Help me using MPU6050 GY-521
I’m trying to use my MPU6050 through library named MPU6050 electronic cats
I tried to run the library’s example, however it always fails at testConnection()
I also looked into the library’s source code, but I couldn’t comprehended what are required to make the function return true.
(Sorry for nasty setup and picture. I will get better picture if you need one)
This is my current setup. I did the soldering job myself, and it is connected to Arduino Nano.
VCC is connected at 5v(also tried 3v), and SCL, SDA are connected in A5, A6(though, I tried pretty much every successive combination with those, like A3 4, A2 3, A1 2, I even tried switching each other.).
What did I miss?
Welcome to the forum
SDA is A4 and SCL is A5
Which pins are you actually using ?
Does an I2C scanner find you device ?
Hello!!
Sorry for the late reply
Yeah.. it seems that my 3 hours really couldn’t think that pin combination was not conducted somehow..
Thanks, the library is now able to find my device
I am glad that iI was able to help
Good luck with your project
