(servoPin);
Wire.begin();
//rtc.adjust(DateTime(F(DATE), F(TIME))); // uncomment this to set the current time and then comment in next upload when u set the time
rtc.adjust(DateTime(2022, 21, 12, 06, 59, 00)); // manual time set
lcd.begin(16, 2);
lcd.clear();
lcd.print("Welcome To Our"); // print a messege at startup
lcd.print("Medicine Reminder");
gwsMessege();
delay(3000);
helpScreen();
delay(2000);
timeScreen();
delay(3000);
lcd.clear();
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
pinMode(buttonPin3, INPUT);
pinMode(buttonPin4, INPUT);
pinMode(buzz, OUTPUT);
void ValSet(){
Serial.println(EEPROM.read(addr));
val2 = EEPROM.read(addr); // read previosuly saved value of push button to start from where it was left previously
switch (val2) {
case 1:
lcd.clear();
lcd.print("Reminder set ");
lcd.print("for Once/day !");
pushVal = 1;
case 2:
lcd.clear();
lcd.print("for Twice/day !");
pushVal = 2;
case 3:
lcd.clear();
lcd.print("for Thrice/day !");
pushVal = 3;
// the main loop will constantly check to see if the button has been pressed
// if it has, a counter is incremented, and then some action can be taken
{ //call to set thrice/day
if (pushVal == 1) { // if push button 1 pressed then remind at 8am
at8am(); //function to start uzzing at 8am
else if (pushVal == 2) { // if push button 2 pressed then remind at 8am and 8pm
at8am();
at8pm(); //function to start uzzing at 8mm
else if (pushVal == 3) { // if push button 3 pressed then remind at 8am and 8pm
at8am();
at2pm(); //function to start uzzing at 8mm
at8pm();
// read the state of the button
bS1 = digitalRead(buttonPin1);
bS2 = digitalRead(buttonPin2);
bS3 = digitalRead(buttonPin3);
bS4 = digitalRead(buttonPin4);
// check to see if it different than the last time we checked
if (bS2 != lBS2) {
// either the button was just pressed or just released
if (bS2 == HIGH) {
// it was just pressed
Serial.println("n02");
EEPROM.write(17,1);
push1();
lBS2 = bS2;
if (bS3 != lBS3) {
if (bS3 == HIGH) {
Serial.println("no3");
EEPROM.write(17,2);
push2();
lBS3 = bS3;
if (bS4 != lBS4) {
if (bS4 == HIGH) {
Serial.println("no4");
EEPROM.write(17,3);
push3();
lBS4 = bS4;
if (bS1 != lBS1) {
if (bS1 == HIGH) {
val3=EEPROM.read(addr);
EEPROM.write(17,0);
digitalWrite(buzz, LOW);
pinstop();
EEPROM.write(17,val3);
lBS1 = bS1;
timeScreen();
ValSet();
void push1() { // function to set reminder once/day //save the state of push button-1
lcd.clear();
delay(1200);
lcd.clear();
void push2() { //function to set reminder twice/day
lcd.clear();
delay(1200);
lcd.clear();
void push3() { //function to set reminder thrice/day
lcd.clear();
delay(1200);
lcd.clear();
void pinstop(){ //function to stop buzzing when user pushes stop push button
lcd.clear();
lcd.print("Take Medicine ");
lcd.print("with Warm Water");
delay(5000);
lcd.clear();
void at8am() { // function to start buzzing at 8am
DateTime t = rtc.now();
if (int(t.hour()) == buzz8amHH && int(t.minute()) == buzz8amMM && (int(t.second()) == buzz8amSS || int(t.second()) < buzz8amSS+10)) {
digitalWrite(buzz,HIGH);
lcd.clear();
lcd.print("Time to take ");
lcd.print("Morning medicines.");
delay(5000);
void at2pm() { // function to start buzzing at 2pm
if (int(t.hour()) == buzz2pmHH && int(t.minute()) == buzz2pmMM && (int(t.second()) == buzz2pmSS || int(t.second()) < buzz2pmSS+10)) {
lcd.clear();
lcd.print("Afternoon medicines.");
delay(5000);
void at8pm() { // function to start buzzing at 8pm
if (int(t.hour()) == buzz8pmHH && int(t.minute()) == buzz8pmMM && (int(t.second()) == buzz8pmSS || int(t.second()) < buzz8pmSS+10)) {
lcd.clear();
lcd.print("Night medicines.");
delay(5000);
sensorValue = analogRead(analogInPin);
if(sensorValue < 600){
for (int i = 0; i<=180; i++){
servo.write(i);
delay(10);
servo.write(i);
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
What should the combined sketch do ?
Please post your best attempt at combining the sketches and explain any problems
Help us help you.
code merging
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
What does "correct" mean? I cannot possibly read your mind and magically know what you intend for your code to do.
So you want to go back to 90°? That's where the servo moves when you attach the pin.
To go back to 90°:
servo.write(90);
#include <Wire.h>
#include <RTClib.h>
#include <EEPROM.h>
RTC_DS3231 rtc;
int buzz = 13;
int addr=17;
int val2 = 0;
int val3=0;
int pushVal;
int lBS2 = 0;
int lBS3 = 0;
int lBS4 = 0;
int buzz8amHH = 08;          //    HH - hours         ##Set these for reminder time in 24hr Format
int buzz8pmHH = 09;          //    HH - hours
    lcd.clear();
    lcd.clear();
    lcd.clear();
    lcd.print("Time:");
    lcd.print(":");
    lcd.print(":");
    lcd.print("/");
    lcd.print("/");
Wire.begin();
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));            // uncomment this to set the current time and then comment in next upload when u set the time
  //rtc.adjust(DateTime(2019, 10, 12, 15, 50, 30));                // manual time set
  lcd.begin(16, 2);
  lcd.clear();
  gwsMessege();
  delay(3000);
  helpScreen();
  delay(2000);
  timeScreen();
  delay(3000);
  lcd.clear();
void ValSet(){
  switch (val2) {
    case 1:
      lcd.clear();
      pushVal = 1;
    case 2:
      lcd.clear();
      pushVal = 2;
    case 3:
      lcd.clear();
      pushVal = 3;
    at8am();
    at8am();
    at8pm();
if (bS2 != lBS2) {
    if (bS2 == HIGH) {
      EEPROM.write(17,1);
      push1();
  lBS2 = bS2;
if (bS3 != lBS3) {
    if (bS3 == HIGH) {
      EEPROM.write(17,2);
      push2();
  lBS3 = bS3;
if (bS4 != lBS4) {
    if (bS4 == HIGH) {
      EEPROM.write(17,3);
      push3();
  lBS4 = bS4;
if (bS1 != lBS1) {
    if (bS1 == HIGH) {
      EEPROM.write(17,0);
      pinstop();
  lBS1 = bS1;
  timeScreen();
  ValSet();
    lcd.clear();
    delay(1200);
    lcd.clear();
    lcd.clear();
    delay(1200);
    lcd.clear();
    lcd.clear();
    delay(1200);
    lcd.clear();
    lcd.clear();
    delay(5000);
    lcd.clear();
        lcd.clear();
        delay(5000);
        lcd.clear();
        delay(5000);
        lcd.clear();
        delay(5000);
Please help me add a servo motor and an IR sensor code for dispensing machine
Also posted for a second time in the wrong category. Flagged for moderation.
I have merged your posts due to them having too much overlap on the same subject matter @darwin2k.
In the future, please only create one topic for each distinct subject matter and be careful not to cause them to converge into parallel discussions.
The reason is that generating multiple threads on the same subject matter can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Thanks in advance for your cooperation.
The codes have no errors it's just that the servo motor and sensor doesn't function
Sometimes it functions but the it doesn't go back to original position of the servo motor
... in what code, does it behave like that? The latest code above, seems like just a request to help merge. Not a complete first test sketch.
The code you have posted in post #8
contains zero lines of code that would activate or control a servo
and it
contains zero lines of code that would do anything with any kind of sensor
So a lot of information is missing.
If a new project starts:
Even the most advanced software-developper-expert with 40 years programming experience will ask his customer:
"what functionality do you want to have?" please describe it in normal words
As you are a beginner it is 100 times more important to give a normal worded description of the wanted functionality. As a beginner it might be that you have some misconceptions about how code works. If the misconception is small it is hard to detect this misconception.
This is the reason why it is very important to describe the wanted functionality in normal words.
You can finish your project in two ways:
way 1: taking looong almost unlimited time
Way 2: taking a limited time.
Way 2 is to take a limited time of maybe 60 minutes to carefully think over how can I describe the wanted functionality in normal words? Starting to write. Reading it again, delete some parts write it new, add more specific words etc.
Way 1
shooting quick in the dark with a very short posting which then invokes asking back
the asking back is after some time maybe 10 minutes maybe 2 hours or 5 hours later
Shooting Quick In the Dark Asking Back
I will use the abbreviation "sqidab" for better making visible what will gonna happen
sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...sqidab...
and after weeks still no finished project.
If sqidab-ing is your favorite pleasure go ahead whirling in circles without moving forward.
If you would like to finish your project go and take the limited time to read 20 minutes
and then write down and RE-editing a decent normal worded description of your project
best regards Stefan
