Hi.....am making a project on infrared pulse sensor and am getting an error in this program while Processing......i have my project submission in sometime.....plzz plzz do help....this is program where am getiing error
// Based on examples from Arduino's Graphing Tutorial and OscP5 documentation
import processing.serial.*;
Serial myPort; // The serial port
int xPos = 1; // horizontal position of the graph
float oldHeartrateHeight = 0; // for storing the previous reading
void setup () {
// set the window size:
size(600, 400);
frameRate(25);
// List available serial ports.
println(Serial.list());
// Setup which serial port to use.
// This line might change for different computers.
myPort = new Serial(this, Serial.list()[1], 9600);
// set inital background:
background(0);
void draw () {
void serialEvent (Serial myPort) {
// read the string from the serial port.
String inString = myPort.readStringUntil('\n');
if (inString != null) {
// trim off any whitespace:
inString = trim(inString);
// convert to an int
println(inString);
int currentHeartrate = int(inString);
// draw the Heartrate BPM Graph.
float heartrateHeight = map(currentHeartrate, 0, 1023, 0, height);
stroke(0,255,0);
line(xPos - 1, height - oldHeartrateHeight, xPos, height - heartrateHeight);
oldHeartrateHeight = heartrateHeight;
// at the edge of the screen, go back to the beginning:
if (xPos >= width) {
xPos = 0;
background(0);
I hope this is a school project and not something that anyone is actually going to need. "plzz plzz do help" does not inspire confidence.
As for the actual post:
supra21196, please read the sticky posts on the sub, in particular read point 6 of "read this before posting a programming question". Your post is exactly the kind of post that that particular point is about. You are simply not going to get any help at all until you make a post that contains the stuff that people need for to be able to help you.
