Help - Motion Sensor Issue
Hi All, I'm a newbie and had code written for a simple mechanical eye movement using two servos per eye on an Arduino Uno using a PWM (PCA965) for 4 servos (DS3235).
The movement sequence is triggered by a motion sensor . When I push the button to enable the motion sensor the servos start the sequence even though motion has not been detected. The serial monitor shows "motion detected" continuously. If there is actual motion it does not register. I've replace the motion detector but no change.
Any help would be appreciated.
Sensor Wired as follows
5V
output to pin 7 on arduino uno
ground
jumper is on L
I have an external power supply connected to my PWM.
Here is the code.
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h> //Including PWM libraries
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(); //Setting up PWM
#define RlrSERVOMIN  290
#define RlrSERVOMAX  370
#define RudSERVOMIN  290
#define RudSERVOMAX  370
#define LlrSERVOMIN  290
#define LlrSERVOMAX  370
#define LudSERVOMIN  290
#define LudSERVOMAX  370
//CENTER
#define RIGHTlrSERVOHOME 330
#define RIGHTudSERVOHOME 330
#define LEFTlrSERVOHOME 330
#define LEFTudSERVOHOME 330
int SPEED = 8;
#define SERVO_FREQ 50 //Dont change this
#define SERVO_RUD 0 //change this only if you plug in servo to diffrent pins
#define SERVO_RLR 1 //change this only if you plug in servo to diffrent pins
#define SERVO_LUD 2 //change this only if you plug in servo to diffrent pins
#define SERVO_LLR 3 //change this only if you plug in servo to diffrent pins
int LED1Pin = 8; //change this only if you plug in LED to diffrent pin
int LED2Pin = 9; //change this only if you plug in LED to diffrent pin
int LED3Pin = 10; //change this only if you plug in LED to diffrent pin
int button1Pin = 4; //change this only if you plug in Button to diffrent pin
int button2Pin = 2; //change this only if you plug in Button to diffrent pin
int button3Pin = 3; //change this only if you plug in Button to diffrent pin
const int motionSensorPin = 7; //change this only if you plug in MotionSensor to diffrent pin
//Bools to flag system on, motion sensor active, and random move active
bool systemActive = false;
bool motionSensorActive = false;
bool randomMoveActive = false;
//bools to flag weather button was pressed before
static bool button1LastState = false;
static bool button2LastState = false;
static bool button3LastState = false;
//Dont change these they are for button bouncing
unsigned long LastTimeButton1StateChanged = millis();
unsigned long LastTimeButton2StateChanged = millis();
unsigned long LastTimeButton3StateChanged = millis();
unsigned long LastTimeRandomWasSet = millis();
unsigned long LastTimeRandomStarted = millis();
unsigned long debounceDuration = 50;
int  currentPosRlr = RIGHTlrSERVOHOME;
int  currentPosRud = RIGHTudSERVOHOME;
int  currentPosLlr = LEFTlrSERVOHOME;
int  currentPosLud = LEFTudSERVOHOME;
int doLeftToRightNonBlockingPlayCount = 0;
int doRandomMoveNonBlockingPlayCount = 0;
  //set up for console
  Serial.println("System Initialized");
  //set up for LED pins
  pinMode(LED1Pin, OUTPUT);
  pinMode(LED2Pin, OUTPUT);
  pinMode(LED3Pin, OUTPUT);
  //set up for button pins
  pinMode(button1Pin, INPUT);
  pinMode(button2Pin, INPUT);
  pinMode(button3Pin, INPUT);
  //set up for motion sensor pin
  pinMode(motionSensorPin, INPUT_PULLUP);
  //reads buttons
  button1LastState = digitalRead(button1Pin);
  button2LastState = digitalRead(button2Pin);
  button3LastState = digitalRead(button3Pin);
  //set up for PWM
  pwm.begin();
  pwm.setOscillatorFrequency(27000000);
  pwm.setPWMFreq(SERVO_FREQ);
unsigned long doRandomMovePreviousMillis = 0;
const long doRandomMoveInterval = 20;
int doRandomMoveStepCount = 0;
int doRandomMoveTargetPosRlr = 330;
int doRandomMoveTargetPosRud = 330;
int doRandomMoveTargetPosLlr = 330;
int doRandomMoveTargetPosLud = 330;
void doRandomMoveNonBlocking(){
  if (doRandomMoveStepCount == 0) {
    doRandomMoveTargetPosRlr = random(RlrSERVOMIN, RlrSERVOMAX);
    doRandomMoveTargetPosRud = random(RudSERVOMIN, RudSERVOMAX);
    doRandomMoveTargetPosLlr = random(LlrSERVOMIN, LlrSERVOMAX);
    doRandomMoveTargetPosLud = random(LudSERVOMIN, LudSERVOMAX);
    currentPosRlr = doRandomMoveTargetPosRlr;
    currentPosRud = doRandomMoveTargetPosRud;
    currentPosLlr = doRandomMoveTargetPosLlr;
    currentPosLud = doRandomMoveTargetPosLud;
    doRandomMoveStepCount = 1;
  if (currentMillis - doRandomMovePreviousMillis >= doRandomMoveInterval) {
    doRandomMovePreviousMillis = currentMillis;
    if (doRandomMoveStepCount <= 25) {
      int posRlr = currentPosRlr + (doRandomMoveTargetPosRlr - currentPosRlr) * doRandomMoveStepCount / 50;
      int posRud = currentPosRud + (doRandomMoveTargetPosRud - currentPosRud) * doRandomMoveStepCount / 50;
      int posLlr = currentPosLlr + (doRandomMoveTargetPosLlr - currentPosLlr) * doRandomMoveStepCount / 50;
      int posLud = currentPosLud + (doRandomMoveTargetPosLud - currentPosLud) * doRandomMoveStepCount / 50;
      pwm.setPWM(SERVO_RUD, 0, posRud);
      pwm.setPWM(SERVO_RLR, 0, posRlr);
      pwm.setPWM(SERVO_LUD, 0, posLud);
      pwm.setPWM(SERVO_LLR, 0, posLlr);
      currentPosRlr = posRlr;
      currentPosRud = posRud;
      currentPosLlr = posLlr;
      currentPosLud = posLud;
      doRandomMoveStepCount++;
    }else{
      doRandomMoveNonBlockingPlayCount ++;
void doLeftToRightNonBlocking(){
    if (doRandomMoveStepCount <= 50) {
      int posRlr = currentPosRlr + (RlrSERVOMIN - currentPosRlr) * doRandomMoveStepCount / 100;
      int posLlr = currentPosLlr + (LlrSERVOMIN - currentPosLlr) * doRandomMoveStepCount / 100;
    }else if(doRandomMoveStepCount <= 200 && doRandomMoveStepCount > 50){
      int posRlr = currentPosRlr + (RlrSERVOMAX - currentPosRlr) * doRandomMoveStepCount / 300;
      int posLlr = currentPosLlr + (LlrSERVOMAX - currentPosLlr) * doRandomMoveStepCount / 300;
    }else{
      doLeftToRightNonBlockingPlayCount++;
void resetServos() {
  //this function moves all the servos to the home position
  pwm.setPWM(0, 0, RIGHTlrSERVOHOME);
  pwm.setPWM(1, 0, RIGHTudSERVOHOME);
  pwm.setPWM(2, 0, LEFTlrSERVOHOME);
  pwm.setPWM(3, 0, LEFTudSERVOHOME);
void eyeMovement(){
  //Add side to side motion below
  //Position 1
  //Eye 1
  pwm.setPWM(0, 0, RIGHTlrSERVOHOME + 5);
  //Eye 2
  pwm.setPWM(2, 0, LEFTlrSERVOHOME + 30);
  pwm.setPWM(3, 0, LEFTudSERVOHOME - 40);
  delay(150);
  //Position 2
  //Eye 1
  pwm.setPWM(0, 0, RIGHTlrSERVOHOME +5);
  //Eye 2
  pwm.setPWM(2, 0, LEFTlrSERVOHOME + 15);
  pwm.setPWM(3, 0, LEFTudSERVOHOME -40);
  delay(200);
  //Position 3
  //Eye 1
  pwm.setPWM(1, 0, RIGHTudSERVOHOME - 5);
  //Eye 2
  delay(150);
  //Position 4
  //Eye 1
  //Eye 2
  pwm.setPWM(2, 0, LEFTlrSERVOHOME + 40);
  pwm.setPWM(3, 0, LEFTudSERVOHOME + 5);
  delay(150);
  //Position 5
  //Eye 1
  pwm.setPWM(0, 0, RIGHTlrSERVOHOME + 20);
  pwm.setPWM(1, 0, RIGHTudSERVOHOME - 40);
  //Eye 2
  delay(100);
  //Position 6
  //Eye 1
  pwm.setPWM(0, 0, RIGHTlrSERVOHOME + 30);
  pwm.setPWM(1, 0, RIGHTudSERVOHOME - 10);
  //Eye 2
  pwm.setPWM(3, 0, LEFTudSERVOHOME + 15);
  delay(150);
  //Position 7
  //Eye 1
  pwm.setPWM(0, 0, RIGHTlrSERVOHOME + 40);
  //Eye 2
  delay(150);
  //Position 8
   //Eye 1
  //Eye 2
  pwm.setPWM(3, 0, LEFTudSERVOHOME -5);
  delay(150);
  //Position 9
   //Eye 1
  //Eye 2
  delay(150);
  //Position 10
  //Eye 1
  pwm.setPWM(1, 0, RIGHTudSERVOHOME + 10);
  //Eye 2
  delay(150);
  //Position 11
 //Eye 1
  pwm.setPWM(1, 0, RIGHTudSERVOHOME - 20);
  //Eye 2
  delay(150);
  //Position 12
  //Eye 1
  pwm.setPWM(0, 0, RIGHTlrSERVOHOME + 35);
  //Eye 2
  delay(150);
  //Position 13
  //Eye 1
  pwm.setPWM(1, 0, RIGHTlrSERVOHOME + 40);
  pwm.setPWM(0, 0, RIGHTudSERVOHOME);
  //Eye 2
  pwm.setPWM(3, 0, LEFTlrSERVOHOME + 40);
  pwm.setPWM(2, 0, LEFTudSERVOHOME);
  delay(150);
  //Position 14
  //Eye 1
  pwm.setPWM(1, 0, RIGHTlrSERVOHOME+ 30);
  //Eye 2
  pwm.setPWM(3, 0, LEFTlrSERVOHOME + 30);
  delay(150);
  //Position 15
  //Eye 1
  pwm.setPWM(1, 0, RIGHTlrSERVOHOME+ 20);
  //Eye 2
  pwm.setPWM(3, 0, LEFTlrSERVOHOME + 20);
  delay(150);
  //Position 16
  //Eye 1
  pwm.setPWM(1, 0, RIGHTlrSERVOHOME+ 10);
  //Eye 2
  pwm.setPWM(3, 0, LEFTlrSERVOHOME + 10);
  delay(150);
  //Position 17
  //Eye 1
  pwm.setPWM(1, 0, RIGHTlrSERVOHOME);
  //Eye 2
  pwm.setPWM(3, 0, LEFTlrSERVOHOME);
  delay(150);
  //Position 18
  //Eye 1
  pwm.setPWM(1, 0, RIGHTlrSERVOHOME - 10);
  //Eye 2
  pwm.setPWM(3, 0, LEFTlrSERVOHOME - 10);
  delay(150);
  //Position 19
  //Eye 1
  pwm.setPWM(1, 0, RIGHTlrSERVOHOME - 20);
  //Eye 2
  pwm.setPWM(3, 0, LEFTlrSERVOHOME - 20);
  delay(150);
  //Position 20
  //Eye 1
  pwm.setPWM(1, 0, RIGHTlrSERVOHOME - 30);
  //Eye 2
  pwm.setPWM(3, 0, LEFTlrSERVOHOME - 30);
  delay(150);
  //Position 21
  //Eye 1
  pwm.setPWM(1, 0, RIGHTlrSERVOHOME - 40);
  //Eye 2
  pwm.setPWM(3, 0, LEFTlrSERVOHOME - 40);
  delay(300);
  resetServos(); //Move the servos to the home position and turn the LEDS on
bool readyToDetectMotion = true;
unsigned long timeLastMotionWasDetected = 0;
  //this is constantly looped
  if (millis() - LastTimeButton1StateChanged >= debounceDuration) { //If debounceTime is up since first button was pressed (for debouncing)
    bool Button1State = digitalRead(button1Pin); //Check to see what button 1 reads
    if (Button1State != button1LastState) { //if button 1 is not what it was last time(on or off)
      LastTimeButton1StateChanged = millis(); //for button debouncing
      if (Button1State == LOW) { //if button is pressed
        Serial.println("Button 1 has been pressed");
        if(systemActive){ //if the system was active before and the button was pressed
          Serial.println("SYSTEM IS NOW OFF");
          systemActive = false; //turn the system off
        else{
          Serial.println("SYSTEM IS NOW ON");
          systemActive = true; //turn the system on
          resetServos();//moves all the servos to the home position
      button1LastState = Button1State; //set last button press to what it is now
  if(systemActive){ //if the system is on
    digitalWrite(LED1Pin, HIGH); //turn the Green LED on
    if (millis() - LastTimeButton2StateChanged >= debounceDuration) { //If debounceTime is up since first button was pressed (for debouncing)
      bool Button2State = digitalRead(button2Pin); //Check to see what button 2 reads
      if (Button2State != button2LastState) { //if button 2 is not what it was last time(on or off)
        LastTimeButton2StateChanged = millis(); //for debouncing
        if (Button2State == LOW) { //if button is pressed
          Serial.println("Button 2 has been pressed");
          if(motionSensorActive){ //if the motion sensor system was on before and button was pressed
            Serial.println("Motion sensor SYSTEM IS NOW OFF");
            motionSensorActive = false; //turn the Motion sensor system off
          else{
            Serial.println("Motion sensor SYSTEM IS NOW ON");
            motionSensorActive = true; //turn the Motion sensor system on
        button2LastState = Button2State; //set last button press to what it is now
    if (millis() - LastTimeButton3StateChanged >= debounceDuration) { //If debounceTime is up since first button was pressed (for debouncing)
      bool Button3State = digitalRead(button3Pin); //Check to see what button 3 reads
      if (Button3State != button3LastState) { //if button 3 is not what it was last time(on or off)
        LastTimeButton3StateChanged = millis(); //for button debouncing
        if (Button3State == LOW) { //if button is pressed
          Serial.println("Button 3 has been pressed");
          if(randomMoveActive){
            Serial.println("randomMoveActive SYSTEM IS NOW OFF");
            randomMoveActive = false; //randomMoveActive sensor system off
            resetServos(); //home the servos
            digitalWrite(LED2Pin, HIGH); //turn eye LEDS on
            digitalWrite(LED3Pin, HIGH); //turn eye LEDS on
          else{
            Serial.println("randomMoveActive SYSTEM IS NOW ON");
            randomMoveActive = true; //randomMoveActiven sensor system on
        button3LastState = Button3State; //set last button press to what it is now
    if(randomMoveActive){ //when random move is active (this will NOT move the servos randomly)
      for(int i = 0; i < 6; i++){ //repeat the action 4 times CHANGE this to however many times you want eyes to do moving action
        eyeMovement();
        eyeMovement();
        eyeMovement();
        delay(1500);
        delay(15000); //wait 10 seconds before turning LEDS off
        digitalWrite(LED2Pin, LOW);
        digitalWrite(LED3Pin, LOW);
      randomMoveActive = false; //once system does moving action turns off random move active
    if(doLeftToRightNonBlockingPlayCount == 1 || doLeftToRightNonBlockingPlayCount == 2){
      doLeftToRightNonBlocking();
    }else if(doLeftToRightNonBlockingPlayCount == 3){
      doRandomMoveNonBlockingPlayCount = 1;
    if(doRandomMoveNonBlockingPlayCount >= 1 && doRandomMoveNonBlockingPlayCount <= 7){
      doRandomMoveNonBlocking();
    }else if(doRandomMoveNonBlockingPlayCount == 8){
      resetServos();
      delay(2000);
      delay(5000);
    if(motionSensorActive){  //when motion sensor is active
      int motionDetectedRead = digitalRead(motionSensorPin);
      if(millis() - timeLastMotionWasDetected >= 30000){
         if(motionDetectedRead == HIGH) {
              if (readyToDetectMotion) {
                  Serial.println("MotionDetected");
                  doLeftToRightNonBlockingPlayCount = 1;
                  readyToDetectMotion = false;
                  timeLastMotionWasDetected = millis();
              if(millis() - timeLastMotionWasDetected >= 30000) {
  else{ //when sysytem is off
    //turn all LEDs off
    digitalWrite(LED1Pin, LOW);
    resetServos();
Can you provide a link to the details of it?
Maybe the motion sensor outputs LOW when motion is detected. Which is why I asked the question in my previous post.
If you haven't done so already, it would be worth writing a simple sketch that just reads the motion detector output and outputs what it read using Serial.print.
chatGPT: 500 lines to detect motion and move four servos.
Throw it away.
According to chatGPT, motion has been detected. Ask chat why.
Sounds dangerous. Disconnect everything. Draw a picture of your project wiring.
You would be much happier writing your own code. You know it will work and you will know how to fix it. For example; Motion Detection 20 lines...
byte sensor = 2;
bool pinState, pinStateOld;
  Serial.begin(115200); // start serial comm
  pinMode(sensor, INPUT);
  pinState = digitalRead(sensor);   // read new state
  if (pinStateOld == LOW && pinState == HIGH) { // state change to active
    Serial.println("Motion detected!");
  if (pinStateOld == HIGH && pinState == LOW) {   // state change to inactive
    Serial.println("Motion stopped!");
  pinStateOld = pinState; // store old state
Servo Movement, 20 lines...
#include <Servo.h>
Servo servo;
byte servoPin = 2;
int position = 0, direction = 1; // positive direction
#define HOME 0 // start servo at zero positions
  servo.attach(servoPin);
  servo.write(HOME); // start at zero
  if (position > 180 || position < 0) // at end of sweep
    direction = -direction; // change direction
  servo.write(position);
  position += direction; // change position
  delay(5); // each step should have a pause
Four servo movement, 30 lines...
#include <Servo.h>
byte servoPin[] = {2, 3, 4, 5}; // array of servos
const int servos = sizeof(servoPin) / sizeof(servoPin[0]); // number of servos
Servo servo[servos];
  for (int i = 0; i < servos; i++) {
    servo[i].attach(servoPin[i]);
    servo[i].write(HOME); // start at zero
    if (i % 2) // odd servos
      servo[i].write(position);
    else // even servos
      servo[i].write(180 - position);
Thanks for the reply Dave. Its a PIR motion sensor.
Thanks xfpd. The code was written by a programmer and he is also stumped as to why its not working. Unfortunately I'm very new to this so I wouldn't be able to code myself. Everything in the program works ok except the sensor.
I do wonder though. the power for the buttons, the sensor and the PWM are all in series. (with external power for the servos through the PWM)
Please, provide a drawing of your connections.
How experienced could this programmer be, not to write a program to just test the motion sensor and learn how it operates and then put that logic into the final program.
Take some initiative and tell the programmer to write a test program for the sensor!
